Author Topic: Anker Vertical Mouse - $9.99  (Read 6595 times)
Re: Anker Vertical Mouse - $9.99
« Reply #1 on: Fri, 05 July 2013, 14:25:59 »
This is worth it just to try. Wonder if the wireless model is worth it.....
« Reply #2 on: Fri, 05 July 2013, 14:27:44 »
Does look way better than the Evoluent, but I still love my Joy Pen.
- D Trump 2026-09-28
« Reply #3 on: Fri, 05 July 2013, 14:36:09 »
TheFlyingRaccoon has a wireless version much like this.  The design is an OEM, so there are a few variations of this device in wired/wireless.
« Reply #4 on: Fri, 05 July 2013, 14:45:33 »
I literally just bought this the other day for $17.  Think Amazon will refund me the difference?
« Reply #5 on: Fri, 05 July 2013, 14:46:23 »
Doesn't hurt to try. I have had nothing but awesome experience with their customer service. But as always YMMV.
« Reply #6 on: Fri, 05 July 2013, 14:57:38 »
And they did it.  Seems they'll refund the difference if it's within 7 days of delivery.  I could have also been a stickler and gotten another $1 back from another purchase, but I was happier to get my $6.50 back on the mouse.
And if you haven't tried it, it's not a bad vertical mouse.  Not an amazing one, but not a bad one either.  I originally had a wireless Anker Vertical Mouse, but my mom tried it and stole it from me.
Offline Thechemist
« Reply #7 on: Fri, 05 July 2013, 15:18:28 »
Don't let her near your mech boards  ;D
« Last Edit: Fri, 05 July 2013, 15:34:33 by Thechemist »
Offline PointyFox
« Reply #8 on: Fri, 05 July 2013, 15:24:04 »
Ordered ._.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #9 on: Fri, 05 July 2013, 17:43:50 »
Forwarded this on to a friend with big ol' hands. His hands get fatigued from trying to hold onto those regular mice to move them, so maybe this would help.
« Reply #10 on: Fri, 05 July 2013, 17:48:28 »
It might help him, I have regular sized fingers and a large palm.  My fingers to go the end, but I also have used this mouse with a pincer grip and it's still comfortable.  Lots of folks at my office like these.
Offline Sniping
« Reply #11 on: Fri, 05 July 2013, 17:58:47 »
I've never tried a vertical mouse before, so I just purchased a wired one to see what all the craze is about! I'm looking forward to using this.
« Reply #12 on: Fri, 05 July 2013, 18:04:03 »
It takes some getting used to, but it's more comfortable for extended use.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #13 on: Fri, 05 July 2013, 22:14:57 »
If you want a wired vertical mouse go with the Anker, it's a great deal. If you want wireless I would recommend going with this Perixx one. It goes up to 2000dpi and is cheaper. Otherwise it's basically the same except the Perixx one has a better finish on the clickers. Regardless of which one you get, I highly recommend these mice. They are very comfortable and great for the price.
Amazon link http://www.amazon.com/Perixx-PERIMICE-713-Wireless-Ergonomic-Vertical/dp/B00C6Y4J1E/ref=sr_1_1?ie=UTF8&qid=1373080269&sr=8-1&keywords=perixx+vertical+mouse
HHKB Pro 2   SmallFry Keyboard
« Reply #14 on: Fri, 05 July 2013, 22:25:51 »
I have not used these Ankers but I can certainly vouch for this type:
http://www.ebay.com/itm/New-Ergonomic-Design-WOWPEN-Vertical-USB-Optical-Mouse-JOY-Wrist-Pain-hot-USB-/221181040125?pt=Mice&hash=item337f6ad5fd
PS - it is much better-looking and less clunky in real life
Offline khaangaaroo
« Reply #15 on: Sat, 06 July 2013, 11:58:16 »
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #16 on: Sat, 06 July 2013, 14:07:10 »
or if you want to look badass at work: http://www.newegg.com/Product/Product.aspx?Item=N82E16826501004
i got one of these for $5 a couple years ago in a newegg deal-my guess is zalman must have made a million of these and couldnt sell them, it is such a dumb thing--yes it has some of the ergonomics of a vert mouse but it doesnt really feel ergonomic after you use it for more than 10 minutes gaming, plus it looks really stupid to use.
« Reply #17 on: Sun, 07 July 2013, 01:31:32 »
I just opened mine up and swapped 5 out of the 6 crappy Zhij switches for these Omrons and it makes it so much nicer.  The switches are a lot less stiff, but still nice and clicky. The only one I didn't have enough Omrons for was the DPI switch, but I'm okay with that.  Honestly, you can't go wrong with it for $10 and another $4-8 for some Omron switches.
While I was at it, I also swapped the LED for one of these water clear pink LEDs.  It's not as bright as I would like, but looks nicer than the blue IMO.  I may need to open it up again and see if I can swap a resistor for a lower resistance one to make it brighter.
« Last Edit: Sun, 07 July 2013, 12:55:06 by nubbinator »
  • HHKB Pro
« Reply #18 on: Sun, 07 July 2013, 21:35:53 »
That is really awesome! How hard was swapping out the switches? And how much of a difference do the Omron switches make? I am considering doing this on mine.
« Reply #19 on: Sun, 07 July 2013, 21:47:00 »
It was really easy. Figuring out how to open it was a PITA, but it actually disassembles pretty easily.
How to disassemble:
- Pop the glides/skates/feet off the mouse.  There are screws under 3 out of the four that need to be removed.
- After unscrewing the screws, the bottom of the mouse comes out and you'll need to disconnect a ribbon cable.
- Find a little clip inside for popping off the part of the mouse that you press to click the buttons.
- Once that's off, unscrew three screws, two up front, one in the back.
- Next, find the clips holding the two sides together and pop the two halves apart.
- From there, it's just unscrewing PCBs, desoldering, and soldering on the new switches in the right orientation.
The Omrons are easier to click and feel nicer. The Zhij switches it uses take a lot of force to depress and are a lot stiffer.  It's not a massive difference, but it's definitely noticeable and well worth it to me.  It's enough of a difference that my mom asked me to do it to the wireless one she stole from me.
« Last Edit: Sun, 07 July 2013, 21:48:51 by nubbinator »
  • HHKB Pro
« Reply #20 on: Sun, 07 July 2013, 21:56:48 »
How to disassemble:
Wow, thanks for the guide! For $4 I think it will be well worth it.
