Author Topic: Alps Appreciation Thread  (Read 3095082 times)
0 Members and 9 Guests are viewing this topic.
Re: Alps Appreciation Thread
« Reply #1350 on: Tue, 19 April 2016, 17:15:22 »
I'll have to give a more thorough review some time, but for now the M0116 can't be used as I don't have the converter. I can pretend to type on it (all the switches are exceptionally sturdy and smooth), but I plan on harvesting them for a Clueboard, so that's when I'll do my final thoughts!  :p
I think a Clueboard sounds like an excellent candidate to start your Alps journey (and a fantastic endgame choice as well; I know a lot of people like FC660s).
The S doesn't come with Alps, or does it?
I think the FC660 is Cherry MX and Topre only, but with skully's Clueboard PCB you can use Alps. Plus, fully programmable!
That's cool, didn't knew that.
So much to find out and to try still... I've only scratched the surface or so it seems.
Leave before it's too late!  :))
Offline iLLucionist
  • Topre is Love.
« Reply #1351 on: Tue, 19 April 2016, 17:17:48 »
It's too late already. I'm already browsing on classifieds, waiting for a nice deal. I'M LOST! Y U DO THIS GH
Offline E3E
« Reply #1352 on: Tue, 19 April 2016, 17:30:31 »
I started with blue Alps, and then the second switch I tried was Alps SKCM Orange on an AEK. I've always run along the more difficult to find switches and have stayed away from the most common ones, like SKCM White, Black, and Damped, though I do have those now. The only board-wide switch (switches that aren't just space bar switches) that I don't have is SKCM Cream, and I'm not all that interested in them, but I might go through some NeXT boards to find some eventually.
As people on DT call it, the Alps Vortex is ferocious and unforgiving! Beware!
Offline iLLucionist
  • Topre is Love.
« Reply #1353 on: Tue, 19 April 2016, 17:33:13 »
So Alps is your end-game I suppose? Never into MX / Topre?
Offline Mattr567
« Reply #1354 on: Tue, 19 April 2016, 18:37:16 »
I have always found the NeXT boards cool. Black Alps-made Doubleshots. Thicker than their dyesubs I believe.
I started with SKCM Black on a Alps MCL-101, then a V60 Matias Click, AEKII, Zenith Z-150, SGI Granite, then finally my FK-3001. I bought SKCM Oranges to swap my SGI. Kinda of a unique path, but done at the cheaply as possible. Never spent more than $70 on a vintage board. Not bad  ¯\_(ツ)_/¯
« Last Edit: Tue, 19 April 2016, 18:39:11 by Mattr567 »
IBM P77, SKCC Green, 1984
Offline pr0ximity
« Reply #1355 on: Tue, 19 April 2016, 19:24:13 »
It took a while for them to grow on me, but I think SKCL Greens are becoming a top contender for my favorite linear, and I rarely even type on them. My Zenith is sitting to the right of my desk while I've been IBM'ing it up since my USB adapter is at work on my Mini. Every once and a while I reach over and think to myself "damn, probably about time to bring the Mini home and the Zenith to work"
They really are just so smooth and have such a pleasant force curve and travel distance. I think my new lust is a brass-bottomed 60% with GMK-thickness ABS caps, SKCL Greens, and an acrylic plate. Sounds like I need to learn CAD...
Are there any really thick ABS ALPs-compatible caps out there? The ones on my Zenith are horribly thin.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #1356 on: Tue, 19 April 2016, 19:28:28 »
Alps themselves made some fairly thick ABS doubleshots. However, Honeywell-calibre Alps caps don't exist AFAIK.
I use my ZKB-2R at work, it's a great work keyboard even despite being linear :D .
Offline pr0ximity
« Reply #1357 on: Tue, 19 April 2016, 19:39:19 »
Yeah Honeywell-thickness would be extreme, GMK is a nice weight to me. I suppose SP's DCS is the modern standard then. Pity, maybe JTK will venture into ANSI ALPs territory in the future.
Offline jacobolus
« Reply #1358 on: Tue, 19 April 2016, 19:47:16 »
The thickest ABS “standard mount” Alps keycaps are the sculpted spherical ones from the mid-80s.
Some pics of the bottoms from Parak:
Definitely not as thick as Honeywell caps, or even Alps tee-mount caps, but pretty sturdy.
In general, Alps dyesubs are pretty thick. My favorites are the ones from a couple C.Itoh keyboards.
Here are some pics from HaaTa: https://www.flickr.com/photos/triplehaata/sets/72157663966300963/
The ones from Apple keyboards are also great though.
« Last Edit: Tue, 19 April 2016, 19:52:02 by jacobolus »
Offline Mattr567
« Reply #1359 on: Tue, 19 April 2016, 20:44:11 »
Ah, from old Canon typewriters. Those are cool :)
Here is a NeXT key
Offline E3E
« Reply #1360 on: Tue, 19 April 2016, 23:36:54 »
If you want the closest equivalent to GMK caps in the Alps world, try to find a later model FAME TH-5539, as these have some very convincing Cherry profile/clone key caps that look pretty much just like Cherry doubleshots. Only thing is that they come with a BAE and short right shift, so you might have to work some magic if you want to use ANSI with those caps.
Alps-made doubleshots and PBT are fine caps though, and I really enjoy typing on either example. As Mattr shows, they actually are quite thick, it's just that they do not have uniform thicknesses for each side so some sides can be somewhat thin while others are quite thick. I measured the DS caps with a caliper and compared them to GMK and they're very close aside from the thin side of the cap.
« Last Edit: Tue, 19 April 2016, 23:38:54 by E3E »
Offline iLLucionist
  • Topre is Love.
« Reply #1361 on: Wed, 20 April 2016, 04:34:30 »
Here is a NeXT key
Now THAT is a VERY Thick key! It must sound dead quiet or low pitched. Do you have a board with the whole set or the original NeXT keyboard?
Offline chyros
  • a.k.a. Thomas
« Reply #1362 on: Wed, 20 April 2016, 04:45:45 »
Alps doubleshots are cool, I've a board with some pretty funky ones on them you'll see sometime down the line ^^ .
Offline jacobolus
« Reply #1363 on: Wed, 20 April 2016, 06:32:20 »
No, the NeXT boards are pretty loud, like any non-damped Alps keyboard with ABS keycaps. If you want quiet, you should get an AEK II or SGI AT101.
« Reply #1364 on: Wed, 20 April 2016, 06:49:45 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #1365 on: Wed, 20 April 2016, 13:35:23 »
I have a next, and while it is quieter than some other boards, it is definitely much louder than a damped keyboard.
Offline alienman82
« Reply #1366 on: Wed, 20 April 2016, 13:43:36 »
removed.
« Last Edit: Thu, 01 March 2018, 15:29:10 by alienman82 »
Offline Mattr567
« Reply #1367 on: Wed, 20 April 2016, 18:59:12 »
Bought 4x IBM 5140's. I will be building up a Leeku ALPhas L3 pcb in AEK layout for my LZ-GH soon. Can't wait to get in the PCB's :thumb:
How? Did you just buy the boards? How much was it?
It had to happen.
Party On!
http://www.ebay.com/itm/leading-edge-keyboard-dc-2014-In-Original-Box-/301934966798?
Oh, here we go. This is gonna be a fun ride ;)
Offline alienman82
« Reply #1368 on: Wed, 20 April 2016, 19:08:13 »
removed.
« Last Edit: Thu, 01 March 2018, 15:28:22 by alienman82 »
Offline E3E
Offline Delirious
« Reply #1370 on: Wed, 20 April 2016, 20:41:58 »
all from eBay seller.  Prices ranged from $20-65 each :) :thumb:
I saw on reddit you recently picked up a Sharp typewriter. How did it turn out? Delicious Green Alps or no?
Offline alienman82
« Reply #1371 on: Wed, 20 April 2016, 20:43:15 »
removed.
« Last Edit: Thu, 01 March 2018, 15:28:18 by alienman82 »
Offline alienman82
« Reply #1372 on: Wed, 20 April 2016, 20:46:52 »
removed.
« Last Edit: Thu, 01 March 2018, 15:28:15 by alienman82 »
Offline Venatorious
  • Gotta Start Somewhere
« Reply #1373 on: Wed, 20 April 2016, 21:57:20 »
Guys, these caps may be ABS but they are really sweet.  http://www.ebay.com/itm/Acer-6311-KW-Mechanical-Vintage-Keyboard-/301933595824?hash=item464ca50cb0:g:irYAAOSwD2pXFUed
I love the texture and feel of them.  They are also dyesub too!  I recommend these as a great cheap set of ANSI alps caps.
Offline alienman82
« Reply #1374 on: Wed, 20 April 2016, 22:01:55 »
removed.
« Last Edit: Thu, 01 March 2018, 15:28:11 by alienman82 »
Offline Hak Foo
  • Make America Clicky Again!
« Reply #1375 on: Wed, 20 April 2016, 22:59:28 »
The 6511 has similar caps, except the stabilizers are weird on larger keys and fit nothing.
Overton130, Box Pale Blues.
Offline Mattr567
« Reply #1376 on: Thu, 21 April 2016, 00:30:29 »
It had to happen.
Party On!
Yeeeeah, noooo.
Funny thing too, I was watching Scream last night, and noticed the same typewriter at the school just before this guy gets slayed :thumb:
Nice find. Not all those use SKCM's btw. I've searched craigslist for these and have come across Green SKCC's and Tactile SMK's  (inverse cross mount).
Nice!
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #1377 on: Thu, 21 April 2016, 00:34:18 »
Now that I finally got my desktop running again, I needed a new board to use with it. Chose one of my Sharp X68000s and I have to say that SKCL Greens grow on you the more you use them. I've never been much on linear but these are great and they are so much quieter too. Unfortunately I'm missing a key so I had to use one of my Tai Hao caps until I find a more suitable replacement.
Bonus PC picture:
Offline frogthejam19
  • Good Vibrations
« Reply #1378 on: Thu, 21 April 2016, 20:38:10 »
Waiting on KBP v60 blue Alps boad. :-X :-X After 5 months of painful waiting. The pain is becoming unbearable. Going to invest in some nice sleeved usbs and a nice carry case.
"All is Well"
Offline alienman82
« Reply #1379 on: Thu, 21 April 2016, 20:58:40 »
removed.
« Last Edit: Thu, 01 March 2018, 15:27:39 by alienman82 »
Offline rand77
« Reply #1380 on: Fri, 22 April 2016, 02:49:48 »
I'll just leave this here.   Wonderful switches, really prefer these to MX (except Zealios).
Offline chyros
  • a.k.a. Thomas
« Reply #1381 on: Fri, 22 April 2016, 03:18:54 »
Are they salmons? The white balance seems a bit off in the picture? Nice board though :) .
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #1382 on: Fri, 22 April 2016, 09:22:07 »
Looks like they might be Amber.
Offline njbair
    • nickbair.net
« Reply #1383 on: Fri, 22 April 2016, 09:43:07 »
They're salmon. He cross-posted this from the Alps Party thread. https://geekhack.org/index.php?topic=75491.msg2148260.msg#2148260
My boards:
Offline rand77
« Reply #1384 on: Fri, 22 April 2016, 09:59:27 »
They are Salmons harvested from an Apple Standard Keyboard (M0116).
Offline chyros
  • a.k.a. Thomas
« Reply #1385 on: Fri, 22 April 2016, 10:04:09 »
Cool, and you prefer Zealios to them? Damn, sounds like I'm going to have to give those a try sometime Oo .
Offline Touch_It
« Reply #1386 on: Fri, 22 April 2016, 12:24:36 »
HMM.  I love my salmon switches. (typing on them right now).  It sounds like I may have to get a hold of some zealios as well at some point.
Offline guster11
« Reply #1387 on: Fri, 22 April 2016, 13:10:48 »
I asked the seller first to confirm, but yes.  67 green alps for $25 shipped :)
Will need more parts to make a 60%
What type of old typewritters have alps switches? I'll have to keep an eye out for them clearly at that price. Dying to get some green alps too, that's a great buy
Offline sacratoy
    • Twitch
« Reply #1388 on: Fri, 22 April 2016, 14:36:04 »
I love my Omnikey 102.
Poker II
Offline guster11
« Reply #1389 on: Fri, 22 April 2016, 17:11:58 »
Northgate keyboards are honestly the best keyboards I ever owned, I really regret selling my mint omnikey ultra. I've never has a 102 though, what's that touch button fucntion row like?
Offline E3E
« Reply #1390 on: Fri, 22 April 2016, 17:16:00 »
I think that is just a label for people who need to jot down what the function keys do for particular programs or something.
Offline guster11
« Reply #1391 on: Fri, 22 April 2016, 17:21:43 »
haha wow I always though those were the old school plastic cover push buttons....couldn't have been more wrong
Offline E3E
« Reply #1392 on: Fri, 22 April 2016, 17:23:45 »
Yeah, you made me have to do a double-take on that and look up some info, haha. It does seem that it's just a label though, but I totally see how you might think that.
Offline Venatorious
« Reply #1393 on: Fri, 22 April 2016, 18:05:20 »
I think there are actually holes in the plate under the cover.  In one version of this board there are more function keys where that cover is.
Offline Mattr567
« Reply #1394 on: Sun, 24 April 2016, 00:19:50 »
All this talk of SKCM Orange made me bring out my SGI Granite, which I swapped w/ SKCM Orange jacked from a AEK a while back. Forgot how good these were. As a result I cleaned all the switches today. Very tedious but worth it. Thinking about it, I have cleaned about 400 Alps switches at this point :eek:
BTW the reason I didn't just buy a AEK is because of the changing of the home row bumps to D/K. It always screwed me up on my old AEKII. Moving the keycaps around just aggravated me for whatever reason.
« Reply #1395 on: Sun, 24 April 2016, 00:27:32 »
My M0116 was the first time I had homing bumps on D and K. Had no idea that was a thing, and took me a while to get adjusted.
Offline Mattr567
« Reply #1396 on: Sun, 24 April 2016, 01:11:01 »
I eventually got adjusted to my old AEKII as well, but my typing speed was still affected.
Offline chyros
  • a.k.a. Thomas
« Reply #1397 on: Sun, 24 April 2016, 15:29:22 »
Btw you guys are going to see something pretty cool in two weeks or so, I think :D .
Offline Mattr567
« Reply #1398 on: Sun, 24 April 2016, 17:56:49 »
Yay! Always look forward to your videos.
Offline alienman82
« Reply #1399 on: Sun, 24 April 2016, 17:58:24 »
removed.
« Last Edit: Thu, 01 March 2018, 15:26:21 by alienman82 »
