Author Topic: Check your DSA SP caps before using.  (Read 31347 times)
« on: Sun, 14 July 2013, 19:02:57 »
So recently I got out my DSA retro set to outfit a recently built ergodox.  I'm not very thrilled with the results which were a lot of broken switches.  If you buy DSA caps from SP or have any want to buy them from SP make sure you check the bases.
The 2 caps on the left came off my board without any problem.
The 2 caps on the right took(destroyed) the entire switch when the cap was removed..  I tried to go at it gently after I noticed a pattern, but unfortunately I could only get the stems out of the keycaps with plyers.
The pattern here is the bases of the caps.  If they have 4 points and some extra cut away the cap then they are good, but a simple cross shape will destroy your switches.  You can test it if you want on some crappy ones, but you might not want to completely ruin any spares you might have lying around.
« Last Edit: Mon, 15 July 2013, 13:46:36 by Binge »
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: Check your DSA SP caps before using.
« Reply #1 on: Sun, 14 July 2013, 19:06:03 »
I recently bought their DSA PBT blank caps, in all black. The larger caps (mods) had holes that were too large for my stabilizer nubs, so my space bar and right shift and others are a little wonky. Any suggestions besides super glue?
« Reply #2 on: Sun, 14 July 2013, 19:11:08 »
I'm at a loss brother.  Really have no idea why 1/2 of my caps are like this and the other half aren't.  Even my relendables (which should all be the same mold) have this defect in about half of the keys.
Offline gnubag
« Reply #3 on: Sun, 14 July 2013, 19:20:06 »
put some paper/tape over the stabs.
« Reply #4 on: Sun, 14 July 2013, 19:25:04 »
Which are the 'bad' ones in the picture?
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #5 on: Sun, 14 July 2013, 19:27:56 »
Ohh thanks gnubag!
Offline linziyi
  • The one with many questions
« Reply #6 on: Sun, 14 July 2013, 19:29:02 »
How does that destroy the switch?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline Leslieann
« Reply #7 on: Sun, 14 July 2013, 19:36:09 »
Paper or Saran Wrap will shim the caps that are too loose.
As for why some are tight and some are not... I see this on my 3d printer, how fast the plastic cools can effect how much shrinkage there is. On an open printer, with no enclosure, simply opening a window or door can make visible changes in the object as some layers will shrink more than others. The same can happen by changing the temp they are molded at, some of my ABS needs 227c, another prefers 119c, not only can different manufacturers effect this, coloring can too. My bet is that they were done at different times, and a temp was set wrong.
Looking closer at the caps, it looks like they were cooled at a different rate, or on a different mold.
« Last Edit: Sun, 14 July 2013, 19:38:33 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline smknjoe
« Reply #8 on: Sun, 14 July 2013, 19:38:13 »
The stem was ripped out of the switch. The only way to remove the stems without damaging the switch is to disassemble the switch, not rip it out through the top.
SSKs for everyone!
« Reply #9 on: Sun, 14 July 2013, 19:38:14 »
Ohh thanks gnubag!
Or a small square of plastic, say from a plastic lunch bag (I have used that to good effect).
Or even a small piece of teflon tape.
« Reply #10 on: Sun, 14 July 2013, 21:30:17 »
Ohh thanks gnubag!
the caps on the right.
Offline Photoelectric
« Reply #11 on: Sun, 14 July 2013, 21:43:27 »
Teflon tape has been best in my experience (= pipe tape, you can get it from a hardware store plumbing department for a couple of dollars).
Offline elton5354
« Reply #12 on: Sun, 14 July 2013, 23:54:07 »
Same thing happened to me with the switch coming out. Not only that the stem on the cap broke off...
« Reply #13 on: Mon, 15 July 2013, 12:41:28 »
Yo that's messed up.
Offline gnubag
« Reply #14 on: Mon, 15 July 2013, 12:51:12 »
well, it's also because the stems are crazy tight on all the caps (rotation thingy)
Offline Dubsgalore
« Reply #15 on: Mon, 15 July 2013, 12:55:58 »
Pretty sure in the clear stem thread someone said that PBT DSA SP caps are the tightest...looks like it's true
sorry to hear m8
« Reply #16 on: Mon, 15 July 2013, 13:42:28 »
these are ABS doubleshots... look at the stems, some have relief while the others do not.
::EDIT:: added more to picture in first post.
« Last Edit: Mon, 15 July 2013, 13:47:48 by Binge »
Offline vivalarevolución
« Reply #17 on: Mon, 15 July 2013, 19:43:27 »
I had this same problem.  In order to not destroy the switch, I had to hold the stem with a long, thin object, like a small screw driver, and push down on the switch while I pulled up on the keycap.
Offline Thimplum
  • Master of all Ponies
« Reply #18 on: Mon, 15 July 2013, 19:52:42 »
OUCH!
TP4 FOR ADMIN 2013
Offline reiuorw
« Reply #19 on: Mon, 15 July 2013, 20:46:07 »
I ordered PBT white blank set from SP, I should check it when I receive it.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #20 on: Mon, 15 July 2013, 21:05:55 »
Broken switches ouch. I broke a switch on my Ducky 5mins from getting it from the mailman, :(
« Reply #21 on: Mon, 15 July 2013, 21:51:54 »
Ducky caps are annoying like that too--at least the Shine ones.  Had the worst time getting it off new MX Clears (well a test switch that I specifically tried the cap on to see the fit).  Clears + Ducky Shine caps = extra tough to get off.
Offline MOZ
  • Busy making stuff
« Reply #22 on: Mon, 15 July 2013, 22:01:05 »
LOL. Mine was other way round. I was trying a custom cap which I had received the day before (Didn't get time to try it on any other keyboard). So as soon as I opened the Ducky Zero, I tried the keycap. It fit easily but when removing it, it pulled the blue stem as well as the white part from my Cherry MX Blue.
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #23 on: Tue, 16 July 2013, 11:34:01 »
I managed to get some of the "bad" caps off of MX Clears with no damage, but for anyone else who wishes to try... Go very slowly with this!
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline MOZ
  • Busy making stuff
« Reply #24 on: Tue, 16 July 2013, 12:17:44 »
I don't know if this works but how about lubing the outside of the stems on the switch before putting these caps on?
Offline jingil
« Reply #25 on: Thu, 18 July 2013, 17:38:10 »
I will check it. Thanks!
DUCK MINI V1 ll 356MINI
Offline reiuorw
« Reply #26 on: Sat, 20 July 2013, 22:33:53 »
oh, after read this thread, I found some of my DSA keycaps have same bad stems.
then, couldn't I use them? or is there any way to prevent pulling up sliders together when I remove them from keyboard?
Offline funkymeeba
  • CRUMPULAR
« Reply #27 on: Sat, 20 July 2013, 23:05:01 »
They can absolutely be removed. Just be VERY CAREFUL when doing it. Patience is extremely valuable.
Offline Hamblet
« Reply #28 on: Sun, 21 July 2013, 00:27:31 »
Folks !!
Never worry about it.
I have a good news for the poor people here.
It is a way old but works fine, and have never seen any finer design than this one.
Here comes the most safest keytop remover.
Come and try it.
Main Idea
How to work
28879-1
Blueprints
28881-2
Details
28883-3
Proto
The Finals
28887-5
« Last Edit: Sun, 21 July 2013, 00:32:24 by Hamblet »
Offline MOZ
  • Busy making stuff
« Reply #29 on: Sun, 21 July 2013, 00:41:26 »
Those are from rispter's guide. Nothing new.
« Reply #30 on: Sun, 21 July 2013, 00:45:46 »
Folks !!
Come and try it.
Main Idea
How to work
Blueprints
Details
Proto
The Finals
You should at least credit the original...
Offline Hamblet
« Reply #31 on: Sun, 21 July 2013, 01:33:35 »
What's that ? R's guide ?
Sorry, I know nothing about the guide.
I do not have any kind of recent news (i.e. couple of years).
I do not care about the guide says.
The only thing I know clearly is, the idea is MINE from the very first time. And, Of course the photos are all mine too.
I do not care about you understand the idea or not, and you are going to use it or not.
The only thing I know clearly is, If you do not use it you will ruin your switches for sure.
Offline Hamblet
« Reply #32 on: Sun, 21 July 2013, 01:38:36 »
You guys do not know ABC.
The link above are just silly one. Most of the contents are stollen, and (s)he does not understand it at all.
Idiot.
Offline rao2100
« Reply #33 on: Sun, 21 July 2013, 02:31:40 »
I think Hamblet's design is to use it as a lever. Meaning hold down the switch while pushing the cap up like a lever.
Correct me if I am wrong Hamblet. Thanks.
| KMAC LE Vintage Blues | LZ-S Ergo Clears | Filco TKL MJ2 Ninja Reds | CM QFR - Blues | IBM Model M SSK 1991 |
Offline Hamblet
« Reply #34 on: Sun, 21 July 2013, 04:01:54 »
You are absolutely right, clever girl !!!
It is safe because you will not see the bare stomach (slider and spring) of your lovely switches out of the blue.
It is safe because you will not scratch the face of your tender keytops (think about the stupid metallic pullers. The worst is Topre's).
It is safe because you will not break the stem of keytops, especially the weakest one of the Alps'.
It is cheap, tiny and looking good.
It is nice, isn't it ?
« Reply #35 on: Mon, 22 July 2013, 08:56:33 »
Folks !!
Come and try it.
Main Idea
How to work
Blueprints
Details
Proto
The Finals
If you guys look Ripster gives credit to Hamblet!!
And Hamblet, that is really cool would you be interested in selling a couple sets? I'm building a key cap keychain and key cap puller collection.
Offline Hamblet
« Reply #36 on: Mon, 22 July 2013, 18:47:39 »
Basically, I am not intending to sell it. I just made a unique design, opened it for the purpose of eliminating the uneasiness of harvesting keytops.
If you want to have it, buy a box of paper clip at stationery. Unbend it and bend it again with your will. That's it. Easy.
Good Luck my friend.
Offline gnubag
« Reply #37 on: Mon, 22 July 2013, 19:43:36 »
The DSA tooling was designed for ABS not PBT. PBT shrinks more so, depending on the molding conditions, the mount could be slightly smaller and fit more tightly on a key switch. The stems of key switches can also vary slightly. The right combination can result in a very tight fit.
-SP
that is what I got told from SP when I asked about my PBT blank set.
Offline reiuorw
« Reply #38 on: Mon, 22 July 2013, 22:14:49 »
-SP
but DSA retro set is ABS, isn't it?
« Reply #39 on: Mon, 22 July 2013, 22:19:26 »
It is, but SP also makes blank DSA-profile PBT caps.
Offline smknjoe
« Reply #40 on: Mon, 22 July 2013, 22:42:09 »
All of Ripster's stuff used to be here before he was banned and the server started going off-line every few hours. He was quite the prolific poster here at GH. He does credit all of the sources in your link - including Hamblet.
Pretty cool design Hamblet!
Folks !!
Come and try it.
Main Idea
How to work
Blueprints
Details
Proto
The Finals
[/quote
SSKs for everyone!
Offline funkymeeba
  • CRUMPULAR
« Reply #41 on: Mon, 22 July 2013, 22:43:30 »
I have yet to find any PBT DSA caps that don't fit right, and I have over 1,250 of them.
« Reply #42 on: Mon, 22 July 2013, 22:44:58 »
My bad about the Ripster link and proper credit!
« Reply #43 on: Mon, 22 July 2013, 22:49:34 »
Maybe your caps are just funky ;)
Offline Hamblet
« Reply #44 on: Mon, 22 July 2013, 22:55:19 »
Says, Mr. R is not here anymore. I do not know why, and (sorry) I am not interested in that.
One thing I know is, He is a not so bad guy.
I got no bad feelings about him.
Offline funkymeeba
  • CRUMPULAR
« Reply #45 on: Mon, 22 July 2013, 23:03:49 »
I can always get some of them prepped in a color you like. PM me! $28 + shipping. Beware: I have found no blue dyes that work. Purple is my favorite so far.
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #46 on: Tue, 23 July 2013, 11:54:34 »
Still handy though :p
Offline Rule16
  • R.I.P. SmallFry
« Reply #47 on: Tue, 23 July 2013, 17:50:25 »
Ripster got banned? What for?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
« Reply #48 on: Wed, 24 July 2013, 09:14:16 »
Offline megaxpop
« Reply #49 on: Wed, 24 July 2013, 09:19:53 »
i'm very lucky cuz my DA retro is all good! :p
