Author Topic: red alert and klaxon?  (Read 2937 times)
Offline jonathanyu
« on: Thu, 08 August 2013, 17:23:03 »
Hi, i have found a lot of picture of a keycap that is red on white and white on red.
After some research, i found there is klaxon and red alert, and that look very similar.
So i want to ask, what kind of different do they have? or they are just the same?
Offline Kabuks
Re: red alert and klaxon?
« Reply #1 on: Thu, 08 August 2013, 17:28:20 »
They used a slightly different red for klaxon cause SP was not carrying the original red from red alert when the klaxon GB happened. The difference isn't that noticeable though.
Offline jonathanyu
« Reply #2 on: Thu, 08 August 2013, 17:29:53 »
so the only different is the color of the red?
Offline Kabuks
« Reply #3 on: Thu, 08 August 2013, 17:30:29 »
Yes.
« Reply #4 on: Thu, 08 August 2013, 17:33:11 »
I think the plastic is slightly thinner on the Klaxon as well, but that's just comparing a RA arrow set against a full Klaxon set.
Offline jonathanyu
« Reply #5 on: Thu, 08 August 2013, 17:33:33 »
does the klaxon set also have the red on white modifier set? because i miss both of the groupbuy , so i don't know much of them, but i want it
Offline Xenderwind
« Reply #6 on: Thu, 08 August 2013, 17:40:34 »
Klaxon had RoG, RoW, and WoR parts.  check the groupbuy thread
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #7 on: Thu, 08 August 2013, 17:41:34 »
white on red and red on grey mods for klaxon. F1-4 and F9-12 are red on white though.
Offline jonathanyu
« Reply #8 on: Thu, 08 August 2013, 17:52:19 »
thank you :D i know what are they now
Offline Leslieann
« Reply #9 on: Thu, 08 August 2013, 17:54:07 »
There are several minor differences.
Red Alert 1 used 7bit symbols.
Red Alert 2 (RA2) used text.
Klaxxon used text and had more color options.
RA2 and Klaxxon both have swirling in the White on Red (WoR) keycaps, while both have it, it's more noticeable severe on RA2. Another difference as mentioned is that one of the three used a different red. Trying to discern between WoR/RoW Klaxxon and RA2 keys is difficult, I have to keep them separated or they will get mixed up.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
