Author Topic: Popular keyboards for each switch?  (Read 3592 times)
Offline xSpartanCx
« on: Tue, 23 July 2013, 14:27:20 »
I'm building up my wish list for keyboards, and I'd like to know a bit more about popular models for certain switches, as well as which switches are most popular (by this I mean the ALPS)
Are there any keyboards that use the following switches?
MX/White
MX/Clear
MX/Black
MX/Darkgrey
MX/Grey
And what are the popular ALPS switches? I know there's the in-production Matias clicky and tactile. What keyboards use these new ones, and what are the popular older ALPS switches? What keyboards use those?
I'm trying to move away from the common MX switches and would like some of your guys' input. Another question: Are there any popular topre keyboards other than the HHKB and 87u?
Re: Popular keyboards for each switch?
« Reply #1 on: Tue, 23 July 2013, 14:30:12 »
I can't swear by it but I'm thinking this exact same thread exists if anyone can find it, it might be helpful to you!
Captain` BA has some good switch info there is a link in his sig, he will probably post in here also.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #2 on: Tue, 23 July 2013, 14:30:47 »
Leopold FC660M has MX Clear at qtan's vendio store
Ducky also has MX Clear at mechanicalkeyboard.com
« Last Edit: Tue, 23 July 2013, 14:53:29 by kenmai9 »
Offline ImperfectLink
« Reply #3 on: Tue, 23 July 2013, 14:46:01 »
Leopold FC660M has MX Clear at elitekeyboards.com
I think you mean QTang. EK doesn't have clears listed.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #4 on: Tue, 23 July 2013, 14:47:45 »
AFAIK there are no boards with nothing but Whites, Greys, and Dark greys. You usually find those as single keys on some boards, like on some blue boards you'll have a green spacebar. Lots of Cherry boards come with blacks, and some with clears that you can harvest.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Lastpilot
  • Power stance
« Reply #5 on: Tue, 23 July 2013, 14:47:55 »
I know Whites were on Race and Pure keyboards. Not sure of any other models.
The white races are on mechanicalkeyboards.com right now :D
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #6 on: Tue, 23 July 2013, 14:48:42 »
I stand corrected on whites :)
TOO BAD FOR YOU
« Reply #7 on: Tue, 23 July 2013, 15:03:39 »
It's Qtan.
Matias Clicky can be found on the Matias Tactile Pro keyboard and MK.com and Matias sell loose switches.
Matias Quiet can be found on the Matias Quiet Pro keyboard and MK.com and Matias sell loose switches.
I'm a huge fan of the Dell AT101W which has Tactile Black Alps. I also really enjoy the Clicky White Alps which can be found in a Focus FK-2001. Tactile Salmon Alps can be found in Apple AEK keyboards which seem to be very popular.
There's a few boards with complicated blue alps but I can't remember the models at the moment; usually Chicony boards.
I just got a Siig Minitouch with Monterey Blue Alps Variants which I really like.
If you go to the DeskThority Wiki, they'll have a nice listing of boards for switches. If you search for "MX Black", there should be a list of boards that have MX Black switches.
« Reply #8 on: Tue, 23 July 2013, 15:19:07 »
It's Qtan.
Yeah I was confused too.
Quinan Tang = QTang
His email address is qtang1s@...
You're right though, I think his eBay store says QTan. Either way, it's coming from another language with non-latin characters so it's open to interpretation.
Offline Masterchief79
« Reply #9 on: Tue, 23 July 2013, 15:29:30 »
There are "complicated dampened cream ALPS" on the Apple Extended Keyboard II I believe, which is rather common and not really hard to get. On mine however, there are "white cream ALPS" which are considered pretty rare by the wiki: http://deskthority.net/wiki/Apple_Extended_Keyboard_II
Then there are other versions with Mitsumi clones or salmon/pink ALPS switches (I have a Apple M0118 with salmon ALPS which is also pretty rare). :) In the end, I would consider the Apple M3501 (AEK2) as the most popular keyboard using cream ALPS, and the Apple M0116 (AEK) the most popular one using salmon/orange ALPS.
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
Offline esoomenona
  • Gnillort?
« Reply #10 on: Tue, 23 July 2013, 15:30:32 »
Man... are you guys learning nothing?
G81 for MY switches
« Reply #11 on: Tue, 23 July 2013, 15:32:13 »
My liege, I felt it was not my place to proselytize the MY switch.
Offline xSpartanCx
« Reply #12 on: Tue, 23 July 2013, 15:35:09 »
So, are tactile/clicky like complicated/simplified? What's the difference between complicated/simplified?
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #13 on: Tue, 23 July 2013, 15:35:21 »
My apologies sir. I'll be more diligent next time.
TOO BAD FOR YOU
« Reply #14 on: Tue, 23 July 2013, 15:38:22 »
1) So, are tactile/clicky like complicated/simplified?
2) What's the difference between complicated/simplified?
1) No
2) How the internals are built up. As I understand it, legit Alps switches are "complicated" and the "simplified" versions are Alps clones.
Offline tgujay
« Reply #15 on: Tue, 23 July 2013, 15:44:48 »
And on greys http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=465
Gotta collect them all
Offline knotra
  • I ­­­♥ ⌂ ♫
« Reply #16 on: Tue, 23 July 2013, 15:46:15 »
the new wasd v2 has clears and blacks.
idk if there are any left but the ducky dye subs had dark greys and blacks.
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #17 on: Tue, 23 July 2013, 15:46:40 »
Well feces. I guess I really have been out of the MX game for a while.
TOO BAD FOR YOU
