Author Topic: Which one should I get??? Dell Quietkey or IBM KB-8923  (Read 6705 times)
Offline theryaner
« on: Mon, 22 July 2013, 22:29:10 »
I've owned several mechanical keyboards, ibm model M/F, Apple Extended Keyboard I/II, Dell AT101W and several others ,but I want to try out a high quality rubber dome for kicks. Which one of these do you guys like best? Aesthetically I like the ibm more but I want know which keyboard is the better performer.
Offline esoomenona
  • Gnillort?
Re: Which one should I get??? Dell Quietkey or IBM KB-8923
« Reply #1 on: Mon, 22 July 2013, 22:30:46 »
Rubber dome? Topre.
High quality? MY.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #2 on: Mon, 22 July 2013, 22:36:06 »
If you can get the QuietKey for dumb cheap then go ahead...but like the post above me...get a Topre board...I am planning to get it if I can get a job during the school year...
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
« Reply #3 on: Mon, 22 July 2013, 22:38:33 »
I don't know. IBM buckling rubber sleeves are supposed to be pretty nice. Many RD KB's with metal plates are nice. I really like my olivetti.
Offline theryaner
« Reply #4 on: Mon, 22 July 2013, 23:39:49 »
I don't have money for a topre so please keep your comments relevant to the two keyboards I mentioned or something similar in price. I'm a fan of vintage boards so it doesn't matter if its something older. Thanks guys!
Offline Lmnr
  • The Jack Of All Trades
    • W.W.C.
« Reply #5 on: Tue, 23 July 2013, 00:51:23 »
From experience, very nice IBM board but the spacebar is very loud but overall I'd get the IBM if you could but the Quietkey is easier to get.
Peripherals:
Realforce 87uw with grey caps,Ducky YOTR Blues,Realforce 104ug Hipro,Zowie Am FG,WMO 1.1a,Sidewinder X3
Offline tipo33
  • "Ski"
« Reply #6 on: Tue, 23 July 2013, 00:55:55 »
I have used both, the keyfeel is about the same, based on condition of course.  But the Trackpoint on the IBM seals the deal IMHO.
KM4COL    R.I.P.  SmallFry
Offline brialona
« Reply #7 on: Tue, 23 July 2013, 02:31:36 »
I have a dell quiet key and to be honest, I personally can't say that there is a big difference between rubber domes
edit: typing on it right now, not a big difference but there is one
« Last Edit: Tue, 23 July 2013, 02:50:34 by brialona »
ozil
« Reply #8 on: Tue, 23 July 2013, 07:28:12 »
They are equivalent, I like them both, but if you go for the Dell, make sure that you get the early one from Malaysia with a number like R45D and not a later one from China with a number like 1000.
- Franklin Roosevelt 1933
Offline theryaner
« Reply #9 on: Tue, 30 July 2013, 02:41:11 »
I went with the IBM kb-8923 and I like it a lot. It definitely isn't as great as some of the best mechanical boards, but it beats some of them. I prefer it over the apple extended II and maybe the dell at101w. I love the simple/solid construction and how the board is held together only by phillips screws. Thanks for the info guys.
Offline Danule
« Reply #10 on: Tue, 30 July 2013, 07:36:53 »
I recently aquired a dell quietkey at a second hand store for 2.99 and I have to say I was impressed by it.  Very nice for a rubber dome board.
I'd say go for it :)
45g Brown Brown Blue
Offline daerid
    • Rossipedia
« Reply #11 on: Tue, 30 July 2013, 10:21:03 »
Preferred over the at101w? Blasphemy!
Offline hoggy
  • * Ergonomics Moderator
« Reply #12 on: Tue, 30 July 2013, 10:24:49 »
Keytronic do a nice range of rubber domes.  Their ergo range have variably weighted keys - need more force on keys that are under your stronger fingers, and less force on keys under your weaker fingers.
Or there's the goldtouch.  Might not have the form factor you're after, but feel really good for RD (and they are very quiet).
