Author Topic: Solder for Phantom  (Read 2644 times)
Offline Dgsbllx
Solder for Phantom
« on: Thu, 27 June 2013, 09:30:26 »
New to soldering so noob question  ;D
Was speaking to my neighbour about the phantom build, and mentioned I needed to do some soldering and was going to buy some and he gave me some solder;
Will this be alright for the phantom build?
Thanks in advance
edit; Should have asked in one of the threads rather than a new topic, sorry. Didn't even think about it  :-[
« Last Edit: Thu, 27 June 2013, 09:32:07 by Dgsbllx »
Offline Tranquilite
Re: Solder for Phantom
« Reply #1 on: Thu, 27 June 2013, 14:57:57 »
Should be just fine, though personally I prefer the stuff with lead in it.
Offline asura
  • not a duck
« Reply #2 on: Thu, 27 June 2013, 15:03:12 »
Which is illegal in the EU...
Err on my part - illegal on anything sold in the EU, as a component it can be sold, and you can use it for your own purposes, but re-selling once used in assembly becomes illegal...  Gotta' love the EU
Double edit... someone should really tackle the wikipedia page on solder - it doesn't go into hard soldering at all...
« Last Edit: Thu, 27 June 2013, 15:09:03 by asura »
Offline MJ45
  • HHKB Pro
« Reply #3 on: Thu, 27 June 2013, 16:55:25 »
That looks too heavy, you should get some around 0.032 dia. or less. Leaded is also easier to use it has a lower melting point.
Offline bazemk1979
« Reply #4 on: Thu, 27 June 2013, 17:13:40 »
looks like a thick wire, you would want 0.3 or 0.2mm solder wire
Offline Dgsbllx
« Reply #5 on: Fri, 28 June 2013, 10:45:38 »
Thanks a lot for the replies!
Offline oluf
  • formerly olaph
« Reply #6 on: Fri, 28 June 2013, 11:06:31 »
Check out the living soldering thread http://geekhack.org/index.php?topic=42824.0
...and EEVBlog, http://www.eevblog.com/
