Author Topic: Cherry G80 numpad on ebay  (Read 2064 times)
- D Trump 2026-10-24
Offline SeriouSSpotS
  • 60% is love, 60% is life
Re: Cherry G80 numpad on ebay
« Reply #1 on: Tue, 16 July 2013, 07:49:45 »
That is a bit expenisve
« Reply #2 on: Tue, 16 July 2013, 07:51:03 »
Are those the normal keycaps that would come with one of these?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Tue, 16 July 2013, 07:58:48 »
I paid more for mine and it was in worst condition (slightly yellowed case, brown cable, slight shine on the caps). This one looks nearly NIB other than those stupid caps it has on it
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 16 July 2013, 08:46:23 »
No it would have doubleshots if it was stock. Those look like some custom lasered job, some sort of control pad application? It does look like it should be like mint since it has the plastic cover to have protect it. Also it should be 100% programmable version so the price is not too terrible.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #5 on: Tue, 16 July 2013, 08:53:19 »
That sounds about right to me for one of those in that condition. Especially if it's Mode 4 compatible, then you can fully program the thing. I'd say it's worth it if you wan't an MX numpad that you can easily modify.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline esoomenona
  • Gnillort?
« Reply #6 on: Tue, 16 July 2013, 14:12:27 »
Haven't some come with lasered Cherry caps? I thought that was the difference between the ones that have two tone sets and the ones that have single tone.
« Reply #7 on: Tue, 16 July 2013, 14:31:56 »
There are later made 3700LQAUS, etc. where only the top 4 keys are programmable. But this one here is 3700HAD, so it should have German labeled doubleshots, but it was a custom order caps.
