Author Topic: Stabilizer Clips  (Read 3605 times)
Offline driekus
Stabilizer Clips
« on: Fri, 26 July 2013, 22:16:21 »
I am building a custom keyboard using WASD components.
I plan on getting a steel plate laser cut and am comfortable with the switch dimensions however the placement and dimensions of stabilizer clips is a problem.
Can anyone help me out with this problem?
Offline alaricljs
  • I be WOT'ing all day...
Re: Stabilizer Clips
« Reply #1 on: Fri, 26 July 2013, 22:41:06 »
There's a diagram in this DIY Resource thread.
Filco w/ Imsto thick PBT
Offline driekus
« Reply #2 on: Sat, 27 July 2013, 08:58:56 »
Sorry I searched that thread but couldnt find it.
Could you tell me which link in the DIY Resource I should click I would appreciate it.
« Reply #3 on: Sat, 27 July 2013, 09:02:43 »
perhaps he was referring to this?
Costar stabilizer layout (thanks to bpiphany):
Offline kps
« Reply #4 on: Sat, 27 July 2013, 09:53:53 »
This thread on DT has some complete layouts including Costar stabilizer slots, mostly in DWG format.
« Reply #5 on: Sat, 27 July 2013, 10:21:56 »
Does anyone know the dimension 'A' for 6.25 spacebars? Cherry spec only has 7x.
Offline alaricljs
« Reply #6 on: Sat, 27 July 2013, 11:01:28 »
3 15/16"
Offline driekus
« Reply #7 on: Sat, 27 July 2013, 14:03:13 »
Excellent, the DWG format worked perfect for me and I got all the measurements that I needed.
Offline driekus
« Reply #8 on: Sat, 27 July 2013, 20:52:16 »
Here is my first attempt at bringing it together
There are two space bars (made using right shift keys). I also have a trackpad that will be salvaged from a thinkpad USB keyboard.
