Author Topic: Do DSI and Keycool have the same profile keycaps?  (Read 2345 times)
Offline geekhack360
« on: Sat, 10 August 2013, 19:24:44 »
I have a DSI left handed keyboard*, nd I want to put on some colored modifier and win keycaps, the best deal I've found is a set made by keycool.
I’m a newb to the keyboard world, and I’ve skimmed over the forum a bit and apparently
Some keycaps are different profiles.
My question is do DSI and Keycool have the same profile keycaps?
Thanks.
* http://www.dsi-keyboards.com/dsi-left-handed-keyboard-usb-with-cherry-mechanical-key-switches.aspx
Offline geekhack360
Re: Do DSI and Keycool have the same profile keycaps?
« Reply #1 on: Sat, 24 August 2013, 02:12:12 »
No one knows?
I can pop off the keycaps and take photos or give their measurements with a caliper if that would help.
« Reply #2 on: Sat, 24 August 2013, 03:51:10 »
My KeyCool is at work, but from memory the keycaps are OEM profile.
I do not have DSI for comparison.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 24 August 2013, 09:09:46 »
Yes you should be good to go. Any OEM profile keycaps should match up with the stock keys you have on your DSI. Depending on how the key mounts on the enter, the aftermarket steelseries sets might be 100% compatible as well if you wanted to replace them all with some nicer set of PBT or whatever.
Offline geekhack360
« Reply #4 on: Tue, 03 September 2013, 20:50:56 »
Thanks guys, for the info.
