Author Topic: Is it possible to lube the keyswitch without open it?  (Read 2288 times)
Offline Neo.X
« on: Sat, 06 July 2013, 19:11:46 »
My QFR red switch is feeling a little scratch, it's working all OK, just not as smooth as my other keyboards.
I am thinking of lube it a little bit, but I don't have skill nor time to desolder the switches, lube them and put them back. I did some search and come across this article, http://imgur.com/a/lhLqo
Did anyone try this before and how did it work?
Thanks in advance.
All those keyboards will be lost in time....
Offline The_Beast
  • I like wood ಠ_๏
Offline Neo.X
Re: Is it possible to lube the keyswitch without open it?
« Reply #2 on: Sat, 06 July 2013, 19:48:14 »
Thanks for the information, helps a lot.  :) :)
Offline fateswarm
« Reply #3 on: Sun, 07 July 2013, 07:56:11 »
I just flood them while keeping it pressed. Since flooding may dumpen it a lot, a simple solution is to blow compressed air in it for half a second. It removes anything in excess without damaging it.
Offline Neo.X
« Reply #4 on: Mon, 08 July 2013, 10:32:38 »
Can you please provide more detail, Like what lubricant you were using, how did the key switch feel after that? Any mess on the plate?
Thanks
« Reply #5 on: Mon, 08 July 2013, 11:40:39 »
Probably used DeoxIT Fader.
