Author Topic: AcidFire's modular keyboard system - Axios [In Development]  (Read 899904 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: AcidFire's custom split keyboard - ErgoGP
« Reply #200 on: Tue, 16 July 2013, 15:33:10 »
I can't give it all away yet! right now it's all living in my head, I'll have to sketch it out first and pass it along to someone who can render it out properly for me. Right now the way I have it in my head, it would only work with plate mount, as you'd need something to stabilize/lock it in.
Why not make the PCB accept pin inputs as the connection for the switch, like the controller on Filco's and such whereas it just pushes in, why not do something along the lines of that? Sure it'll make the profile of the entire board a bit larger, but it'd be sweet to just pop a switch off and throw another one on.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline AcidFire
    • Axios - The Open Source Modular Ergonomic Keyboard
« Reply #201 on: Tue, 16 July 2013, 16:05:21 »
That's pretty much what I had in mind, only the design floating around in my head shouldn't increase the board thickness anymore than what the pins currently stick out for. Once I've got my first batch up on kickstarter I plan to put more time into this.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #202 on: Tue, 16 July 2013, 21:02:44 »
Liking the idea.
BTW, another big HTTYD fan here :D
Offline AcidFire
« Reply #203 on: Thu, 18 July 2013, 03:28:38 »
So while I check the tracking on my PCBs every 5 minutes, the samples from SP came in, and I got a couple of caps into the laser for testing:
After playing with my improvised rig, I'm definitely wanting to be able to do independent control of each side of the set up:
Next I'm gonna order some of the frosted keys from SP and see if I can do the vinyl dye at home w/ the same results. I also think I may have found a more affordable solution for the RGB LEDs, so there may be a surprise or two in the future ;)
« Last Edit: Thu, 18 July 2013, 04:41:20 by AcidFire »
Offline MOZ
  • Busy making stuff
« Reply #204 on: Thu, 18 July 2013, 06:36:15 »
These from the actual prototype or PS?
Offline AcidFire
« Reply #205 on: Thu, 18 July 2013, 09:42:30 »
These are from the actual key, with the color tweaked a bit since the photos were slightly washed out when I took them. But those are (with maybe a slight exception to the red) color accurate to the LEDs.
Also, a bit more details from the key caps:
The one on the left was my second attempt with aligning to the center of the key. On the right was my first attempt, as well as my first (the circles) and second attempt (the patterning) at lasering the sides with a rig I designed to do it.
Offline Thimplum
  • Master of all Ponies
« Reply #206 on: Thu, 18 July 2013, 10:06:09 »
Nice! You should make a Toothless keycap.
TP4 FOR ADMIN 2013
Offline CommunistWitchDr
  • >implying keyboards
« Reply #207 on: Thu, 18 July 2013, 10:15:57 »
Those look amazing. If this can be done with dyesub pbt (well, pbt/poly blend for the frosteds) then that would be even more amazing, mostly because it wouldn't just degrade with use like the laser ones will.
I wonder what a totally blank (or just non letter patterned) frosted would look like with that setup, seeing as that's what I would want to install personally.
Offline AcidFire
« Reply #208 on: Thu, 18 July 2013, 13:41:13 »
Get out of my head.
Offline Thimplum
« Reply #209 on: Thu, 18 July 2013, 15:33:23 »
Get out of my head.
NIGHT FURY! GET DOWN!
TP4 FOR ADMIN 2013
Offline AcidFire
« Reply #210 on: Thu, 18 July 2013, 16:01:22 »
Do you mean etched, or just 4 controllable RGB LEDs?
« Reply #211 on: Thu, 18 July 2013, 16:04:27 »
I just mean a blank frosted or frosted with like that hexagon pattern dyesubed over the whole cap in the 4 rgb led assembly.
Offline AcidFire
« Reply #212 on: Thu, 18 July 2013, 16:15:47 »
It's entirely possible, biggest issue right now is alignment between the sides but I have some plans to handle that, mostly with a jig w/ tighter tolerances.
Offline Merloobi
« Reply #213 on: Fri, 19 July 2013, 07:59:13 »
Wow what an incredible project. I'm extremely interested in buying one of these if/once you begin selling  ;D
Offline AcidFire
« Reply #214 on: Fri, 19 July 2013, 12:50:24 »
Awesome, glad to hear it :)
On a side note, I'm putting a website together for this and I'll be posting a survey & first round beta sign up later today or tomorrow. There are a couple of you who I've already marked for first round if you decide to sign up :)
Offline BlueByLiquid
« Reply #215 on: Fri, 19 July 2013, 13:09:14 »
I'm definitely a go
Offline AcidFire
« Reply #216 on: Fri, 19 July 2013, 18:46:42 »
Ok, I still need to finish the survey, but for those of you looking to apply for the first round of beta, you can do so here:
ErgoGP Beta v1.0 Application.
I'm currently looking for 10-20 people to participate in the beta on the first round.
« Last Edit: Fri, 19 July 2013, 19:24:19 by AcidFire »
Offline linziyi
  • The one with many questions
« Reply #217 on: Fri, 19 July 2013, 18:50:03 »
Link broken :S need a little fix :)
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline AcidFire
« Reply #218 on: Fri, 19 July 2013, 18:51:43 »
bah, fixed it. I blame friday :P
Offline Thimplum
« Reply #219 on: Fri, 19 July 2013, 19:10:01 »
It's still broken...
TP4 FOR ADMIN 2013
Offline Thimplum
« Reply #220 on: Fri, 19 July 2013, 19:10:53 »
http://www.multiplxd.com/ergogp/beta
I think that this is what he means.
TP4 FOR ADMIN 2013
Offline AcidFire
« Reply #221 on: Fri, 19 July 2013, 19:24:59 »
Ok, it's officially time to go home. yes thats the right one, I also fixed my own link.
Offline Thimplum
« Reply #222 on: Fri, 19 July 2013, 19:40:33 »
I should go home or you? I'm confused.
BTW, great looking site.
TP4 FOR ADMIN 2013
Offline AcidFire
« Reply #223 on: Fri, 19 July 2013, 19:46:59 »
I should, it's obviously been a long week >_<
Offline Thimplum
« Reply #224 on: Fri, 19 July 2013, 19:52:29 »
By the way, what exactly does "at cost" mean? If I signed up, how much would I be paying?
TP4 FOR ADMIN 2013
Offline AcidFire
« Reply #225 on: Fri, 19 July 2013, 19:58:07 »
that you'd be paying whatever it costs me to produce production units if I get that far. You aren't paying anything to participate in the beta.
Offline xman
« Reply #226 on: Fri, 19 July 2013, 21:39:28 »
Would it be possible to give a very rough ballpark
estimate as to the cost of a production unit?
You will not be held to it.
Also... a very rough time frame as to how soon
a production unit can maybe possibly
be in a beta tester's hands?
Just very rough estimates.
« Reply #227 on: Fri, 19 July 2013, 21:48:49 »
I'm currently looking at:
Case+Electronics = $120.00
Case+Electronics+Switches -or- Caps = $160.00
Case+Electronics+Switches+Caps = $200.00
Completely Assembled+Tested = $250.00
Depending on what kind of funding I get, I'm also looking to offer injection molded & anodized aluminum cases.
And a chance of being lower due to buying at cost.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #228 on: Fri, 19 July 2013, 23:02:35 »
Of course i filled out that beta signup form............lol
I am sorry i can't help with firmware/software but hopefully you would take someone that uses a keyboard 12-14 hours a day into consideration. just saying....
Offline AcidFire
« Reply #229 on: Fri, 19 July 2013, 23:16:33 »
Absolutely! At the end of the day I'm looking for better comfort and support for those of us who spend way too much time on a keyboard.
On a side note, did you hit submit after you filled it in? Your application hasn't shown up.
Offline Glod
    • YouTube Channel
« Reply #230 on: Fri, 19 July 2013, 23:27:47 »
yeah i hit submit for sure, hmmmm
Offline Larken
« Reply #231 on: Sat, 20 July 2013, 00:32:36 »
submitted. definitely interested in how this works out in typical usage.
| Ergodox #1 | Ergodox #2 |
Offline Thimplum
« Reply #232 on: Sat, 20 July 2013, 10:19:26 »
I submitted... has mine shown up yet?
TP4 FOR ADMIN 2013
Offline linziyi
« Reply #233 on: Sat, 20 July 2013, 10:23:50 »
 :) I think I am the first one, had mine show up?
Ducky DK9008G2 Pro
Offline Glod
    • YouTube Channel
« Reply #234 on: Sat, 20 July 2013, 11:16:30 »
i refilled out the form, hopefully you got it this time
Offline Kozu
« Reply #235 on: Sat, 20 July 2013, 11:31:24 »
I also filled out the form yesterday. Hope it went through.
I'm a software engineer, so yeah. So keyboards are essentially my money maker.
Offline Thimplum
« Reply #236 on: Sat, 20 July 2013, 12:45:23 »
Terrible keycap design is terrible. I made this in about 30 seconds:
TP4 FOR ADMIN 2013
Offline AcidFire
« Reply #237 on: Sat, 20 July 2013, 13:06:08 »
Yup, everyone's made it through now.
You sir owe me a new keyboard & LCD cleaning supplies lol
Offline Thimplum
« Reply #238 on: Sat, 20 July 2013, 13:10:52 »
Moral of the story: Don't drink anything while looking at my um... "artwork."
TP4 FOR ADMIN 2013
« Reply #239 on: Sat, 20 July 2013, 13:11:13 »
Acidfire,
Can u tell me if my application went through? I'm in a place with horrible Internet for several days and the form was acting funny?
Offline AcidFire
« Reply #240 on: Sat, 20 July 2013, 13:18:39 »
Acidfire,
I've only got one application without a username and that was a day or two ago, so you may need to try again.
« Reply #241 on: Sat, 20 July 2013, 14:51:28 »
Acidfire,
Hmm, maybe the form doesn't work on an iphone. I just tried again and when I agree and click complete it loads a screen where you can tell something is missing and the three text links, update, something and beta signup. Will try when I get to the real world.
Offline Thimplum
« Reply #242 on: Sat, 20 July 2013, 15:17:40 »
Ok now he's just scary.
TP4 FOR ADMIN 2013
Offline MattDarling
« Reply #243 on: Sat, 20 July 2013, 17:10:06 »
I've been lurking and watching this thread since last week, and just submitted my beta application. I was sold on the idea of making the thumb clusters more comfortable to use (I had to stop using my Kinesis Advantage because of that), but then you posted the thing with the laptop, and I was sold twice over.
Anyway, it's awesome to see another ergonomic keyboard project starting in Canada - now I won't have to pay an arm and a leg for shipping, lol. Regardless of whether I get a prototype model or a Kickstarter unit :)
Offline AcidFire
« Reply #244 on: Sat, 20 July 2013, 18:08:52 »
Canada FTW! Where in canada are you? NVM, its on your application -derp-
« Last Edit: Sat, 20 July 2013, 18:11:03 by AcidFire »
« Reply #245 on: Sun, 21 July 2013, 10:53:12 »
Acidfire,
Should we get a confirmation email? I just tired it from a computer and it seemed to work but no email. Thanks!
Offline MattDarling
« Reply #246 on: Sun, 21 July 2013, 19:14:18 »
Haha, yeah - at least I know you got the application :D I'm amazed at how quickly this is moving forward. Perhaps those lean startup folks were right after all...
I didn't get a confirmation for mine, either, fwiw :) And, apparently, mine did go through.
Offline AcidFire
« Reply #247 on: Sun, 21 July 2013, 21:11:15 »
Sorry, yes blue yours made it in, and thats a good point, I'll have to add in a confirmation email for extra clarity.
Offline AcidFire
« Reply #248 on: Mon, 22 July 2013, 11:04:07 »
I've never heard of this concept before, but I like it. Definitely along the same track I'm working on, it's cool that theres a name for it.
Offline AcidFire
« Reply #249 on: Mon, 22 July 2013, 12:20:13 »
Ok, a suggestion was made to me at work that I'd like to hear opinions about. Right now, this beta test is looking to cost me a fair bit of money to get the first units produced. I'm happy to shell out the cash because I think it's vital to the development to get user experience and see what needs to be changed, if anything. However, this will stretch my own finances a bit when I should be paying bills. Some of you have already offered to preorder the kits to help support the development, something that was extremely gratifying, but I didn't feel comfortable taking anyone's money until I had made it a bit farther. I've said in the beta applications that the boards would need to be returned at some point, mainly due to the cost for me, however I would like to do at this point is offer a compromise.
What I'd like to do is put up a small indiegogo campaign to cover the cost of production for 20 beta kits. These kits will be offered with & without switches, and each kit would come with frosted keycaps for the backlighting. Basically, I'm looking at roughly $100 without switches, and $150 w/ blue, clear or black switches. This means that the prototype is yours to keep, and you'll still be able to buy a kickstarter/retail kit @ cost when they become available. I'm also looking at offering 20-30 sets of the clear frosted keys (in DSA) as well for $40 to help with funding as well. Would anyone be interested in this option?
