Author Topic: Capcraft Hub - Updates & Tom Foolery Herein  (Read 2065714 times)
  • * Moderator
Re: Hand-e-Cap
« Reply #200 on: Mon, 26 August 2013, 23:29:10 »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Hand-e-Cap
« Reply #201 on: Mon, 26 August 2013, 23:56:00 »
 :p
Dood, that Batman cap turned out so well :)) Can't get over how cool it looks. Can't wait to see it get a paint job!!!
Offline Photoelectric
Re: Hand-e-Cap
« Reply #202 on: Tue, 27 August 2013, 00:34:10 »
Ohhh the front mustache dude--my new favorite!!!
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Hand-e-Cap
« Reply #203 on: Tue, 27 August 2013, 02:47:02 »
OH MY GOD
IT'S BURTON'S BATMAN
MUST HAVE
  • * Moderator
Re: Hand-e-Cap
« Reply #204 on: Tue, 27 August 2013, 21:44:42 »
Incoming disaster?
33290-0
Offline mkawa
Re: Hand-e-Cap
« Reply #205 on: Tue, 27 August 2013, 22:12:51 »
if you plan on sealing the pot with that model M, then i would say no. all that will happen is a slight hissing as the environment pressure in your garage rises < 1mmhg from atm
Offline domoaligato
Re: Hand-e-Cap
« Reply #206 on: Tue, 27 August 2013, 22:34:05 »
sir... do you know what the average rating on the safety valve is on that pot?
I have to upgrade the safety valve on mine because it sometime pops... keep that in mind.
also make sure that you use teflon tape on every single piece.
if the top leaks.... I removed mine and put in silicone molding as a gasket. just don't cure the silicone material with the top on the pot. it will never come off.
  • * Moderator
Re: Hand-e-Cap
« Reply #207 on: Tue, 27 August 2013, 23:00:41 »
The safety valve is rated for 80 PSI, the top has a silicon gasket installed, and all of the parts have been installed with teflon tape :)
Tested some of the equipment earlier.  I need to make sure I understand how the compressor works.  It has a gauge for tank pressure and a gauge for pressure in the line.  Would that line pressure also mean tank pressure at some point?  I bought the compressor that I did in hopes that I could install fewer parts, but I don't mind buying a gauge for the pot as well.
Offline domoaligato
Re: Hand-e-Cap
« Reply #208 on: Tue, 27 August 2013, 23:42:48 »
I have 2 gauges on my pot. one before the valve to let the air in and one on the pot where the paint is supposed to blow out.
pressure test the tank over night. if you get over 10 psi drop overnight then you have a major leak.
mix some dawn dish soap in some water and rub this on all the areas that could have a leak. it will blow little bubbles from the area that leaks.
  • * Moderator
Re: Hand-e-Cap
« Reply #209 on: Wed, 28 August 2013, 11:53:03 »
That's a good method to check the seals Domo.  Thanks for the advice.  I'm going to break in my pump tonight and check the seals.  Then we get to casting!
  • * Moderator
Re: Hand-e-Cap
« Reply #210 on: Wed, 28 August 2013, 23:22:52 »
no leaks... no leaks at all :D
« Last Edit: Wed, 28 August 2013, 23:50:38 by Binge »
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Hand-e-Cap
« Reply #211 on: Wed, 28 August 2013, 23:38:11 »
These aren't keycaps. This is art.
Re: Hand-e-Cap
« Reply #212 on: Thu, 29 August 2013, 07:36:56 »
I think you should do a circus performer set, it would be EPIC!
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: Hand-e-Cap
« Reply #213 on: Thu, 29 August 2013, 07:38:58 »
Binge those are fantastic! So great to see how far you've come in such a short amount of time  :thumb:
You seem to have a knack for tongues, any way you'd do me a Rolling Stone's inspired cap?
  • * Moderator
Re: Hand-e-Cap
« Reply #214 on: Thu, 29 August 2013, 10:47:05 »
I don't see why that would be an issue, but I might need reminding if another round starts.
Re: Hand-e-Cap
« Reply #215 on: Thu, 29 August 2013, 19:09:34 »
Who is the lucky person getting the mustache cap?  I wants it! :D
Offline bueller
  • MX baller
Re: Hand-e-Cap
« Reply #216 on: Thu, 29 August 2013, 19:26:45 »
YAY! I'll be camping out for another round then :)
  • * Moderator
Re: Hand-e-Cap
« Reply #217 on: Thu, 29 August 2013, 22:47:27 »
pretty sure that's Spamray's from R2.  He has a special set coming and that is one of them.
Oh and I put my first mold in the pressure pot tonight.  We'll see how things go :D
« Last Edit: Thu, 29 August 2013, 22:50:56 by Binge »
Re: Hand-e-Cap
« Reply #218 on: Thu, 29 August 2013, 22:55:35 »
:eek:
Offline MKULTRA
  • telling it how it is
Re: Hand-e-Cap
« Reply #219 on: Thu, 29 August 2013, 23:17:55 »
**** is about to get real
Offline domoaligato
Re: Hand-e-Cap
« Reply #220 on: Fri, 30 August 2013, 00:11:55 »
Good Luck!
Re: Hand-e-Cap
« Reply #221 on: Fri, 30 August 2013, 00:19:36 »
Binge how's my gas mask going :O
  • * Moderator
Re: Hand-e-Cap
« Reply #222 on: Fri, 30 August 2013, 01:29:37 »
I ordered paint especially for your cap.  Waiting for it to arrive.  It was shipped today. :)  You like sky blue, right?
Offline mkawa
Re: Hand-e-Cap
« Reply #223 on: Fri, 30 August 2013, 01:41:26 »
not all silicone sealant is the same! READ THE DATASHEET FOR YOUR SILICONE CAREFULLY. good rtv silicone sealants/gasket makers will give you ultimate tensile strength at their thickest allowable application most silicones can't stand up to that kind of heat and pressure.
the heavy duty permatex and motivative silicones are exactly what the doctor ordered for this application. in fact, i have this insane RTV159 that you could probably set a pressure pot cap out of.
Re: Hand-e-Cap
« Reply #224 on: Fri, 30 August 2013, 02:59:30 »
Ohhhhh yeaaaaaaaaaaaaaah
  • * Moderator
Re: Hand-e-Cap
« Reply #225 on: Fri, 30 August 2013, 09:06:35 »
Part 2 of the mold is poured, and once I arrive home at 8pm tonight we'll see results.  Part 1 had 0 bubbles and captured the subjects beautifully.
  • * Moderator
Re: Hand-e-Cap
« Reply #226 on: Fri, 30 August 2013, 10:29:42 »
33526-0
I know the picture above really sucks, but I thought it was worth illustrating what is happening with these molds.
Legos are pretty cool.  When pouring into legos the connection "bumps" are all accessible to the silicon.  This means that the silicon mold can be used in conjunction with regular legos.
In picture 1, I create a mold for my keycap tops.  The keycap bottoms are hollow and do not accept any silicon.  When the mold is released there is still air under the keys.
after the silicon cures the mold is flipped over and a lego structure is built on the mold to use as a large inlet for pouring.  That's right... I built a lego structure into the mold.  Why?  BECAUSE IT COULD WORK REALLY WELL >:O
« Last Edit: Fri, 30 August 2013, 10:44:39 by Binge »
Offline Thimplum
  • Master of all Ponies
Re: Hand-e-Cap
« Reply #227 on: Fri, 30 August 2013, 10:44:27 »
TP4 FOR ADMIN 2013
Offline domoaligato
Re: Hand-e-Cap
« Reply #228 on: Fri, 30 August 2013, 10:47:43 »
Here is one of mine.
  • * Moderator
Re: Hand-e-Cap
« Reply #229 on: Fri, 30 August 2013, 10:47:58 »
  • * Moderator
Re: Hand-e-Cap
« Reply #230 on: Sat, 31 August 2013, 00:26:12 »
nothing to see here... move along.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: Hand-e-Cap
« Reply #231 on: Sat, 31 August 2013, 01:50:51 »
Hand caps are looking real good! Nice work Binge!
Offline Glissant
Re: Hand-e-Cap
« Reply #232 on: Sat, 31 August 2013, 02:23:54 »
High five? Don't mind if I do!
  • * Moderator
Re: Hand-e-Cap
« Reply #233 on: Sat, 31 August 2013, 02:52:15 »
up high!
Offline domoaligato
Re: Hand-e-Cap
« Reply #234 on: Sat, 31 August 2013, 04:01:21 »
those look nice dude! can you tell the difference with the pressure pot vs before?
Offline i3oilermaker
  • techkeys.us
    • TechKeys
Re: Hand-e-Cap
« Reply #235 on: Sat, 31 August 2013, 12:25:09 »
Wow! No Bubbles!! Well done!
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: Hand-e-Cap
« Reply #236 on: Sat, 31 August 2013, 12:41:26 »
looks amazing man, cant wait to get my hands on another version of this
Offline Thimplum
Re: Hand-e-Cap
« Reply #237 on: Sat, 31 August 2013, 12:54:48 »
TP4 FOR ADMIN 2013
Offline MOZ
  • Busy making stuff
Re: Hand-e-Cap
« Reply #238 on: Sat, 31 August 2013, 13:24:47 »
My keyboard needs a hand!
Offline Dubsgalore
Re: Hand-e-Cap
« Reply #239 on: Sat, 31 August 2013, 20:10:28 »
up high!
they look great broski
slight work, slight work
Re: Hand-e-Cap
« Reply #240 on: Sat, 31 August 2013, 20:20:24 »
You're getting better with every new update!  I really like those molded caps!!  Very well done!
Offline mkawa
Re: Hand-e-Cap
« Reply #241 on: Sat, 31 August 2013, 20:38:21 »
dude those caps are HOT (in the colloquial sense).
  • * Moderator
Re: Hand-e-Cap
« Reply #242 on: Sat, 31 August 2013, 22:46:49 »
Oh my gosh we could all use one >.<  Gave the first Wasdson cap to my local financial backer.  He was thrilled with the results.  Prompted me to make a V3 hand-e-cap.  Keep your eyes peeled for updates.
Hands... huehuehue
We are the champions... my friend. :D
Yes!  I am very excited for all of the progress here.  :D
Yes the difference is pretty intense.  We should skype sometime and compare experiences.  I've been messing around with more of smooth-on's materials and came across a few great options.
Daww... maaan thank you :)
Offline MOZ
  • Busy making stuff
Re: Hand-e-Cap
« Reply #243 on: Sat, 31 August 2013, 22:49:19 »
I'm interested in the process of how you made the latest caps, mind sharing?
Offline vun
  • Just one more thing
Re: Hand-e-Cap
« Reply #244 on: Sat, 31 August 2013, 22:49:54 »
BINGE THIS IS SOME SERIOUS SESS GOING ON IN HERE
Keep up the good work
Just saying that does not look like a keycap mould
Offline mkawa
Re: Hand-e-Cap
« Reply #245 on: Sun, 01 September 2013, 00:29:06 »
so binge, remember how we were talking about partially cured thermosets? here's the thermoset bible in abridged form. the short answer is that most thermosets can be partially cured. what actually happens it that a thermoset is defined as a poly that goes from a goo full of monomers and slag and what have you and then as you put energy into it goes into a glass transition and then eventually becomes a gel. hence, there are three distinct phases to most thermosets during the application of energy
A: no energy. goo
B: vitrification. some monomers have joined into polymer networks. however, the compound is generally considered glass and the thermoset has not set, which is marked by:
C: gelification. this is a full cure and means that the thermoset has become a single infinitely long polymer network (that is, unlike say thermoplastics and most other polymers, there are no end-caps to the polymer chains, thermosets are defined by the fact that they form cyclical polymer networks at full cure, and actually less by the fact that energy makes them hard. what it specifically does to them is make these cyclical polymer networks.
you can suspend a thermoset in a state of vitrification with impurities (eg, air) removed. since it's glass at this point (B), it shouldn't take on additional air bubbles. obviously this depends on the thermoset material properties. sets for which state B is very soft are obviously going to have a harder time being partially set, for example.
so in short, all you need is one compession pot and a carefully chosen thermoset for an entire community to have molding material. pretty cool considering we went from 0 to 2 in a flash ;)
see: http://www.primethermosets.com/introtothermosets.pdf
Re: Hand-e-Cap
« Reply #246 on: Sun, 01 September 2013, 00:30:25 »
Yoo....... that's good
Offline domoaligato
Re: Hand-e-Cap
« Reply #247 on: Sun, 01 September 2013, 00:31:30 »
Toaster oven post cure ftw!
  • * Moderator
Re: Hand-e-Cap
« Reply #248 on: Sun, 01 September 2013, 01:29:23 »
This entire thread is all about how I've been making the caps.  I also did a live demo at keycon where I discussed a bit of the process.  Without making things too hard for me would you be able to narrow down your point on inquiry?  It would really help me deliver useful information :D
*SNIP*
Why work with thermosets that are partially cured instead of the two part chemicals domo and I have been using?  Maybe I missed something, and I'll do a bit more reading, but I'm really just trying to grasp the more learned understanding and try to apply it to what creative process exists.
Gotta work some Sifo-M green while I can.
Offline MOZ
  • Busy making stuff
Re: Hand-e-Cap
« Reply #249 on: Sun, 01 September 2013, 01:43:59 »
I get how you made the top of the keycap. I'm interested in how you did the stem.
