Author Topic: das III switches: tabs visible?  (Read 2922 times)
Offline wellington1869
« on: Sat, 08 November 2008, 00:56:49 »
Does anyone know if the cherry switches on the das III are flush mounted with the backplate (making the little tabs on the switches not accessible) or if its possible to access the tabs (and thus pop off the top of the keyswitch to access the spring and the stem)?
thanks!
using: ms 7000/Das 3
Offline lowpoly
« Reply #1 on: Sat, 08 November 2008, 04:57:59 »
If somebody opens his/her Das III please check the pcb for mfgr logos/names. I'm curious as to who actually does the production.
« Reply #2 on: Sat, 08 November 2008, 05:01:39 »
Quote from: lowpoly;10489
If somebody opens his/her Das III please check the pcb for mfgr logos/names. I'm curious who actually does the production.
I thought it was a rebranded cherry g80-3000? With the III I think they only added the usb hub and changed the form factor, right?
Offline alpslover
« Reply #3 on: Sat, 08 November 2008, 09:09:45 »
Quote from: wellington1869;10486
they're plate mounted.
« Reply #4 on: Sat, 08 November 2008, 09:54:58 »
Quote from: alpslover;10497
crap. ok thanks.
Offline lowpoly
« Reply #5 on: Sat, 08 November 2008, 11:13:51 »
That was the Das II. The III is made in Taiwan, IIRC.
