Author Topic: .  (Read 1766 times)
Offline esoomenona
  • Gnillort?
« on: Tue, 06 August 2013, 21:44:03 »
« Last Edit: Fri, 17 October 2014, 18:00:27 by esoomenona »
Offline daerid
    • Rossipedia
Re: Help from someone with HHKB and 23U/B
« Reply #1 on: Tue, 06 August 2013, 23:01:29 »
I've never gotten this to work on an external numpad. The way Windows handles the Unicode key combinations, the alt key needs to be from the same device as the numpad keys. Separate devices won't work (AFAIK).
Offline esoomenona
  • Gnillort?
« Reply #2 on: Tue, 06 August 2013, 23:06:07 »
« Last Edit: Fri, 17 October 2014, 18:00:36 by esoomenona »
Offline daerid
    • Rossipedia
« Reply #3 on: Wed, 07 August 2013, 00:35:59 »
Not sure about the programmable num pad, but using AHK to remap a key to alt should work in theory.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Wed, 07 August 2013, 11:38:51 »
« Last Edit: Fri, 17 October 2014, 18:00:48 by esoomenona »
« Reply #5 on: Wed, 07 August 2013, 11:44:13 »
What does this do exactly moose?
Offline esoomenona
  • Gnillort?
« Reply #6 on: Wed, 07 August 2013, 11:49:52 »
« Last Edit: Fri, 17 October 2014, 18:00:57 by esoomenona »
« Reply #7 on: Wed, 07 August 2013, 11:57:36 »
I've known about these but only really used this one alt + 0176 ° (degree)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #8 on: Wed, 07 August 2013, 12:07:11 »
° Hey I can do it with the embedded numpad on my 87u :)
TOO BAD FOR YOU
              Phantom 62g MX Whites
