Author Topic: lubing costar stabilizer?  (Read 8974 times)
Offline jonathanyu
« on: Mon, 05 August 2013, 00:23:55 »
Hi, i am using filco ninja right now, i found that the feel of the key that using costar stabilizer is not  very good(except the space bar). so i want to know that is that possible to lube the stabilizer? and what kind of lubricant should i use ?  :blank:
And also, why the space bar feel better that shift, enter, and backspace? especially the enter  :rolleyes:
Offline Rayne
  • For Science!
Re: lubing costar stabilizer?
« Reply #1 on: Mon, 05 August 2013, 00:42:39 »
here is a link to a video that WhiteFireDragon made about lubing stabilizers, both costar and cherry. Should have all the info you need :)
Offline jonathanyu
« Reply #2 on: Mon, 05 August 2013, 00:57:23 »
thank you  :p but what is that lubricant? is that a Krytox GPL-206 or 226?
Offline gnubag
« Reply #3 on: Mon, 05 August 2013, 01:10:58 »
you can actually use any decent grease you want since it isn't that noticeable on the stabs compared to switches.
Offline jonathanyu
« Reply #4 on: Mon, 05 August 2013, 01:22:31 »
i am thinking of that too, since the krytox is very expensive
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Mon, 05 August 2013, 01:57:13 »
The lube I used was Krytox GPL 205. Yes, it's rather expensive. Almost any lube should be ok, but just remember it has to be grease (not oil) and also metal and plastic safe. You could consider getting some great lube from this upcoming group buy for pretty cheap. I did not have this opportunity when I bought my stuff:
http://geekhack.org/index.php?topic=46191.0
Offline jonathanyu
« Reply #6 on: Mon, 05 August 2013, 09:40:54 »
 ;) thank you !
« Reply #7 on: Mon, 05 August 2013, 09:42:09 »
The_Beast is forever telling me that "Superlube" will work great on stabilizers and that's what WASD uses as well.
Offline jonathanyu
« Reply #8 on: Mon, 05 August 2013, 09:49:19 »
superlube, ok one more choice thank you! ;)
« Reply #9 on: Mon, 05 August 2013, 09:51:00 »
I also forgot to say that The_Beast told me he snagged Superlube from a Home Depot/Lowes too so that might help you out ^__^
Offline jonathanyu
« Reply #10 on: Mon, 05 August 2013, 10:29:55 »
home depot have it? going check out today!  ;)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #11 on: Mon, 05 August 2013, 19:22:10 »
I actually got it at Ace Hardware........
« Reply #12 on: Mon, 05 August 2013, 19:27:05 »
It's also dirt cheap on Amazon.  Perfect if you have Prime.
Offline Danule
« Reply #13 on: Mon, 05 August 2013, 21:32:48 »
the spacebar probably feels better to you cause it comes pre lubed.  I had to lube my backspace enter and shift keys on my filco to make them smoother and quieter.
45g Brown Brown Blue
