Author Topic: Which wrist rest do you use?  (Read 14835 times)
Offline wellington1869
« on: Sat, 18 October 2008, 15:07:32 »
Especially interested in people using model-M sized bulky keyboards (which I think includes Filco, Scorpius M10, Endurapro, etc etc, which are around the same size and height, I think)
Do you find that you need a wrist rest with your keyboard? If so, which one are you using? Just a "generic" one or did you have to shop around to find one that worked well?
using: ms 7000/Das 3
Offline Ulysses31
« Reply #1 on: Sat, 18 October 2008, 15:27:20 »
I don't personally use one, since my hands tend to "float" over the keyboard when i'm typing, but then i'm not a guy who types for a living.  The Filco is one of the most compact full-sized keyboards (that have a numpad) out there, I don't think it's really comparable to the Model-M battleship :P.
Offline lowpoly
« Reply #2 on: Sat, 18 October 2008, 16:44:59 »
The wrist rest is only used for breaks, not during typing, IIRC.
Offline CaptCarrot
« Reply #3 on: Sat, 18 October 2008, 16:55:19 »
whatever table/desk/lap/knee/etc the kb is resting on ;)
Offline bigpook
« Reply #4 on: Sat, 18 October 2008, 17:03:13 »
I use a imak ergobead thingy.  It naturally conforms to my wrists and makes typing easier for me. Its much nicer than having my wrists rest on the desk itself.
« Reply #5 on: Sat, 18 October 2008, 17:30:35 »
Quote from: bigpook;9608
this looks good. staples has 'em, I think I'll check it out. I like that its malleable for minor height adjustment.
Offline bigpook
« Reply #6 on: Sat, 18 October 2008, 17:43:44 »
Right. It has these little beads that give away as your wrists rest on them.
Someone mentioned that their hands float as they type, but that doesn't work for me.
My elbows are resting on the arm rests of my chair, my wrists on the imak thingy, my hands on the keyboard.
Maybe that is not the correct form, but it works for me.
I should say that this is my setup at home, at work its completely different. I use a laptop and there are times I am programming a switch while sitting on the floor, or some crappy computer chair, or other sub-optimal sitting position.
But I get paid for doing it so it doesn't bother me so much.
Offline karlito
    • http://altitudegame.com
« Reply #7 on: Sat, 18 October 2008, 17:50:02 »
i use some memory foam thing from bestbuy... cant complain. it cost too much though ($20)
Offline bigpook
« Reply #8 on: Sat, 18 October 2008, 18:23:41 »
Offline itlnstln
« Reply #9 on: Sat, 18 October 2008, 20:36:38 »
I use a cheap $2 "thick-mousepad," old-school wrist rest for both my M and my Evolution.  I find that the gel and memory-foam types are too thick.  I like my rests at about 3/4".
« Reply #10 on: Sat, 18 October 2008, 20:41:12 »
ya me too. my wrists are always down on the table while typing, so unless its a slim keyboard I generally need something to prop them up.
Offline bigpook
« Reply #11 on: Sat, 18 October 2008, 21:49:20 »
I am curious as to what a "thick-mousepad" would be. My imak bead thing flattens out to about 3/4 inch which works well. I am using the HHKB keyboard now, but get the same effect with my model m's.
Offline itlnstln
« Reply #12 on: Mon, 20 October 2008, 06:04:29 »
This is the exact one(s) I have:
http://cgi.ebay.com/Wrist-Rest-American-MADE-THICK-Comfort-keyboard-2-PACK_W0QQitemZ310075319079QQcmdZViewItem?_trksid=p3286.m20.l1116
It is closed-cell foam with the standard (cheap) mousepad fabric on top.
Offline bigpook
« Reply #13 on: Mon, 20 October 2008, 07:33:44 »
Quote from: itlnstln;9687
That looks like it would work pretty well also. I wonder how it holds up over time. Does it get dirty? Can it be washed?
The one I have is some kind of fabric, I don't think it is machine washable but it has stayed clean for me so far. It helps that I don't eat at my desk.
Offline itlnstln
« Reply #14 on: Mon, 20 October 2008, 09:58:15 »
I have had mine for a couple of years now, and the fabric is still in place (i.e. not separating from the foam) and clean.  They are very easy to clean using water and dish soap (like Dawn).  I like them because they are soft but not squishy.  Since I slide my hands around to use the number pad, some of the gel/memory-foam rests take too long to compress to feel comfortable.  That, and it keeps it old-school. :)
Offline bigpook
« Reply #15 on: Mon, 20 October 2008, 11:21:12 »
I ordered one to try it out. I have a HHKB keyboard and I think I could trim the length down to size. It looks like it could be trimmed.
Offline bigpook
« Reply #16 on: Mon, 20 October 2008, 11:42:07 »
If it is solid can it be cut? I have a HHKB keyboard and wonder if it can be trimmed to size.
Offline bigpook
« Reply #17 on: Mon, 20 October 2008, 11:43:23 »
If it is solid, can it be trimmed to fit? I have a HHKB keyboard.
« Reply #18 on: Mon, 20 October 2008, 12:16:12 »
you must be some kind of superman... Fritos and computers were just *made* for each other ;)
Offline bigpook
« Reply #19 on: Mon, 20 October 2008, 12:22:55 »
I suppose thats better than eating cheetos.....
Offline itlnstln
« Reply #20 on: Mon, 20 October 2008, 13:46:01 »
Quote from: wellington1869;9697
I have no idea where, but I wrote a pretty lengthy diatribe on this board about eating at the keyboard.  If I remember correctly, the thread was about letters on the keys rubbing/coming off.  I don't know if it is an acute desire for clean equipment/workspace, or what, but I can't stand using someone's greasy, nasty keyboard.  That, and I really take pride in taking care of my things.  I have had my Evolution for about 3 or four months now, and it looks/works brand new, just like my 2 Model Ms.
Offline bigpook
« Reply #21 on: Mon, 20 October 2008, 13:59:19 »
How about some greasy wings and some ranch sauce.....
« Reply #22 on: Mon, 20 October 2008, 14:13:50 »
Quote from: bigpook;9708
Ok, now you've made me hungry... time for a snack break!
Offline lowpoly
« Reply #23 on: Mon, 20 October 2008, 14:17:14 »
Suntan lotion is really bad for electronic devices. My wife killed a digital camera and an iPod when that stuff spilled in her bag. Killed the exterior and the electronics. Thankfully, both the camera and the iPod were cheap models.
Offline bigpook
« Reply #24 on: Mon, 20 October 2008, 14:52:02 »
Quote from: lowpoly;9713
Well that sounds like it got soaked. I can see it ruining the equipment. How about if you have a film of suncreen on your hands and you are typing on a keyboard? Same probably goes for hand lotion. Would that have a bad effect on the keys?
If so, maybe lotion is like some low-level acid.
Offline itlnstln
« Reply #25 on: Mon, 20 October 2008, 14:53:29 »
iPod ... cheap
Wow.  I would have never thought to hear that in the same sentence (unless preceded by "not").  :)  I have a 4G 40GB iPod still holding strong.  I can't find a reason to upgrade yet other than disk space.  I would rather just replace the hard drive, though.  There is a lady at work that the NASTIEST kb ever.  It is pretty greasy (probably form hand lotion), and dust has caked to it in a pretty thick layer.  Sometimes, when she is out, I have to do some of her work from her computer.  I had to stop using her PC and just remote desktop to it.  I had to go wash my hands every time I used it.  Ugh.
Offline itlnstln
« Reply #26 on: Mon, 20 October 2008, 14:54:58 »
Hand lotion is pretty acidic, just like food grease.  Either can accelerate the smoothing of the keys' texture as well cause the rubbing off of the keys' letters.  Nasty stuff.
Offline lowpoly
« Reply #27 on: Mon, 20 October 2008, 15:05:02 »
Quote from: itlnstln;9716
It was a first gen iPod Shuffle.
Quote from: bigpook;9715
It actually ruined the exterior plastic as well. The silver coating of the camera went off in some places. Like the lotion dissolved the outmost surface. I'll see if I can find the camera and take some pics.
« Reply #28 on: Fri, 24 October 2008, 23:30:18 »
I checked out the IMAK ergobeads wrist rest (and others) at staples. The IMAK one is definitely very cool, and the 'beads' are very comfortable. But in the end I decided I wanted a very low profile wrist rest. The IMAK was squishy but didnt flatten as much as I was looking for.
The average wrist rest height seems to be 3/4 inches. There are several available at 1-inch and higher. There are very few available below 3/4 inch.
The Fellowes 58044 is .63 inches high (and very cheap, about 10 bucks on ebay).
In the end I wound up with a 3M WR315LE which is only about half-inch high. The lowest profile one that I could find. I think its intended to put on top of existing plastic hard wrist rests that are built into some keyboards, but for me actually this would work well on its own.
Offline Chloe
  • Switch Kitten
« Reply #29 on: Tue, 25 November 2008, 07:44:59 »
I'm looking for a wrist rest with a gentle slope. I don't like the feel of gel or plastic. Any ideas?
This Filco FKBPR/B looks quite comfy, but it's a bit too wide (18.5"):
http://66.102.9.104/translate_c?hl=en&sl=cn&u=http://www.b18.com.tw/product_info.php%3Fproducts_id%3D599
There's also this one by Elecom, but it's not wide enough for me. At 11" wide it would be ideal for a smaller board like the HHKB:
http://www.jlist.com/PRODUCT/MOH-012BK
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #30 on: Tue, 25 November 2008, 08:10:10 »
Quote from: Chloe;12360
Considering the web site above and the current topic, I'm surprised no one has mentioned this wrist rest yet (look at top of page):
http://www.jlist.com/ADULTTOYS/
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
« Reply #31 on: Tue, 25 November 2008, 09:34:52 »
Quote from: megarat;12364
lol. I was expecting worse after seeing the url ;)
Offline secularzarathustra
« Reply #32 on: Tue, 25 November 2008, 09:42:57 »
Quote from: itlnstln;9706
I second this wholeheartedly, I can't stand to eat at my desk. Coffee, alcohol and a little bud are all that can be partaken of, by anyone, at my desk.
Dark and the Desert and Destriers me ken,
And the Glaive and the Joust, and Paper and Pen.
« Reply #33 on: Tue, 25 November 2008, 10:16:44 »
Quote from: secularzarathustra;12380
funny, I regularly have 7-course meals while sitting at my desk. :)  Part of this is because computers/internet now provide both work and play in equal amounts. I used to eat in front of the tv, now its the computer. :)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #34 on: Tue, 25 November 2008, 15:33:14 »
I was expecting better!
Offline xsphat
  • Enlightened
« Reply #35 on: Tue, 25 November 2008, 15:35:47 »
I use a 3M WR320 for my wrist rest. It's an industrial job they sell with office supplies like keyboard trays and sh*t. This is my first one and I find it to be very comfortable and I don't mind that it doesn't match up with my keyboard in size. I use it for the mouse too.
Offline megarat
« Reply #36 on: Tue, 25 November 2008, 17:41:01 »
Solidarity, comrade.  I used to work alongside a IT desktop-support group (while my job wasn't desktop support, per se, I got to hear  their stories).  The number of keyboards that died due to the accumulation of years and years of food detritus was absolutely appalling.  Some of those keyboards were so filled up with crumbs and junk that you could actually use the principle of stratigraphy to determine which foodstuffs had been eaten when.  ("Hmm ... there are three layers of miscellaneous cruft between the cheese slice and the Ritz cracker fragment ... so the cheese predates the cracker by perhaps two years.")
Offline iMav
  • geekhack creator/founder
« Reply #37 on: Tue, 25 November 2008, 18:29:06 »
I'd rather drop a sandwich on my keyboard then a cup of coffee.  ;)
Nobody but me sits at my desk.
Offline itlnstln
« Reply #38 on: Tue, 25 November 2008, 23:06:37 »
Food comes nowhere close to my keyboards.  Actually, hands that have just touched food do not come close to my keyboards, either.  Like iMav. I am the only person that ever sits at my desk.
Offline xsphat
  • Enlightened
« Reply #39 on: Wed, 26 November 2008, 00:20:48 »
I use my Topre 86 as a microwave plate for oatmeal.
Offline lam47
« Reply #40 on: Fri, 28 November 2008, 07:57:36 »
Does anyone know what this one is. I really like it.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline Chloe
  • Switch Kitten
« Reply #41 on: Fri, 28 November 2008, 09:48:06 »
You could try asking at the blog:
http://6strings.tistory.com/20
I found a smaller Filco FKBPRM/B that looks just right:
http://leopold.co.kr/?doc=cart/item.php&it_id=1224744339
Offline lam47
« Reply #42 on: Fri, 28 November 2008, 10:05:12 »
I just want one with a bend in it like the one in the pic.
Anyone speak Korean?
Offline Chloe
  • Switch Kitten
« Reply #43 on: Fri, 28 November 2008, 10:19:00 »
Offline Chloe
  • Switch Kitten
« Reply #44 on: Fri, 28 November 2008, 10:21:14 »
Aww, they have Rilakkuma too!
http://item.rakuten.co.jp/jfstream/rk-ham-cr/
Offline lam47
« Reply #45 on: Fri, 28 November 2008, 10:23:26 »
You my friend are amazing!
Ive been searching for it too!
I just need to find one of those places that buy stuff for you now :)
Cheers Chloe!
Offline Chloe
  • Switch Kitten
« Reply #46 on: Fri, 28 November 2008, 10:35:07 »
You could use Crescent Shop. When I asked them for a quote for the Filco they sent me a link to Rakuten.
I'm still searching for one. I'm not sure if I want leather after all. If I find a nice one cheap enough I'm going to try Abidko since they also buy from Taiwan.
Offline Ulysses31
« Reply #47 on: Fri, 28 November 2008, 12:21:00 »
Does Abidko look legit to you?  If it is, I might FINALLY be able to order a KBtalking, or anything else from Inpad.com.tw.
Offline Chloe
  • Switch Kitten
Offline lam47
« Reply #49 on: Fri, 28 November 2008, 15:18:03 »
I've joined and sent a request to Crescent for the palm rest.
Will let you know if I get a response.
Im not 100% sure the request went through as I didn't get a confirmation or have anything showing in my account to suggest it.
Has anyone used them before?
