Author Topic: Alps Appreciation Thread  (Read 3096254 times)
Offline jacobolus
Re: Alps Appreciation Thread
« Reply #1550 on: Wed, 11 May 2016, 12:11:20 »
Dang. I think 55g Topre is actually too light.  :eek:
Slightly off topic, but if I find the above true and think that 65g Zealios are way too light, will 78g Zealios be too much?
Also, Orange Alps are just about perfect; what's the bottoming out force on those?
55 g on a relative scale is not stiff at all xD . Sure it might be too stiff for some people, but many switches are stiffer than that, sometimes considerably more so :) . Most Alps switches are fairly stiff.
These “grams” numbers are misleading. 55g Topre feels about as stiff in practice as MX clear, brown Alps, or a Model M, in my abstract mental image of these switches. The Model M is higher peak force, but the catastrophic buckling of the spring changes the subjective feel dramatically.
Once there are reliable force curve measurements taken of real switches on HaaTa’s machine, we can try to come up with some better metric for “how much work does the switch take to actuate/fully press”, “how tactile is it”, “how painful is it to mash to bottom-out”, etc.
In practice, orange Alps is pretty comparable to 45g Topre IMO, though I don’t own any Topre keyboards, so that’s just going off vague memory.
65g Zealios (that number is based on bottom-out force, right?) are probably fairly comparable to orange Alps. 78g Zealios is going to be closer to black Alps switches or MX clear, I’m guessing. [I haven’t tried Zealios, I could be off base.]
« Last Edit: Wed, 11 May 2016, 12:23:46 by jacobolus »
Offline ipreferpie
« Reply #1551 on: Wed, 11 May 2016, 12:30:13 »
So I'm lucky enough to score several SKCM Blues and SKCM Browns. [...] If I generally have enojoyed 65g Zealios, 55g Silenced Topre and 62g Aristotle/Zealio hybrids, does anyone have a good suggestion which ones to use? I know tactile is quite different from clicky, but I'm worried that browns are stiff (I'm not a fan of MX Clears due to stiffness). Or should I consider SKCM Oranges instead?
55g Topre is also a very stiff switch. Personally I find brown Alps, 55g Topre, and MX clear to all be too stiff for my taste, and I don’t particularly enjoy the “rounded” force curve of Topre, brown/lime Alps, or Burroughs torsion spring switches. YMMV.
Good condition orange and blue Alps switches are both really fantastic switches if you want something lightly–crisply tactile, two of the most enjoyable typing experiences. You can’t go wrong with either of those. The blue ones in particular are IMO the most “elegant” sounding clicky switch you can find. If you want something a bit snappier, then white Alps switches and SMK clicky switches are also great.
Looks like I might have to build 2 alps boards in that case! For me, the topre 55g feels wonderful to type on but it does get tiring for long sessions.
In terms of sound is the Matias Quiet Click or SKCM Orange quieter than the Browns?
Offline jacobolus
« Reply #1552 on: Wed, 11 May 2016, 13:42:15 »
Orange and brown Alps switches will both be pretty loud at bottom-out, though exactly how loud depends on the case construction, what kind of table you set your keyboard on, etc.
Matias quiet switches are much quieter.
Offline klennkellon
  • I like bottoming out
« Reply #1553 on: Wed, 11 May 2016, 14:31:03 »
Matias Quiet Click are dampened tactile switches, and are among the quietest mechanical switches.
ALPS in general are really loud, even their non-clicky switches can be louder than some clicky switches.
Offline eohmiller
« Reply #1554 on: Fri, 13 May 2016, 16:24:50 »
The QCs seem to be the quietest in my opinion. They have a pretty hefty tactile feedback too.
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
« Reply #1555 on: Fri, 13 May 2016, 16:53:45 »
Just got my KBP V60 Matias Clicky nice little board and i'm digging the switch.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline NewbieOneKenobi
« Reply #1556 on: Sat, 14 May 2016, 08:50:12 »
Some time ago my best pal asked if I didn't have a spare keyboard, as he urgently needed something for his mum, a retired GP doctor. So I said LOL, okay, but it's gonna be oooold. There's a whole box of them old Dells, if a key doesn't work or something like that just come back and pick another one, just can't guarantee it won't be a particularly bad shade of yellow. He didn't come back, and the 'board supposedly is great. Also gave one of them to a Ph.D. student in literature and another to a coder. That means I should still have seven left. Ironically, while I appreciate the uncommon speed you can type on them with (compared to anything else, include blue Majestouch), I somehow can't use one myself. I worry about missing characters if I don't realize something's odd with them, and as a professional translator I would face a lot of disproportionate hate over a typo or missing plural or something else like that.
« Last Edit: Sat, 14 May 2016, 08:52:19 by NewbieOneKenobi »
Offline jacobolus
« Reply #1557 on: Sat, 14 May 2016, 09:40:03 »
The contact mechanisms in complicated Alps switches are actually much more robust and better engineered (over-engineered?) than the contact mechanisms in Cherry MX switches. You’re pretty unlikely to get typos from switch chatter if you press the switches past the tactile point, unless there’s some damage to the keyboard circuitry. (I suppose it’s also possible for the metal leaf spring that presses the contact down to get bent out of shape, but that’s unlikely to happen without some kind of serious keyboard abuse.)
Offline Mattr567
« Reply #1558 on: Sat, 14 May 2016, 11:51:10 »
Thats cool. Dell AT101/W's I assume? If they love SKCM Black just wait until they try SKCM Blue or Orange.
IBM P77, SKCC Green, 1984
« Reply #1559 on: Sat, 14 May 2016, 17:02:45 »
Plain old black 101/202W's, yeah. Some preceding Win 95 (no Win key), some not, probably all of them at least 20 years old. I bought like 10 of them for 75 bucks or something, in Polish currency. I don't think I've literally tested them all, but some probably still have all keys in order. I once ordered blue Alps, from a fellow Geekhacker, but they didn't arrive. What a massive pity.
Offline Mattr567
« Reply #1560 on: Sat, 14 May 2016, 18:08:10 »
Do any of them use SKCM Salmon?
Offline E3E
« Reply #1561 on: Sat, 14 May 2016, 18:16:27 »
Perhaps a better question would be if any are US made and have the original Dell logo on them as opposed to being made in Taiwan and and/or having the new Dell logo. :P
Offline Mattr567
« Reply #1562 on: Sat, 14 May 2016, 19:20:14 »
Courtesy of E3E: Two new switches confirmed SKCL Amber and SKCL Brown Lock! Will be adding these to the wiki.
« Last Edit: Sat, 14 May 2016, 19:22:42 by Mattr567 »
Offline jacobolus
« Reply #1563 on: Sat, 14 May 2016, 19:39:36 »
These are both from the Gold Star factory in Korea, right?
Offline E3E
« Reply #1564 on: Sat, 14 May 2016, 19:46:35 »
Yes.
Offline Venatorious
  • Gotta Start Somewhere
« Reply #1565 on: Sat, 14 May 2016, 20:56:39 »
I really really like the way that amber looks...
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #1566 on: Sat, 14 May 2016, 21:42:17 »
Is there a source for anymore of those switches? I just want one to add for my collection.
Offline jacobolus
« Reply #1567 on: Sat, 14 May 2016, 22:39:10 »
Maybe try to find a Korean auction site?
« Reply #1568 on: Sat, 14 May 2016, 22:43:30 »
What do they feel like?! So exciting :D. I would love to just try those switches out!!
Offline alienman82
« Reply #1569 on: Sat, 14 May 2016, 23:05:17 »
removed.
« Last Edit: Thu, 01 March 2018, 15:12:46 by alienman82 »
Offline jacobolus
« Reply #1570 on: Sat, 14 May 2016, 23:46:04 »
Seems like the linear ones should be like other linear Alps switches (are the springs similar to green SKCLs?) and the locking ones should be pretty much the same as other Alps lock switches.
Offline E3E
« Reply #1571 on: Sun, 15 May 2016, 10:54:40 »
Well, the sliders for these switches have symmetrical notches on each side like all of the older linear switches and unlike SKCL Grey and SKCL Yellow.
Based on what I've tried, I'd say the switches weights go like this:
Green > Yellow > Brown & Cream (practically identical feel) > SKCL Grey & SKCL Amber.
There's also SKCL Heavy Green, which I just tried out and compared to the others. It seems to be around the same weight of Alps SKCL Brown and Cream.  Like Jacobolus said, the Brown SKCL Lock is pretty much just a normal SKCL Lock with a different colored slider.  They feel the same. :)
I think SKCL Amber (formerly known as taxi yellow) was known about though. I believe it can be found in some old SKCL Green boards as well.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #1572 on: Sun, 15 May 2016, 11:36:38 »
Uhhh, I'm assuming you mean it the other way around? xD
Offline Mattr567
« Reply #1573 on: Sun, 15 May 2016, 12:36:58 »
Where did you get the SKCL Heavy Grey from?
Offline alienman82
« Reply #1574 on: Sun, 15 May 2016, 13:21:12 »
removed.
« Last Edit: Thu, 01 March 2018, 15:12:43 by alienman82 »
« Reply #1575 on: Sun, 15 May 2016, 14:16:02 »
Hmmm… this is going to make me like a n00b (and for good reason), but I didn't actually check all of them. I simply assumed all of them would be blacks, as coming from the same source at the same price (post-leasing boards), and they felt exactly the same in touch all of them, but if they have different production years and slightly different layouts, they might as well use different switches too. Gotta check.
For now, as I recall, all of them have the new logo, while salmons should have the old.
« Last Edit: Sun, 15 May 2016, 14:26:58 by NewbieOneKenobi »
Offline E3E
« Reply #1576 on: Sun, 15 May 2016, 14:27:51 »
It came from a practically new ADDS 1010 terminal keyboard, but I received only individual switches as I made a trade for them, trading some SKCM Blues out of a DC-2014 for them.
The SKCL Heavy Green had "lipstick" on the rim of its slider, I suppose to denote that it was different. It was some sort of waxy pigment and has since rubbed off.
Here's the album from the original owner of the ADDS keyboard: http://imgur.com/a/vq9iQ
I meant from lightest to heaviest. :D These are from what I've tried, but I know there a few more esoteric linears that have very heavy weighting like the double action and the heavy grey.
To make it easier on yourself, just look out for the beige-cased ones with the OLD Dell logo on them. Out of these, only the ones made in the USA will have Salmon Alps. You can check this by looking at the FCC ID label on the back of the keyboard.  :thumb:
« Last Edit: Sun, 15 May 2016, 14:29:44 by E3E »
Offline BlueNalgene
« Reply #1577 on: Sun, 15 May 2016, 21:27:08 »
Just finished my 60% with custom cut and painted plate.  Had to do some rework with hasu's pcb as the spacebar isn't supported.  Luckily it all worked out nicely:
I like those caps.  What case is that?
Offline alienman82
« Reply #1578 on: Sun, 15 May 2016, 21:27:46 »
removed.
« Last Edit: Thu, 01 March 2018, 15:12:32 by alienman82 »
Offline E3E
« Reply #1579 on: Sun, 15 May 2016, 21:34:14 »
ziptyze plastic 3d printed case
Now that I think about it, dude... If you could get a high profile case that's the same height of the blockers and colored in the same shade of grey, it'd give your keyboard a very sick retromodern aesthetic.
« Last Edit: Sun, 15 May 2016, 21:36:04 by E3E »
Offline alienman82
« Reply #1580 on: Sun, 15 May 2016, 21:35:08 »
removed.
« Last Edit: Thu, 01 March 2018, 15:12:30 by alienman82 »
Offline NightCabbage
  • I don't like Cherry keys!
« Reply #1581 on: Mon, 16 May 2016, 02:40:06 »
Quick question...
I'm thinking about buying either the PC version of  the Matias Tactile Pro or the Quiet Pro.
I like the idea of the Quiet Click keys not making massive amounts of noise, but I'm worried that the tactile feel of the keys would be compromised to achieve this.
How do I choose between the two, without having the chance to try them out?
Also, there are no other (full sized) keyboards on the market with ALPS-like switches, are there?
Offline need
« Reply #1582 on: Mon, 16 May 2016, 04:29:08 »
Quick question...
It definitely feel less tactile than vintage ones, say salmons and blacks which are basically the maximum tactility I can bear. Quiet clicks feels shallower and softer to type, which is pleasant in its own right. It feels bouncy to type on.
You really have to try them out for first hand experience, and vintage keyboards are a good way to do that, as you can sell them without losing much or even any money at all. It will takes more time than buying things off the shelf though.
Offline zombimuncha
« Reply #1583 on: Mon, 16 May 2016, 04:48:02 »
Quick question...
keyboardco.com will sell you individual Matias switches, with somewhat reasonable shipping from the UK. Then you'd just need to find a keycap or two from somewhere.
Offline njbair
    • nickbair.net
« Reply #1584 on: Mon, 16 May 2016, 06:46:39 »
Quick question...
Buy the Quiet Clicks. They are wonderful switches, and I think they feel even better than the clicky ones.
My boards:
« Reply #1585 on: Mon, 16 May 2016, 09:53:59 »
I wasn't able to remove a keycap safely, but all of them had the new logo and GYU numbers (not GYI), so according to this, they should all be blacks. There is some difference in feel between older and newer ones. Newer ones are crisper but rougher, older ones more similar to newer Model M's and a bit thocky — or was it the other way round? Probably not enough to feel like a separate type of switch but not entirely the same either.
Offline chyros
  • a.k.a. Thomas
« Reply #1586 on: Mon, 16 May 2016, 10:09:48 »
The '97SK version came with pine black Alps which are MUCH better than the later bamboo ones used in the '95SK and '90SK. They're really nice switches, much closer to salmon and orange Alps than to bamboo blacks. It even includes a steel weight to make it heavier, which wasn't present on GYI Bigfoots nor on the '90SK.
Here's a video review I made on it:
« Reply #1587 on: Mon, 16 May 2016, 18:58:33 »
Oh that's interesting to hear!
So they make less of a click sound, but still have a good tactile feel to them?
Offline chyros
  • a.k.a. Thomas
« Reply #1588 on: Mon, 16 May 2016, 19:23:18 »
They make no click as they're actually tactile switches; the Quiet Click name is a poorly chosen, misleading name. Due to the way Alps tactile and click leaves work, tactile switches are less tactile than clicky ones. Matias appears to have slightly compensated for this, though.
Offline supamesican
« Reply #1589 on: Mon, 16 May 2016, 19:36:55 »
Got my fk-2001 with alps.tw Type T1 white alps clones. Holy crap they are nice! Not quite buckling spring nice but still even better than I was expecting.
Offline FoxWolf1
  • 154
« Reply #1590 on: Mon, 16 May 2016, 19:37:38 »
Am I right in recalling that the Quiet Click switches are (more or less) a descendant of the old simplified black ALPS?
If so, I may have to pick up a keyboard with them sometime. Heard a few too many complaints about MQP quality relative to the price, though, and as someone who uses a lot of rollover, being limited to 6KRO is a pretty big turnoff. Ah well-- hopefully more manufacturers will adopt them in the future.
Offline chyros
  • a.k.a. Thomas
« Reply #1591 on: Tue, 17 May 2016, 02:29:20 »
they're closer to dampened Alps than black ones. Dampened Alps aren't for everyone, but many still enjoy them.
Some clone types are much better than others, T1 and OA2 are much closer in construction to real Alps than others, making them feel quite like Alps, just a bit lighter. I've found them to be pretty good :) .
Offline Mattr567
« Reply #1592 on: Tue, 17 May 2016, 22:46:10 »
I know this is a Alps thread, but I gotta say, worn in MX Blue stems in a old G80 w/ thin Cherry PBT is a amazing combo. I hate new MX. The stems are from a Ducky Shine 2, plus the orignal MX Browns were worn in as well, so the orignal contacts on top of everything are also worn.
Thin PBT makes the switches feel nice and light and lively, in a good way. I had to put in a couple new switches to fill a couple gaps (ended up putting them in the insert/end/pgupdown/ area so I will almost never use them) The difference is real, and I mean it. No 'vintage' black bull****. The new stems are quieter and feel much more dampened. Worse imho.
Or maybe Cherry's quality has gone down in the last couple years, who knows :p All I know is that this board feels amazing coming from what the normal expectation for MX is.
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #1593 on: Wed, 18 May 2016, 01:44:13 »
Burn the heretic  ;D
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline Mattr567
« Reply #1594 on: Wed, 18 May 2016, 09:35:08 »
Burn the heretic  ;D
Lol. But it is great. Funny how you have to go to such great lengths to properly enjoy MX. ALPS is always good!
Offline alienman82
« Reply #1595 on: Wed, 18 May 2016, 12:52:57 »
removed.
« Last Edit: Thu, 01 March 2018, 15:11:36 by alienman82 »
Offline E3E
« Reply #1596 on: Wed, 18 May 2016, 14:00:22 »
Put some interesting non-sculpted cylindrical caps from a typewriter onto my Hammer Alps Eagle.  They're actually pretty pleasant to type on since the case has a natural incline, but it's just a shame that the mods don't fit with the profile.
« Last Edit: Wed, 18 May 2016, 14:05:35 by E3E »
Offline alienman82
« Reply #1597 on: Wed, 18 May 2016, 14:06:46 »
removed.
« Last Edit: Thu, 01 March 2018, 15:11:23 by alienman82 »
Offline S1llyC0ne
« Reply #1598 on: Thu, 19 May 2016, 00:42:38 »
Yes !
Yes yes !
Yes ! Yes ! Yes !
Sent from my A0001 using Tapatalk
Offline drevyek
« Reply #1599 on: Thu, 19 May 2016, 06:55:40 »
I've been looking around for the different typewriters that used alps caps- which one did you harvest from? those caps are really attractive!
I've got an SGI case and plate and PCB, but no switches or caps :( I think it has an offset capslock, so I need to get a set with one, or else it'll be wonky as all hell.
I love the Orange Alps on my M0116, but sorta wish they were a bit heavier- are there any springs available for alps to make them a bit heavier?
