Author Topic: Suggestions for a set for my Filco Camo?  (Read 5027 times)
« on: Mon, 22 July 2013, 11:37:01 »
I'm drawing a blank here. I can't find anything I like.
I'm leaning towards a white mods with black letter keys type thing, but I'm not sure.
Anything helps, I'm having a lot of trouble deciding.
Re: Suggestions for a set for my Filco Camo?
« Reply #1 on: Mon, 22 July 2013, 11:38:00 »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Mon, 22 July 2013, 11:41:21 »
R3 set. Need reaper for pic.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #3 on: Mon, 22 July 2013, 12:31:59 »
http://geekhack.org/index.php?topic=45655.0
^^ can't go wrong with these
Pretty much designed for the Camo boards haha. I myself went oldschool WYSE for mine :D
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Photoelectric
« Reply #4 on: Mon, 22 July 2013, 20:33:03 »
I'll also recommend those military-inspired caps.  They are amazing.  I would love to own a set myself if I had a spare keyboard that didn't already have a theme planned out and invested in another group buy.
Offline shadewolf
  • ಠ_ಠ
« Reply #5 on: Mon, 22 July 2013, 21:26:56 »
There's also some good stuff in the below thread, including my awful attempt at putting some Filco yellow keys on my old camo board :D
http://geekhack.org/index.php?topic=35441
Offline PointyFox
« Reply #6 on: Mon, 22 July 2013, 21:33:11 »
Mine.  ;)
« Reply #7 on: Mon, 22 July 2013, 21:34:44 »
DSA Retro with Brown mods and green accents also looks amazing in the Camo.
Offline Thimplum
  • Master of all Ponies
« Reply #8 on: Mon, 22 July 2013, 21:51:12 »
A was about to recommend the Sanctuary set, but then I actually thought about what it would look like and almost vomited...
Mine.  ;)
I do like that...
TP4 FOR ADMIN 2013
« Reply #9 on: Mon, 22 July 2013, 22:07:03 »
https://www.originativeco.com/classic-beige-two-tone
What do you think about this set?
I don't like the commando set, SA and DSA caps aren't really my thing.
I was also thinking dolch. I might buy dolch (from originative) for another one of my boards.
« Reply #10 on: Mon, 22 July 2013, 22:09:56 »
That was another set I thought of as being nice.  Classic white and beige.  But might be too busy for that case.
Offline reiuorw
« Reply #11 on: Mon, 22 July 2013, 22:12:49 »
« Reply #12 on: Mon, 22 July 2013, 22:15:17 »
I can do busy. Here's my QFR.
Busy is ok.
« Reply #13 on: Mon, 22 July 2013, 22:18:07 »
Well then!  I think you should combine all of our suggestions onto your Filco, including the different profiles ;)
« Reply #14 on: Mon, 22 July 2013, 22:21:16 »
The case is silly enough. I'll probably just use the beige/white set.
« Reply #15 on: Mon, 22 July 2013, 22:24:20 »
If you like blanks and could deal with DSA after all, you could get blank PBT sets directly from SP.  they come in white, green, and black "mix and match"--you could make some suitable combination.
http://www.keycapsdirect.com/marketplace.php
They also have simple DS white sets there.
« Last Edit: Mon, 22 July 2013, 22:25:57 by Photoelectric »
« Reply #16 on: Mon, 22 July 2013, 22:29:11 »
I'll skip the DSA.
I was thinking about a black on white set. $60 is a pretty good price. I've also got 3 other boards to cap, so cheaper is better.
« Reply #17 on: Mon, 22 July 2013, 22:33:34 »
If you want cheaper and simple, go with thin PBT sets.  Like qtan's online store has some:
http://www.vendio.com/stores/E-sports-Gaming-equipments/category/cateogry1-name/catId=3982960
White side printed, top printed, etc.  Some sets on eBay too from him and Feng (usually costs more there), and some sets on mechanicalkeyboards.com
« Reply #18 on: Mon, 22 July 2013, 22:56:56 »
I'll probably order from Qtan. Thanks for your help!
Offline Rule16
  • R.I.P. SmallFry
« Reply #19 on: Thu, 25 July 2013, 19:36:52 »
Busy is ok.
How do you even type on that with all the different profiles?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline bazemk1979
« Reply #20 on: Thu, 25 July 2013, 20:38:37 »
Busy is ok.
touch typing....
Offline bazemk1979
« Reply #21 on: Thu, 25 July 2013, 20:40:13 »
^^^^ This.... spend more and really enjoy them, not just buy something for less,use them for few months and then trying to sell them.... That set would be perfest for cammo boards + the keycaps are thick and the 2nd shot looks beefy copmpared to the DSA and DCS
