Author Topic: compact keyboard + colemak  (Read 2854 times)
Offline Little
« on: Mon, 22 July 2013, 06:03:46 »
Dear Geekhack community,
I want to buy a compact keyboard and change the letters to colemak layout.
I was thinking about a  FC660M or a Poker 2.
Except for the messed up hotkey labels, is there any other problem doing this?
what are your thoughts on this? is it a bad idea?
Thank you!
Offline korrelate
  • iubeo stultum esse libenter
Re: compact keyboard + colemak
« Reply #1 on: Mon, 22 July 2013, 06:09:19 »
FYI: WASD Keyboards recently unveiled their V2... a TKL that comes with a controller that supports colemak natively.
Topre REALFORCE
Offline Lupizza
  • Kung av Sverige!
« Reply #2 on: Mon, 22 July 2013, 07:05:38 »
Don't the keys have different profiles?
Left geekhack 2013-08-24, because of rude and arbitrary moderators.
Offline CommunistWitchDr
  • >implying keyboards
« Reply #3 on: Mon, 22 July 2013, 08:09:33 »
Blank keys work with any layout.
Offline yasuo
  • spanengan puyeng newbie
« Reply #4 on: Mon, 22 July 2013, 08:21:27 »
for letters on the keycap, you can order from SP or WASD
Logitech MK220 Colemak DH
« Reply #5 on: Mon, 22 July 2013, 12:03:17 »
Colemak and dvorak keycaps have both been options for a while from WASDkeybaords
Offline jspark
« Reply #6 on: Mon, 22 July 2013, 12:43:32 »
I haven't type on a Poker II, but I have on a Poker X with Colemak layout.
I haven't had any problem with Colemak on Poker X.
KBC Poker X Cherry MX Black switch
Filco Majestouch2 Ninja Cherry MX Blue switch
IBM Model M 1391401 in 1988
Offline davkol
  •  Post Editing Timeout
« Reply #7 on: Mon, 29 July 2013, 04:08:19 »
WASDv2 should be tenkeyless, w/ HW support for Colemak and custom keycaps (and standard physical layout, so you could easily replace full set).
My another recommendation is TypeMatrix 2030. Sure, it isn't mechanical, but still very good, quieter and thinner than any mechanical keyboard (maybe except some Cherry G84), and with HW Colemak support. My favorite keyboard for traveling. You can get a Colemak skin for it.
Or you could go with a custom keyboard like ErgoDox or GH60.
