Author Topic: Poker II Question  (Read 1737 times)
Offline mr. rampage
Poker II Question
« on: Fri, 02 August 2013, 14:04:56 »
Is there a way to swap the FN and WIN keys functions? As in I'd like the WIN key to be on the right side and the FN key to be on the left. I was able to get the FN key to the left with the dip switch, but wasn't able to get the WIN key to the right.
Offline pixel5
    • pixel5
Re: Poker II Question
« Reply #1 on: Fri, 02 August 2013, 14:08:48 »
The Fn key is hardware only. It cannot be switched with any other key.
Poker II
Quickfire Rapid
BUY MY CRAP
Offline mr. rampage
« Reply #2 on: Fri, 02 August 2013, 14:26:27 »
That's too bad. I guess it would require some re-wiring. Thanks for the reply.
Offline QueenXenon
  • Polymer Princess
« Reply #3 on: Fri, 02 August 2013, 14:33:37 »
Hardware only? Why is that the case for the function key, and what is the other option? programming it, like though the controller? Are non-hardware reassignments possible for all other keys? Is this just the case with Poker II?
Offline esoomenona
  • Gnillort?
« Reply #4 on: Fri, 02 August 2013, 14:35:09 »
It seems to be the case with most Function keys that they are hardware only. Pressing them doesn't change or signal the OS in anyway, thus they can't be intercepted and changed by it. You could change them via the controller, if the controller allowed it, which most consumer boards don't.
Offline Hypersphere
« Reply #5 on: Sat, 03 August 2013, 16:12:47 »
According to the Poker II manual, the Left Win can be swapped with the Fn key by turning DIP switch 3 on.
Offline Quardah
    • DeliTech
« Reply #6 on: Mon, 05 August 2013, 08:14:36 »
Boooooooom.
Words of wisdom. Tested and confirmed on my Poker II, This guy is damn right while all of you others are damn wrong.
Therefore Yes Mister Rampage you can switch both FN and Win key on your upcomming Poker II Keyboard. Another good reason to buy this Magnificent & Glorious, Incredible & Wonderful Keyboard that is the Poker II. You will love it, trust me. Available with 4 different MX switches options, it's a never look back.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
