Author Topic: Dolch keyboard questions  (Read 2759 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Sat, 15 June 2013, 17:47:13 »
First off, how do I open it? What's the easiest way to convert the 4p4c connector to something that I can use (PS2 works, USB is better) that's also cheap?
Offline rainb1ood
  • so pretty so plastic
Re: Dolch keyboard questions
« Reply #1 on: Sat, 15 June 2013, 18:14:47 »
There are screws underneath the round rubber pads.
Offline khaangaaroo
« Reply #2 on: Sat, 15 June 2013, 18:15:20 »
I think the Dolch logo on the bottom has a screw hidden underneath it. Logo on the top does not, but I could be wrong. it's been a while since I took one apart.
Offline khaangaaroo
« Reply #3 on: Sat, 15 June 2013, 18:16:54 »
 or probably that. try the feet before the logo...haha
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sat, 15 June 2013, 18:17:23 »
It's bolted together, but there is one hidden under the logo badge so you will have to remove it with a hobbyknife or something. If you're not going to use it with a PAC ever again, I would just solder on PS/2 cable.
« Reply #5 on: Sat, 15 June 2013, 19:29:23 »
When you put it back together again, note that the screws are of different sizes. The short screws go in the front and the long screws go in the back.
The cable is connected to a 4p4c connector on the inside. I put a 4p4c plug on a old PS/2 cable. I used my "craft scissors" (the ones I abuse :) ) to strip the end of the PS/2 cable and crimped the connector with a screwdriver, but with a proper crimping tool you should be able to do both faster and cleaner.
From the Deskthority Wiki:
The pins are GND, +5V, kb data, kb clock (in order on the keyboard's side). Dolch PAC-65 keyboards with trackpoints have a larger modular connector and cable.
There is also a image floating around in one of these Dolch threads that shows the pinout.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Sat, 15 June 2013, 19:58:28 »
I just received the keyboard and I'm sure I will never find or use a PCB.
So all I need is a PS2 cable and solder them to the right places on the PCB according to the pinout guide that Findecanor posted?
« Reply #7 on: Sat, 15 June 2013, 20:57:43 »
Right. It's what I did on mine. Here are some more details and pictures and stuff in this thread.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Sat, 15 June 2013, 21:21:26 »
I finally got it apart. Who thought it was a good idea to glue over the screw heads!?@!
Anyways, now all I need to do is find a PS2 cable and add a plate!
Offline AKIMbO
  • HHKBro
« Reply #9 on: Sat, 15 June 2013, 21:22:13 »
I dismembered an old PS/2 mouse for my Dolch PAC.
| KBD75 (box reds)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #10 on: Sat, 15 June 2013, 21:24:29 »
I was thinking of sweet talking TJ for a nice sleeved PS2 cable :P
