Author Topic: Keyboard for office  (Read 4119 times)
Offline Jixr
Keyboard for office
« on: Tue, 06 August 2013, 09:28:10 »
Hey everyone, i'm looking at buying a quickfire xt that will be used at my office.
Ive 'tested' blues at work, and no one has asked me about the sound yet, but i'm a bit worried.
I absolutely love blues out of what i've tried ( Red, black, and blue ) I'm not a fan of the linear switch ( for typing anyway )
but i'm considering browns, but don't have a way to test them ( no local shop has a brown )
I can also just order blues and o-ring it.
Ideas, suggestions?
Re: Keyboard for office
« Reply #1 on: Tue, 06 August 2013, 09:29:43 »
I use a Filco MJ2 with Blues. If you're really worried about the sound, get a Matias Quiet Pro or mod your board to Jailhouse Blues. Those are the quietest switches I've tried.
Any of the MX switches will be louder than the RD. But my office isn't that quiet so I can get away with Blues.
Offline SidusNare
  • Do, or do not; there is no try.
« Reply #2 on: Tue, 06 August 2013, 09:30:13 »
I sit in a cube farm and use a Leopold with MX Blues on it, no problem, its just everyone else knows when you are working or not.
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
« Reply #3 on: Tue, 06 August 2013, 09:32:22 »
I really don't care for browns. If you like blues and the noise isn't an issue just go with it.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #4 on: Tue, 06 August 2013, 09:42:10 »
If you've got the money a silent Realforce will do you well. I love mine in the office. Otherwise, I'd say blacks would probably be the quietest for a normal typist on MX, though the TK doesn't come with them. At that point you might as well go with blues.
TOO BAD FOR YOU
              Phantom 62g MX Whites
« Reply #5 on: Tue, 06 August 2013, 09:42:48 »
Ooo yeah, forgot the Silent Topre boards were really quiet as well.
Offline Jixr
« Reply #6 on: Tue, 06 August 2013, 09:52:17 »
yeah, I'm dead set on the QF-XT.
but zero people ( aside from our old school hippy IT guy ) knows what a mech keyboard is, and I'm planning a highly custom keyboard, so I wanna get it right.
EDIT: the board comes in greens ( green, blue, red, and brown ) as well. ( finding one may be a problem though )
« Last Edit: Tue, 06 August 2013, 09:55:49 by Jixr »
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #7 on: Tue, 06 August 2013, 09:53:01 »
I'f you're thocking away on it it's about on par with a normal rubber dome, but if you're a proper touch typist and type very lightly on the thing you can't even hear it.
If you're planning on customizing, do NOT get a TK. It's got a non standard spacing and key size in the bottom row that'll make finding full replacement sets a nightmare.
TOO BAD FOR YOU
Offline Jixr
« Reply #8 on: Tue, 06 August 2013, 09:59:49 »
i'm getting the XT version ( a ten-keyed qfr ) the tk is the smaller form factor crap board. ( the xt is only a month old )
http://coolermaster-usa.com/press_release/quickfire_xt/quickfire_xt.html
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #9 on: Tue, 06 August 2013, 10:03:25 »
Totally my bad. Too many two-letter naming conventions going on with CM.
TOO BAD FOR YOU
« Reply #10 on: Tue, 06 August 2013, 10:09:45 »
I wonder what they really meant....I mean TK = ten key I wonder what the XT stands for?
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #11 on: Tue, 06 August 2013, 10:11:19 »
eXTended?
TOO BAD FOR YOU
Offline Jixr
« Reply #12 on: Tue, 06 August 2013, 10:14:55 »
i'm pretty OCD about hardware design, and the qfr/filco is the only 'perfect' board in my eyes, no extra crap. clean simple and minimal. Basically every razor products is my OCD nightmare ( though i have to use a few of their products as there is no alternatives )
« Reply #13 on: Tue, 06 August 2013, 10:21:18 »
eXTended?
seems legit
Offline Danule
« Reply #14 on: Tue, 06 August 2013, 10:21:57 »
Keep in mind that even if no one has said anything there is still a chance there are people in your office who find your keyboard annoying and are just too polite to say anything.
45g Brown Brown Blue
Offline Jixr
« Reply #15 on: Tue, 06 August 2013, 10:23:37 »
dang, there is about a $20 difference between greens and blues, i'll just go with blues then.
I couldn't find any decent reviews of this board, so once I get it in ( i'll order it today ) I suppose i'll make a detailed write up and such.
Offline Jixr
« Reply #16 on: Tue, 06 August 2013, 10:25:43 »
Keep in mind that even if no one has said anything there is still a chance there are people in your office who find your co-workers annoying and are just too polite to say anything.
;D we have a lady here I call a 'professional hater' and really I only have 1 person close to me,
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #17 on: Tue, 06 August 2013, 10:26:04 »
http://geekhack.org/index.php?topic=38930.0
this guy is selling XT's for cheap
Offline jameslr
« Reply #18 on: Tue, 06 August 2013, 10:28:00 »
This pretty much. If you have to have a mechanical keyboard in an office environment then you should get something quiet. I use blues at home, and I enjoy using them. I have membrane crap at the office and my environment is quiet - even with white noise machines you can hear someone typing or talking on the phone 3 or 4 cubes over and our cube walls are high. If I brought my keyboard with blues into the office it would probably get "sabotaged" while I was away :)
I don't type a lot, but a fair amount. How much quieter do the o-rings make blues? I've seen so many comparison videos on youtube, but they don't really help me out much because I have no frame of reference when it comes to ambient noise levels that I'm used to. I would like to see a db meter comparison of the two. (with and without o-rings).
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
« Reply #19 on: Tue, 06 August 2013, 10:51:11 »
Thinking about this some more, no one has ever complained about my clears.
Offline Jixr
« Reply #20 on: Tue, 06 August 2013, 13:52:45 »
dang, just realized the xt won't ship for another few weeks on amazon.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #21 on: Tue, 06 August 2013, 13:57:29 »
Did you look at the link some other member posted of the guy selling XT's of each color for mad cheap?
TOO BAD FOR YOU
« Reply #22 on: Tue, 06 August 2013, 14:00:28 »
I think the WASD video is really good. You can find it here along with my own views on o-rings.
When you have people yelling into phones, constant cursing, smashing of rubber domes, and the drone of air conditioning/heat, Blues don't really get noticed. And I've never had anyone complain to me about my board. Trust me, the people who sit near me would let me know if it was annoying.
Offline Quardah
    • DeliTech
« Reply #23 on: Tue, 06 August 2013, 14:15:59 »
Bro,
If they complain...
I'm pretty sure...
You can...
Tell 'em to....
...Fukk off?
No but really, who cares what people thinks.
On the other hand,
Try browns, they are pretty slick.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline tbc
« Reply #24 on: Tue, 06 August 2013, 16:41:10 »
eXTended?
seems legit
you're sure it's not 'eXTreme'?
