Author Topic: whats the name and where do i get this keyset?  (Read 6926 times)
Offline oppz197
  • Hai there
« on: Sun, 11 August 2013, 17:58:18 »
I have seen alot of people playing around with this set
( The picture isnt mine )
I know originative and imstro has it but its kinda expensive
Re: whats the name and where do i get this keyset?
« Reply #1 on: Sun, 11 August 2013, 18:31:10 »
It is a replica of Cherry doubleshot or dye-sub.
If you are lucky, you could find a original Cherry G80-3000 or G81-3000 keyboard with doubleshot keys on eBay. It would give you all keycaps except the Caps Lock, which is centre-stemmed on only one or two rarer  keyboard models in the G80 and G81 series.
(I would be surprised if the GH60 keyboard did not support offset-stemmed Caps Locks though, if that is what you want to put the keys on)
« Last Edit: Sun, 11 August 2013, 18:34:30 by Findecanor »
Offline Dubsgalore
« Reply #2 on: Sun, 11 August 2013, 18:32:42 »
I would be surprised if the GH60 keyboard did not support offset-stemmed Caps Locks though.
it supports off centered caps locks
Offline oppz197
  • Hai there
« Reply #3 on: Sun, 11 August 2013, 18:37:10 »
If you are lucky, you could find a original Cherry G80-3000 or G81-3000 keyboard with doubleshot keys on eBay. It would give you all keycaps except the Caps Lock, which is centre-stemmed on only a handful keyboards.
I found this
But it seems like the legends are not that thick and dark
Offline Hypersphere
« Reply #4 on: Sun, 11 August 2013, 18:48:09 »
You can get this from Originative (www.originativeco.com).  It is called "classic beige key set". It is available in blue or black font for $99.00.
Offline oppz197
  • Hai there
« Reply #5 on: Sun, 11 August 2013, 18:49:58 »
Yea I already know, Looking around if there is cheaper ways to get them
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Sun, 11 August 2013, 18:50:43 »
With 1.25 mods, I highly doubt it since you'll need a moogle kit which is stupid expensive for what it is.
Offline oppz197
  • Hai there
« Reply #7 on: Sun, 11 August 2013, 19:21:46 »
What do you guys think about the set i found
Do you guys think it is dye/ double shot?
Btw Can i uses MY Switches Keycaps?
Offline Dubsgalore
« Reply #8 on: Sun, 11 August 2013, 20:40:14 »
hard to tell whether it's dye sub or DS just from that front photo...i would guess dye-sub...
to my knowledge, you can use MY caps on MX, but not MX caps on MY
Offline calavera
« Reply #9 on: Sun, 11 August 2013, 20:44:11 »
****ty pic but I think those are laser edged key caps.
Offline Dubsgalore
« Reply #10 on: Sun, 11 August 2013, 20:54:04 »
^^^ looks most like lasered caps...idk why i didnt think of that hahah
i do know from a friend that cherry makes 1.25 mods, but with the lasered method, so it would make sense if it were original cherry
that picture you posted looks very much like lasered
« Reply #11 on: Sun, 11 August 2013, 20:57:00 »
They're interchangable.
Offline Dubsgalore
« Reply #12 on: Sun, 11 August 2013, 21:04:21 »
ah i heard wrong
thnx
Offline oppz197
  • Hai there
Offline oppz197
  • Hai there
« Reply #14 on: Sun, 11 August 2013, 21:29:00 »
How do i tell if they keys are double shot Dyesub or lasered
« Reply #15 on: Sun, 11 August 2013, 21:31:44 »
Double-shot is obvious (look underneath).
Otherwise: http://geekhack.org/index.php?topic=46728.0
Offline oppz197
  • Hai there
« Reply #16 on: Sun, 11 August 2013, 21:37:34 »
So you think that keyboard will fit ny qfr ?
« Reply #17 on: Sun, 11 August 2013, 21:40:25 »
Not the caps lock.
Offline calavera
« Reply #18 on: Sun, 11 August 2013, 21:46:50 »
First letter after G8x tells what key caps they are. L= laser, H=double shot, S=dyesub.
You wont find a magical board that has all key caps be double shot and be compatible so either lurk in the classifieds hoping for a used originative or imsto set to pop up or just buy from them directly. There's a reason orginative is more expensive, it has cherry thickness and comes with all compatible mods. Otherwise get some cheap ass ducky keycap sets and call it a day.
Offline oppz197
  • Hai there
« Reply #19 on: Sun, 11 August 2013, 21:59:23 »
G8x? G81 3000LPNUS  So i amuse that is a laser print cap? ?
Offline Dubsgalore
« Reply #20 on: Sun, 11 August 2013, 22:17:00 »
first letter after the g8x-xxxx
Offline calavera
« Reply #21 on: Sun, 11 August 2013, 22:22:06 »
yep.
Offline oppz197
  • Hai there
« Reply #22 on: Sun, 11 August 2013, 22:33:45 »
GOD DAMNIT s0 hard ta find a keyset  :'(
Offline oppz197
  • Hai there
« Reply #23 on: Sun, 11 August 2013, 22:38:55 »
Well you guys saved me some money  :-* Inreturn I will share some unexpected find
http://item.taobao.com/item.htm?spm=a1z0k.1000775.1.11.tFk4h4&id=21624135066
Offline bazemk1979
« Reply #24 on: Sun, 11 August 2013, 22:39:21 »
I have used one with minimal wear, almost no shine.... how much you are looking to spend though? btw keys are from this type of board
« Reply #25 on: Mon, 12 August 2013, 09:32:54 »
CHERRY-G81-3000LPNUS-PS2-Keyboard
L = Lasered.
H = Double-shot moulded
S = Dye-sublimated
See more about Cherry article numbers in the Deskthority Wiki.
Offline esoomenona
  • Gnillort?
« Reply #26 on: Mon, 12 August 2013, 09:39:22 »
Finding this set for cheaper than the set available at originativeco.com will be near impossible, unless you're willing to accept a shiny set.
« Reply #27 on: Mon, 12 August 2013, 10:35:14 »
The keyboard pictured has an SP moogle kit and capslock.
Your best option is either to stalk ebay for an MY with doubleshots and add a moogle kit, or to just order it from originitive (which has the benefit of having proper profile on the bottom row)
Offline Hypersphere
« Reply #28 on: Mon, 12 August 2013, 10:38:07 »
I agree. The Originative sets are beautiful and quite reasonable in price, considering the quality. I do not think you find a better set in terms of appearance. The only thing IMO that would make the set better is if it were dye-sub thick PBT instead of double-shot ABS; this would improve the feel of the keycaps but not necessarily the appearance. I have seen a similar set from geek_feng on eBay for about 95 USD that is dye-sub thick PBT, but because of a production error, the non-stepped caps lock is white instead of gray. To make it right would require finding a light gray non-stepped caps lock, but it is doubtful that you could match the color exactly.
« Reply #29 on: Mon, 12 August 2013, 10:43:59 »
Your comparing GMK double shot ABS with Imsto thick PBT....totally different....both have their fans but it's like comparing apples to oranges....
sherry does sell pbt fyi....http://originativeco.com/shop/keysets/product/418-pbt-dye-sublimation-85-keyset
Offline Hypersphere
« Reply #30 on: Mon, 12 August 2013, 10:51:48 »
Yes, I tried to make the distinction between double-shot ABS and dye-sub PBT. You are definitely correct that these are two very different things.
Offline oppz197
  • Hai there
« Reply #31 on: Mon, 12 August 2013, 12:55:39 »
Now I understand the difference :D Anyone knows how much is a moogle kit? I saw a wyse on techkey for 40something ~>~
« Reply #32 on: Mon, 12 August 2013, 12:57:06 »
A moogle for a WYSE? You answered your own question. They're expensive.
Offline esoomenona
  • Gnillort?
« Reply #33 on: Tue, 13 August 2013, 05:54:51 »
The WYSE moogle was a bit expensive. You can usually get moogle for around$25-35 or so. They haven't been made in awhile, so... And what with the GMK going on, and the fact that it seems a lot of people these days are opposed to spending money on certain things, well...
