Author Topic: Programming a Tipro  (Read 3381 times)
Offline GeorgeK
Programming a Tipro
« on: Thu, 25 July 2013, 12:11:47 »
Hey all
Hopefully just a quick question - can you program Tipros to do more than just keypresses?  I'm thinking along the lines of opening programs - simple example something like Microsoft Word.  I've had a play and can't seem to figure out if it's possible or not.
Cheers
George
Offline The_Beast
  • I like wood ಠ_๏
Re: Programming a Tipro
« Reply #1 on: Thu, 25 July 2013, 15:19:32 »
Hey all
Cheers
George
I haven't had any luck with this but I haven't delved into the depths of the tipro programming software. However, you might be able to write one of the keys to be Shift+F24 and then write an autohotkey script to do what you want when shift+F24 is pressed
Offline GeorgeK
« Reply #2 on: Fri, 26 July 2013, 11:46:06 »
Hmmm - a possibility... Thanks for the suggestion.  I was hoping to be able to program more keys however... I'll have to have another look
Offline GeorgeK
« Reply #3 on: Sun, 28 July 2013, 03:47:57 »
Anyone else got any suggestions?
Offline zulios
« Reply #4 on: Sun, 28 July 2013, 09:45:12 »
As far as I can tell the tipro software isn't suited for anything else than keypresses. Autohotkey might be your best bet. I personnally set a keyboard shortcut to the programs with the native windows functionality and program it into a key.
Don't forget that you have access to 4 layers with your tipro, so you can reserve a layer to such macros if it's really useful.
Tipro matrix - mx black
Offline damorgue
    • Personal portfolio
« Reply #5 on: Sun, 28 July 2013, 09:50:01 »
WIN, W, O, R, D, ENTER
That sequence might work to launch word.
Edit: Can Tipro output strings of keypresses like the one above?
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #6 on: Sun, 28 July 2013, 10:27:21 »
I believe you're able to assign a string of up to 255 keypresses, but I might be wrong. Still, that particular combination would work on it.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline damorgue
« Reply #7 on: Sun, 28 July 2013, 10:59:58 »
My solution is probably specific to Windows Vista/7 though. You could set up a shortcut to quicklaunch any program in the start menu as well and assign it a rare keycombo which you then program a key to output said combo.
Offline GeorgeK
« Reply #8 on: Sun, 28 July 2013, 11:59:39 »
I feared that may be the case - I'll look into autohotkey though.  Thanks for the suggestion :)
That would work... It isn't the most elegant of solutions but it'd work!  Thanks!
Offline zulios
« Reply #9 on: Sun, 28 July 2013, 16:27:20 »
That solution didn't work for me, Windows was not fast enough so most of the keypresses were sent somewhere else. Your pc might be more reactive than mine, but with Windows it will never be a long term solution I'm afraid.
Offline damorgue
« Reply #10 on: Sun, 28 July 2013, 16:32:36 »
Weird.
First off, could you confirm that it works when you press the combination slowly by yourself?
Are you certain that you have programmed it to press those ina  sequence and not press them all at the same time?
Does the Tipro programming software allow you to insert delays?
Offline funkymeeba
  • CRUMPULAR
« Reply #11 on: Sun, 28 July 2013, 16:34:51 »
I believe delays are possible with Tipro.
Offline zulios
« Reply #12 on: Sun, 28 July 2013, 17:37:39 »
@Damorgue: Yes I'm sure everything was OK, it worked sometimes and sometimes not depending on what programs were currently running.
I just had a look and you can indeed add delays between keypresses: short (100 ms) or long (1 second). That would be the solution. Believe me or not but I never paid attention to that before !
I'm currently happy as I am, still that's good to know in case I want to program more complicated macros in the future. Thanks :)
Offline davkol
  •  Post Editing Timeout
« Reply #13 on: Mon, 29 July 2013, 03:57:39 »
I don't have a tipro, but an elcom. I programmed the unused keys to F13+ (extra function keys like on old terminal boards) and then remapped them in software.
