Author Topic: What Keyboard Are You Using Now?  (Read 4150334 times)
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: What Keyboard Are You Using Now?
« Reply #7450 on: Fri, 24 May 2024, 23:27:25 »
IBM 1392595, Model M "Display Station" terminal keyboard, just a 1998 one from the Scotland factory, with a non-destructive internal Soarer Converter and a few replacement keytops. Go Gators.
Wow did not know about those model m numpad legends those are pretty cool. Gotta find myself a model m (but they are really overpriced in aus on like ebay cause there are not as common) cause I tried one at a meetup and it was really nice.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline wjrii
« Reply #7451 on: Sat, 25 May 2024, 09:17:38 »
Might be worth looking into a re-shipper, either formal or somebody you know in the states.  That terminal one required some cleanup and a converter, and obviously a few keytops were missing, but I got it shipped inside the US for under USD35.  I also got a PS/2 GE Medical keyboard, a very clean Unicomp from 2014, for less than USD45 shipped.  A lot of that value goes out the window for you, sadly, but slow USPS shipping might still be reasonably economical.
Pristine mainline Model M's are pretty pricy everywhere, though, with Unicomp setting the floor.
« Last Edit: Sat, 25 May 2024, 09:21:02 by wjrii »
Offline Rhienfo
« Reply #7452 on: Sat, 25 May 2024, 13:57:05 »
Yeah I probably will soon, it's just that I wanted to find one in aus because of quicker shipping times but it seems buying from the us might be the play.
I could also proxy a unicomp buckling spring board, I was looking at this split backspace one a while ago but shipping made me nope out but I might as well convert a AT model f and it would look a lot nicer.
https://www.pckeyboard.com/page/product/40PSA
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline scootbroer
    • Qazimodo Instagram
« Reply #7453 on: Mon, 10 June 2024, 09:37:48 »
I've been using this Vault 35 HHKB with Banana Milk Tactiles as one of my main boards for about a year now.
308371-0
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #7454 on: Mon, 10 June 2024, 14:45:52 »
308373-0
308375-1
Finally built my Matrix 8XV3.0 & man is it a nice board! I decided against using the weird alum skeleton plate it came with & got a full PP plate for it from Hype Keyboards. Which ended up pairing super nicely with the Gateron Deeppings I used, it definitely surpassed my expectations which were fairly high given the price of the board. The whole build is as follows, solder PCB, aftermarket full PP plate, hand lubed Gateron Deeppings, TX AP screw in stabs lubed with 205g0, plate gasket mounted, topped off with JTK Griseann.
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #7455 on: Thu, 13 June 2024, 18:32:21 »
For now I'm using a Varmilo VEM88 V2 with EC Rose switches.
So far it's the best keyboard I've had.
Very basic, but very good for me. I enjoy using it.
I'm using it just as it was from the store, but I'm looking at getting some custom keycaps. Not many to find for nordic ISO layout..
« Last Edit: Thu, 13 June 2024, 18:48:29 by ohm-ish »
Offline Rhienfo
« Reply #7456 on: Thu, 13 June 2024, 21:54:40 »
Very cute board.
Oooh this is very cool. Those skeleton plates suck pretty hard so yeah right decision to go for an aftermarket plate. I really like "the mainline" tkls because to me, they strike a good balance between being standard keyboards and being "matrix keyboards" in that over the top sense like that alice that was ridiculous lol. Still prefer the 1.2/og but can't go wrong with this.
Everyone has a starting point, glad to see you are enjoying it.
Might be out of your budget but there are gmk sets that have that support in stock right now from oblotzky and they are pretty cool. GMK is the gold standard for custom caps so you will get good quality stuff.
https://oblotzky.industries/products/gmk-cyl-norde
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline Flybeck
« Reply #7457 on: Thu, 13 June 2024, 23:18:47 »
Khora Prototype (65 top mount) - gmk, pp plate, mx2a purples
Offline InSanCen
« Reply #7458 on: Sat, 15 June 2024, 09:22:36 »
1391406. Rotated out the M13 to put in the "strip and clean" pile with the Model F AT, AT102W. Cherry G80 is likely up next. It's not as loud as a buckling spring, give the other half's ears a break.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline Rob27shred
« Reply #7459 on: Sat, 15 June 2024, 10:07:55 »
Very cute board.
Yep, I took one look at that monstrosity of a plate & was like "nope, nope, nope...". Also the PP plate really surprised me as to how much I like the feel & sound with it! I do agree with your take on Matrix's mainline TKLs. I've always prefered their more clean & subtle look vs Matrix's usual loud & in your face designs so the 3.0 was a no brainer to finally add a Matrix board to my collection. Don't get me wrong I do think a lot of Matrix's wild designs are very cool, but most of them are just too busy for my tastes.
Offline Evolurkeeb
« Reply #7460 on: Tue, 25 June 2024, 02:48:56 »
My boss give me an OG80, and I used it for my work
Offline mashie
« Reply #7461 on: Tue, 25 June 2024, 06:54:46 »
My new daily driver, Keychron Q10:
308581-0
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #7462 on: Tue, 25 June 2024, 15:23:06 »
Zensai65 with GMK CYL Tiramisu:
308585-0
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Lu_e
« Reply #7463 on: Sun, 30 June 2024, 09:30:19 »
F77
« Last Edit: Sun, 30 June 2024, 23:52:02 by Lu_e »
Just say NO to ABS keycaps
« Reply #7464 on: Mon, 01 July 2024, 15:13:03 »
I had one years ago and didn't like it, but my daughter (age single digit at the time) liked it because it was ****e.
"Technology can make us forget what we know about life."
- Sherry Turkle
Offline wjrii
« Reply #7465 on: Mon, 01 July 2024, 16:33:13 »
I am using this apple keyboard I thrifted. Can anyone tell me more about it and is it any good?
I remember being fond of the typing experience back when I would occasionally use one, but as somebody mentioned in another thread, the A1048's tended to get nasty over time if you're not religious about keeping them clean.  They are membrane technology, so nothing "special" in that sense, but the secret of this hobby is that if you like it and it keeps working, it's a good keyboard.  In the US, clean ones on eBay tend to go for about $20-$30 shipped, plus any tax.
Offline 5443
« Reply #7466 on: Sat, 13 July 2024, 06:52:10 »
Unicomp Model M
Filco Tenkeyless with Cherry MX Brown switches
Offline wjrii
« Reply #7467 on: Sun, 14 July 2024, 00:05:54 »
DIY "Hybrid-wired" no-stabs FRL 1800.  Matrix is a PCB, but that PCB is hand wired to the MCU, which also serves as the daughterboard.  3D printed case is loosely based on old beamspring boards and the M0110/HHKB. Akko SA-L and Box Navy.
Offline Subdromat
« Reply #7468 on: Mon, 15 July 2024, 06:50:24 »
Tada68 with Tofu65 case and undefined XDA caps, flimsy as it can be
Offline wjrii
« Reply #7469 on: Thu, 01 August 2024, 13:20:40 »
Litton Systems, Keyboard With Housing, KB-1. Circa 1997 or a little later.
Actually an Alphameric/Devlin sealed capacitive rubber dome inside a powder-coated sheet-steel case.   Mushy bottom out, but true NKRO, 3 pounds, and looks cool AF.
Offline Tseg
« Reply #7470 on: Mon, 09 September 2024, 11:40:10 »
My latest Group Buy, the Neson 810e showed up 3-6 months later than expected.   Luckily I have an inventory of other boards to keep me distracted.  In fact, I think I purchased 6 boards since initially ordering this one.  FRL exploded space bar.  Drop DCX Solarized dark.  Gateron Mini switches.   One more board on order, and I'm done.
« Last Edit: Mon, 09 September 2024, 11:43:16 by Tseg »
« Reply #7471 on: Mon, 09 September 2024, 18:22:56 »
That is a beauty !
- Sherry Turkle
Offline Scrambler_S
  • Sic semper tyrannis
« Reply #7472 on: Tue, 10 September 2024, 09:43:41 »
Wooting in a Holy
Offline Ghostpixel
  • I <3 Topre!
« Reply #7473 on: Sat, 14 September 2024, 17:47:26 »
Main desk keyboard: Swedish Topre Realforce 88UB 45g.
My workhorse almost every day since 2011 :D Dirty as heck but almost as smooth as the day it was new!
+ My new couch keyboard: Varmilo VA69 with gateron tealios. It replaces a Logitech G Pro.
« Last Edit: Sun, 15 September 2024, 10:40:33 by Ghostpixel »
Topre Realforce 88UB / Varmilo VA69 Tealios / G502 Lightspeed / Qpad Heaton XXL
Offline Ramason
« Reply #7474 on: Wed, 18 September 2024, 22:58:29 »
I’m using the Razer BlackWidow V3 mechanical keyboard. The Yellow switches offer a smooth, responsive typing and gaming experience. The key feedback is precise, and the RGB backlighting adds a cool touch. It’s perfect for both gaming and everyday use!
Offline wjrii
« Reply #7475 on: Thu, 19 September 2024, 10:02:14 »
What a coincidence!  I too am using the Razer BlackWidow V3 mechanical keyboard. The Yellow switches do offer a smooth, responsive typing and gaming experience. The key feedback really is precise, and the RGB backlighting adds an undeniably cool touch. It’s truly perfect for both gaming and everyday use!  :p
Actually, I've just rotated my retro TKL variant back into service.  Handwired RP2040 running KMK, aluminum plates, red oak sandwich sides, Box Navy, VSA overstock keycaps from Aliexpress (except for DSA on the F row).
« Last Edit: Thu, 19 September 2024, 13:54:38 by wjrii »
Offline sirRobinFi
« Reply #7476 on: Sat, 21 September 2024, 02:33:31 »
Very cute board.
Thanks for the tip. Painful to find swe/fin keycaps
Offline Minisofu
  • Aspiring Keycap Designer
« Reply #7477 on: Mon, 04 November 2024, 22:08:05 »
Currently using the Cycle 7, although im look ing to switch it out soon but with no budget its been hard. I really do want to try and get the Neo Ergo because of the build quality and how cool it looks. Hopefully one day i can get it when my budget isnt abysmal
Offline Subdromat
Sangeo 65 wk issue
« Reply #7478 on: Sat, 25 October 2025, 13:40:12 »
Sangeo 65 with SOTC (molded) in WK issue  and ozzy ansi - de caps[/img][/img], best space in town
Offline Rob27shred
« Reply #7479 on: Sat, 25 October 2025, 14:07:11 »
314999-0
Plywrks Spyder (Dolomite with stone washed weights), FR4 HS PCB, PCBsnap mounted (4 on top, 2 on bottom), Knight v3 stabs, PP plate, Keygeek Y2 37g switches, DCS Solarized Dark.
Loving this build, super deep sounding even with DCS caps, nice extra bit of softness with PCBsnaps vs the included O-ring, & super smooth feeling with the Y2s. These Y2s & the Blue Cheese v2s have quickly become my go to switches for when I don't feel like tuning the switches myself. Both are not only useable, but really good stock IMHO! Not sure what voodoo Keygeek is using for their factory lubing process but all of their recent switches I have gotten I've been just fine using as is.
« Reply #7480 on: Sun, 26 October 2025, 08:11:54 »
That is an absolute beauty!
- Sherry Turkle
Offline Rob27shred
« Reply #7481 on: Sun, 26 October 2025, 08:33:43 »
Thanks man! Yeah it's a board I've been very happy with!
Offline ISAslot
« Reply #7482 on: Tue, 28 October 2025, 16:46:06 »
315031-0
IBM Type F AT
Work one pictured (1985), mirror setup for home (1987).
Internal Soarer's converters, key changes, floss mod (not superfloss tho)
Offline pnoozi
  • I was annoying at a KeyCon, so now I pay more 🤷
« Reply #7483 on: Thu, 30 October 2025, 12:11:41 »
I'm a simple man. I use a Filco TKL, Cherry MX Red while I research something more exotic.
Filco Majestouch 3 TKL (Red) | Nuphy Air75 (Brown)
« Reply #7484 on: Thu, 30 October 2025, 17:12:11 »
I got one of those for my son 15+ years ago and it is still in use today. After a few months we added the thinnest, softest O-rings we could find.
Use was heavy then but light now.
- Sherry Turkle
Offline julimma
« Reply #7485 on: Thu, 12 February 2026, 19:52:31 »
I am using the NEO 80CU, Wraith60, Paper65, Think 6.5v1, Veil65, QK 65MK3 and yes I am a 65% lover
Offline megasthenes
« Reply #7486 on: Tue, 24 February 2026, 15:19:19 »
This cheap thing.
Offline clay
  • No foams
« Reply #7487 on: Fri, 27 February 2026, 13:35:47 »
Typ65+ by Axiom Studios. Never letting this one go
Offline nikosbell
« Reply #7488 on: Wed, 04 March 2026, 21:55:38 »
I'm using an Epomaker P75 With some Drop Keysterine Smoke keycaps and Oil King linear switches. So far it feels pleasant to type on and the sound is easy to listen to. Haven't lubed or filmed the switches yet, will report back what they sound and feel like later.
Offline SteeZie
« Reply #7489 on: Wed, 11 March 2026, 18:16:59 »
Very new so Entry Level type beat - Drop Alt v1 High-Pro (speed silver switches & Panda Stabs (Holee modded))
IMO very good intro to this space and still pretty THOCKY, however I did notice play on the Plate Mounted Stabs, so I taped the contact between the two - and it sounds great! (layer of hard tape, and spongey tape for shock absorbtion) sounds pretty dialed and balanced over all. The next KB I want in the future is forsure the Ikki68 aurora, but its always sold out - so until then, this is what we run.
p.s. Just ordered a new case for it - current: black | new: Arctic Blue
ₛₜₑₑ𝆎ᵢₑ
Offline Happy Hopping
« Reply #7490 on: Mon, 13 April 2026, 18:55:27 »
What are the top quality brand on magnetic keyboard?  I have check out Wooting and keychron.
Offline dailytadpole
« Reply #7491 on: Tue, 05 May 2026, 12:47:21 »
TAIKO 01
This one's a prototype of the keyboard I made. Gateron Browns. Custom XDA keycaps. Hotswappable. I wrote about my product development journey here
Offline yuppie
« Reply #7492 on: Thu, 07 May 2026, 11:33:54 »
MY-2K with GMK Future Funk R2 and a Skelebro BBv2
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
