Author Topic: I need a PCB Mounted Keyboard.  (Read 1999 times)
Offline FrostyToast
  • Litshoard
« on: Tue, 30 July 2013, 14:18:07 »
I've been looking into mechanical keyboards lately, and while looking, I found a guide on how to change and modify key switches without desoldering; apparently you need a PCB mounted keyboard in order to do so. I have heard about cherry mx clear switches which seem to be exactly like browns, but stiffer with a more pronounced tactile bump and some people have said that cherry mx clears feel great if you mod them with a lighter spring.
So my questions is: What are some PCB mounted keyboards?
I have seen the Poker X keyboard which is PCB mounted, however my concern with that is that the PCB is fully exposed which will leave it very prone to being damaged. Are there any PCB mounted keyboards with a protective backplate, and if so, which keyboards should I be looking at?
Quote from: elton5354
Offline esoomenona
  • Gnillort?
Re: I need a PCB Mounted Keyboard.
« Reply #1 on: Tue, 30 July 2013, 14:24:22 »
Most Cherry G80 boards are PCB mounted.
You could also search for platemounted boards that have plates with switch openings that allow the housings to be removed without desoldering. Some examples are: Phantom, LZ-GH, TKL fitted with a Universal TKL plate, GH60, and others.
Offline FrostyToast
  • Litshoard
« Reply #2 on: Tue, 30 July 2013, 14:33:41 »
I think that the plate mounted keyboards with switch openings sounds very much like what I am looking for!
Offline MKULTRA
  • telling it how it is
« Reply #3 on: Tue, 30 July 2013, 14:40:54 »
The best way to achieve this is through custom keyboards like the GH60, because to add this custom plate to a Filco, QFR, or whatever else you will have to desolder all the switches anyways.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #4 on: Tue, 30 July 2013, 14:42:22 »
That is if he doesn't buy a prebuilt board with said plate.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline esoomenona
  • Gnillort?
« Reply #5 on: Tue, 30 July 2013, 14:44:04 »
That's why I suggested a TKL already fitted with one.
Offline MKULTRA
« Reply #6 on: Tue, 30 July 2013, 14:44:15 »
Are there any non used boards that come with that style of plate?
