Author Topic: Newegg has MSI mechanical keyboards in stock  (Read 2860 times)
Offline missalaire
  • Great Finder of Great Finds
« on: Sun, 16 June 2013, 00:37:03 »
MSI CK Series Black 104 Normal Keys USB or PS/2 Wired Standard Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823167011
MSI GK-601 Black 104 Normal Keys USB 2.0 Wired Gaming Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823167010
And boy are they fugly.
Offline daerid
    • Rossipedia
Re: Newegg has MSI mechanical keyboards in stock
« Reply #1 on: Sun, 16 June 2013, 00:38:31 »
Looks like iOne :-/
« Reply #2 on: Sun, 16 June 2013, 00:39:35 »
I don't get it.. what's the extra $50 for? They both look exactly the same.
Offline gnubag
« Reply #3 on: Sun, 16 June 2013, 00:40:48 »
backlit! totally worth it.
Offline crthell
    • crthell
« Reply #4 on: Sun, 16 June 2013, 15:00:56 »
meh
/crthell
Mechanical Keyboard(s): Apple Extended Keyboard II M3501 (dampened Alps)
Quality Rubber Dome(s): Dell QuietKey RT7D5JTW
Offline Leslieann
« Reply #5 on: Sun, 16 June 2013, 18:33:01 »
Goes well with the old Antec Lanboy case. Ick.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #6 on: Sun, 16 June 2013, 18:58:25 »
Looks like iOne :-/
Looks like?
It is without any doubt a Scorpius M10. They didn't even bother to change the case - they just slapped a coat of paint on it and left in the punch-outs on the CK versus the GK. That alone should tell you all you need to know about the quality, unfortunately.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
