Author Topic: What Keyboard Are You Using Now?  (Read 5248611 times)
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
Re: What Keyboard Are You Using Now?
« Reply #5350 on: Mon, 24 April 2017, 18:50:55 »
Got an anodized aluminum case in for my POK3R. I like it a lot. Besides adding a little extra weight it and looking better it seems to have made the keyboard a little quieter. Can't really complain about that. I like the new sound!
I have to ask, the Pok3r comes stock with an aluminum case, why replace it?
It's a much better case that also sits flat. Great for DSAs. The POK3R cases are lighter and painted. It's a pretty 'big' upgrade, actually. I'm surprised.
Hmm...Never would have considered it since the stock case is one of the pok3r's best features IMO.  May give it a looksie more now.
Cheers
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
Offline TheRightHand
« Reply #5351 on: Tue, 25 April 2017, 06:58:54 »
I'm using a Ducky Shine 6 brown switch , best keyboard i have ever owned , i got it from http://mechkeyboards.eu/
« Reply #5352 on: Tue, 25 April 2017, 07:09:18 »
Actually considering adding one of the newer Ducky's to my collection since they finally switched to Micro USB and fixed the iffy port quality.  Been considering a new MX Blues TKL anyways to use when the wife is not around to scream about the click noise.
Offline Erikdayo
« Reply #5353 on: Tue, 25 April 2017, 09:38:17 »
Cheers
Mmm. Like I said, I was a bit surprised as well. I expected it to be heavier and allow the keyboard to sit flat if I wanted. Wasn't really expecting the change in sound, but I am happy with it.
Offline Lazylewis
« Reply #5354 on: Wed, 26 April 2017, 03:56:09 »
SA with MX greens. I don't like the combo. Feels cheap and noisy... What's good with SA?
166955-0
Offline PlastikSchnittstelle
« Reply #5355 on: Wed, 26 April 2017, 04:57:49 »
166958-0
pok3r with mx-clears
gmk dolch iso german
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #5356 on: Wed, 26 April 2017, 23:20:46 »
Every time I go back to this thread, I keep saying the same thing!
The same one as before!
« Reply #5357 on: Wed, 26 April 2017, 23:24:44 »
Iv'e always said the following about SA
It is one of the best looking keycap profiles out there, but I would never want to type on it long term.
Give me thick PBT anyday
Offline Prelim
« Reply #5358 on: Thu, 27 April 2017, 04:51:39 »
where did you get those Esc/ISO enter/spacebars pack?
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline Erikdayo
« Reply #5359 on: Thu, 27 April 2017, 12:11:54 »
welp. These are my 2 POK3Rs. Don't have any other keyboards anymore besides the ones that haven't sold. And yea, they're basically identical outside of the keycaps. The Cherry profile one is tilted and the DSA one is flat.
« Reply #5360 on: Thu, 27 April 2017, 12:59:23 »
Right now using the oddest named keyboard I have ever seen.
James Donkey 619 TKL W/ Gateron Blues and yellow backlighting.
Offline iLLucionist
  • Topre is Love.
« Reply #5361 on: Thu, 27 April 2017, 15:56:57 »
Switching between KUL ES-87 with MX Clears and 87U 55g. I can't decide what I like most.
Offline Moistgun
  • Slippery When Wet
« Reply #5362 on: Thu, 27 April 2017, 16:21:34 »
HHKB Silent and a year of lube at work
Mira with tuned 67g pinks at home
made it to my resting place
« Reply #5363 on: Thu, 27 April 2017, 16:35:45 »
from this group buy:
https://www.computerbase.de/forum/showthread.php?t=1601148
it was a german gb. ISO-DE layout.
felt strange always having to get the caps from overseas, although they are made right around the corner.
main set was dolch, the esc/enter/space was an addon.
Offline alfmoonspace
« Reply #5364 on: Tue, 02 May 2017, 12:20:29 »
HHKB PRO 2 TYPE-S on my mac and Realforce RGB with my windows machine.
« Reply #5365 on: Tue, 02 May 2017, 12:26:06 »
Ducky ONE W/ MX Blues, thus far I am quite impressed for being my first Ducky board.
Offline iLLucionist
  • Topre is Love.
« Reply #5366 on: Tue, 02 May 2017, 12:46:22 »
How's the Realforce RGB? Is it good?
Offline mBass
« Reply #5367 on: Tue, 02 May 2017, 12:55:57 »
Filco Majestouch 2 Ninja TKL / Shiba Inu hybrid.
Offline Aox
« Reply #5368 on: Tue, 02 May 2017, 13:29:50 »
Currently, Novatouch at work, and ANNEPRO at home!  Got a couple unicorns on the way, so will change it up soon, I believe.
-Aox
« Last Edit: Tue, 02 May 2017, 13:31:21 by Aox »
Offline iLLucionist
  • Topre is Love.
« Reply #5369 on: Tue, 02 May 2017, 13:41:03 »
-Aox
Those caps look awesome. Did you paint those yourself? I've never seen this set?
Offline Aox
« Reply #5370 on: Tue, 02 May 2017, 13:46:45 »
I got mine off of massdrop, but evidently they com from http://pheilcia.com/
-Aox
« Reply #5371 on: Tue, 02 May 2017, 16:02:58 »
To be honest, I don't have enough time with it to pass a good judgment call. I think the housing is cheap and the keycaps are garbage but if you need a full size board, its worth a look.
I use my HHKB 90% of the time :). After reading through this forum though, I might have the bug to try something else!
« Last Edit: Wed, 03 May 2017, 10:46:16 by alfmoonspace »
Offline mBass
« Reply #5372 on: Tue, 02 May 2017, 23:47:22 »
Yeah it's really nothing special until you do the shiba-inu mod.  (I was actually planning on posting the pic I took when I discovered how much of my shiba's fur had accumulated under the key caps since I got it, but it's kind of embarrassing.)  It's an ok keyboard though. Nothing amazing. I'm still a rookie. My last keyboard was a black widow and before that a really tired model-m. It can only get better from here.
Offline Lazylewis
« Reply #5373 on: Wed, 03 May 2017, 02:59:28 »
I could be wrong but I think Alf was talking about the RGB realforce, and replied to you by mistake. The filco majestouch 2 is one of my favourite boards.
« Last Edit: Wed, 03 May 2017, 03:01:29 by Lazylewis »
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #5374 on: Wed, 03 May 2017, 05:47:29 »
Offline mBass
« Reply #5375 on: Wed, 03 May 2017, 07:05:30 »
Derp that actually makes way more sense.
« Reply #5376 on: Wed, 03 May 2017, 10:47:38 »
Correct! My Mistake  :D
« Last Edit: Wed, 03 May 2017, 10:51:26 by alfmoonspace »
« Reply #5377 on: Thu, 04 May 2017, 17:03:18 »
167661-0
Ducky ONE with MX Blues and put the Starry Night Keycaps on it with Warmaster on Esc key.
Offline Ravahan
« Reply #5378 on: Fri, 05 May 2017, 15:30:01 »
This is my currently my daily driver, although I might change things up soon since the combination of the case and the SA keycaps is a bit too high for my taste
Offline mBass
« Reply #5379 on: Fri, 05 May 2017, 15:45:05 »
Wow I wouldn't normally be into something that flashy but I really like that.
Offline taylorswiftttttt
« Reply #5380 on: Fri, 05 May 2017, 20:08:26 »
removed
« Last Edit: Wed, 09 November 2022, 16:06:23 by taylorswiftttttt »
Offline OkinaDaikon
« Reply #5381 on: Fri, 05 May 2017, 20:37:22 »
I currently use an HHKB with GMK Carbon on MX Sliders at work and a B.face X2 with 67g Zealios.
They both treat me great! But I'm not sure if i like one more than the other. I'm tempted to bulld another 67g Zealio board  :D
Offline clankgy1
  • Formerly digifiend
« Reply #5382 on: Fri, 05 May 2017, 20:59:50 »
That looks great but a bit high.  What kind of case is it?
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
Offline Ravahan
« Reply #5383 on: Sat, 06 May 2017, 14:28:00 »
Thanks, I got the case on mechmarket but originally it is from this groupbuy: https://geekhack.org/index.php?topic=82149.0
Offline smithyithy
  • a l p s
« Reply #5384 on: Sat, 06 May 2017, 16:04:28 »
Using this tonight. ALU84 with 78g Zealio. First board I've actually built and soldered myself, a really good experience - the only mishap was breaking a diode on the PCB.. No problem as 2 separate people sent me replacement diodes in the mail out of their own pocket, amazing. Clipped and lubed the stabs too which feel excellent.
Anyway this is like 90% finished. The keyset is a Doubleshot ABS English / Cyrillic set I got from ebay combined with some Filco modifiers. I'm waiting for GMK Coniferous to go on this board then it will become my daily driver for the office. The spacebar is currently switchless as I wait for a ~120g spring to arrive with some other switches and parts for my MechMini. Also the black acrylic sandwich piece arrived cracked so a replacement is on its way. I've had a quick mess with BootLoader to program the PS2AVRGB, seems really simple to use, the default layer works well with a couple of tweaks, I've programmed RGB lighting control and volume controls to the right column - that'll make more sense when I have blank GMK caps in place. Otherwise I think the 75% layout is perfect for a daily board and for the price, the ALU84 is really good.
Added Fugu:
KBD75; Alps64 trio; some other stuff
Offline Moistgun
  • Slippery When Wet
« Reply #5385 on: Sun, 07 May 2017, 11:41:17 »
disone
Offline gnmar2723
« Reply #5386 on: Sun, 07 May 2017, 11:44:25 »
Added Fugu:
Dang, I saw those Cyrillic caps on ebay too, but I wasn't quick enough! They look awesome  :thumb:
Offline smithyithy
  • a l p s
« Reply #5387 on: Sun, 07 May 2017, 13:26:26 »
Thanks dude. I bought 2 full sets so I'm selling the spare set on MechMarket.
Offline gnmar2723
« Reply #5388 on: Sun, 07 May 2017, 14:46:55 »
Let me have first dibs on it :)
Offline smithyithy
  • a l p s
« Reply #5389 on: Sun, 07 May 2017, 17:27:02 »
Offline minh278
  • In life we will only fall, How far will we fall?
« Reply #5390 on: Sun, 07 May 2017, 23:20:53 »
Apologize for the potato picture quality.
167951-0
Mostly just use pressed key lighting on it. I think i'm weird as i actually enjoy the texture of the stock caps(smooth yet solid, closest to the other topre i have).
Keyboards:  Final Fantasy XI XIth Anniversary keyboard (topre 45g) | Realforce Rgb (topre 45g, Eva Noctilucous keyset) | Mionix Zibal 60 (mx black, Vortex doubleshot) | Greymark (white alps) | IBM model M (found in the trash!)
Offline ShishKabobJerry
« Reply #5391 on: Wed, 10 May 2017, 10:09:08 »
Using a Magicforce 68 with some good ol' PBT white blanks and a watster/sadster combo! It's simple, but it's mine! :D
Offline mnmlisme
« Reply #5392 on: Fri, 12 May 2017, 22:50:03 »
bought my POK3R RGB on April, fell in love with 60% size, but realized I still need the arrow keys. Sold my POK3R RGB and bought Saber68 gateron blue and XD60 gateron brown. Rabbit hole here I come!
XD60 (gat.black) | SABER68 (gat.blue) | VORTEX Core (cherry blue) | YD40 (gatistotle)
Offline ponoj
« Reply #5393 on: Sat, 13 May 2017, 09:49:38 »
Just finished it. Gateron Black with FaceW PCB, LaserGist plate, Royal Glam case, DSA keycaps. Couldn't be more excited to have it finished.
Can you share the dimensions of your LaserGidt plate?  Thickness and all. It fits so flush with this beautiful case
Offline PleaseBeMyFriend
  • formerly honsoo
  • reddit /u/PleaseBeMyFriend
« Reply #5394 on: Sat, 13 May 2017, 12:07:20 »
Currently using a 660C with hyperspheres, lubed, and JTK sliders in. Waiting on my ocean dolch and will probably be finished with it after that.
Offline edward789
« Reply #5395 on: Tue, 16 May 2017, 03:32:13 »
Cherry. I feel so good when I use it typing.
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #5396 on: Tue, 16 May 2017, 03:48:28 »
this will be my (new) daily drive  ;D
PCB: JC65
switch: Gatistotle + 65g springs
keycap: G20 Semiotic
case: just an acrylic sandwich case
« Reply #5397 on: Tue, 16 May 2017, 06:53:37 »
PCB: JC65
That's awesome! How does the G20 feel? I don't see alot of people use that.
  • Oblivion Knight
« Reply #5398 on: Tue, 16 May 2017, 08:27:11 »
I like the feel on these (or PBT caps in general)
these keys are flat so your transition between keys is... smoother, I think.
right now I'm having a hard time transition from "1.25u Fn, 3u Space" (my previous board) to "2.75u Space, 1.25u Fn"  :-\
I will get used to this soon, I hope.  :-[
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #5399 on: Tue, 16 May 2017, 08:31:33 »
I hear trash cans and reddit go well with SA  :thumb:
