Author Topic: Topre vs MX  (Read 5969 times)
Offline GeeGee
  • ㅈ ㅈ
Topre vs MX
« on: Tue, 13 August 2013, 09:13:47 »
Hey guys,
I was wondering which switch is better, because I've only used mx switches so far. I should probably ask what the pros and cons for each switch are, since the awnser most likely won't be as easy as 'X is better than Y'.
Thanks in advance :)
Ducky Shine 2 with Blues
Poker 2 with Reds
KMAC Korean Custom with Clears
ReΛlforce 87u 55g
456GT
Offline GeeGee
  • ㅈ ㅈ
Poker 2 with Reds
ReΛlforce 87u 55g
456GT
Re: Topre vs MX
« Reply #3 on: Tue, 13 August 2013, 09:38:49 »
No problem
Offline Skull_Angel
Re: Topre vs MX
« Reply #4 on: Tue, 13 August 2013, 13:35:22 »
The basic TL;DR is that "it's subjective".
Re: Topre vs MX
« Reply #5 on: Tue, 13 August 2013, 17:35:17 »
The best one is better than the other one.
Try both.
Own both.
Then get a buckling spring keyboard ;)
Offline daerid
    • Rossipedia
Re: Topre vs MX
« Reply #7 on: Tue, 13 August 2013, 18:00:58 »
^^^^ Sticky that please.
Offline GeeGee
  • ㅈ ㅈ
Re: Topre vs MX
« Reply #8 on: Wed, 14 August 2013, 06:40:30 »
Try both.
Own both.
I'll do just that. Thanks for the advice ;)
Poker 2 with Reds
ReΛlforce 87u 55g
456GT
Offline vsdubstep
Re: Topre vs MX
« Reply #9 on: Wed, 14 August 2013, 10:28:37 »
Yeah it's pretty subjective. Topre is pretty much the highest quality rubber dome there is. With MX the highest quality is a tuned, lubed, and stickered switch. Personally i find both to be about equally enjoyable, but with most people it seems to be one way or the other. And just because Topre is a rubber dome doesn't mean it's bad, because most rubber domes are cheap and quite terrible. But then again there are some crappy mech switches too that no one has ever heard of.
Offline jameslr
Re: Topre vs MX
« Reply #10 on: Wed, 14 August 2013, 10:35:45 »
I own both, and I can honestly say I like both equally. If you like heavier keys and a nice heavy response feedback, get the Topre. I have a 55g uniform Topre Realforce and it's the highest quality keyboard I have ever typed on. In build quality the Topre is much better than most other MX keyboards. Only one that comes close I think is probably Filco (from manufactured boards anyway).
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: Topre vs MX
« Reply #11 on: Wed, 14 August 2013, 10:42:10 »
I can agree to an extent with this. I enjoy both, and there is a strange phenomenon with Topre that is, though the switch is 55g or 45g, it feels a lot heavier if you were to compare it to an MX switch. This is because the massive tactile bump the Topre domes have in their nature. I'll say now my 45g uniform feels heavier than my 62g whites, but it isn't tiring at all. All Topre boards are solid boards that are built to last. The fact that it doesn't rely on contact makes it a board that can last for a lifetime granted you take care of it.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline mauri
Re: Topre vs MX
« Reply #12 on: Wed, 14 August 2013, 11:10:38 »
inb4 my
I AM BABAR KING OF THE ELEPHANTS
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Topre vs MX
« Reply #13 on: Wed, 14 August 2013, 11:47:50 »
Why are you guys still discussing this? It has been thoroughly beaten to death and then some.
Offline Michael
  • Formerly Bro Caps
Re: Topre vs MX
« Reply #14 on: Wed, 14 August 2013, 11:52:28 »
^ This x10000000000000000000000000000000000000
Offline iri
Re: Topre vs MX
« Reply #15 on: Wed, 14 August 2013, 12:11:33 »
i'd ban for creating such threads
-Ray Bradbury
Offline GeeGee
  • ㅈ ㅈ
Re: Topre vs MX
« Reply #16 on: Wed, 14 August 2013, 16:29:44 »
Now I'm sad ;_;
Sorry for wasting your time
Poker 2 with Reds
ReΛlforce 87u 55g
456GT
Re: Topre vs MX
« Reply #17 on: Wed, 14 August 2013, 16:30:56 »
horsemeat....mmmmmm
Offline mauri
Re: Topre vs MX
« Reply #18 on: Wed, 14 August 2013, 16:31:50 »
horsemeat....mmmmmm
IN MY LASAGNA?
blasphemous
Offline iri
Re: Topre vs MX
« Reply #19 on: Thu, 15 August 2013, 03:15:11 »
horse meat is healthy!!
-Ray Bradbury
Re: Topre vs MX
« Reply #20 on: Thu, 15 August 2013, 05:29:37 »
Especially when it is running around on the fields.
Offline TheQsanity
  • SmallFry Lovin'
Re: Topre vs MX
« Reply #21 on: Fri, 16 August 2013, 06:11:40 »
Can we mod them with Korean springs?
SmallFry! <3
Offline MJ45
  • HHKB Pro
Re: Topre vs MX
« Reply #22 on: Fri, 16 August 2013, 06:19:41 »
They come with Japanese springs that are superior to Korean springs.
Offline TheQsanity
  • SmallFry Lovin'
Re: Topre vs MX
« Reply #23 on: Fri, 16 August 2013, 06:21:28 »
What sounds better? Model M with the Japanese springs they come with or Model M with Moded Korean springs?
Anywho, Can I get them in 50g?
SmallFry! <3
Offline insilica
  • Keyboard Geeza
Re: Topre vs MX
« Reply #24 on: Fri, 16 August 2013, 06:35:47 »
Now I'm sad ;_;
Don't be sorry, just search. I think banning someone for asking a question (especially a newbe) no matter how irritating is just wrong.
As suggested read up on the matter.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Re: Topre vs MX
« Reply #25 on: Fri, 16 August 2013, 07:25:04 »
But are they gold?
Offline TheQsanity
  • SmallFry Lovin'
Re: Topre vs MX
« Reply #26 on: Fri, 16 August 2013, 07:27:28 »
But are they gold?
Hahaa. We soo need a buckling spring keyboard spring GB. Maybe someone that is active on the Korean community could suggest it to the vendors overthere.
SmallFry! <3
Re: Topre vs MX
« Reply #27 on: Fri, 16 August 2013, 07:29:47 »
But are they gold?
How about anodized springs?? Then we could get purple ones!!
Offline TheQsanity
  • SmallFry Lovin'
Re: Topre vs MX
« Reply #28 on: Fri, 16 August 2013, 07:33:29 »
But are they gold?
Yeah! It will be protected from the elements! We can forget our keyboards outside whenever we want!
SmallFry! <3
Re: Topre vs MX
« Reply #29 on: Fri, 16 August 2013, 07:35:33 »
But are they gold?
OR we can use our keyboards outside whenever we want...I always wanted to take my model m camping in case I run across a bear, so I can use it for protection.
Offline TheQsanity
  • SmallFry Lovin'
Re: Topre vs MX
« Reply #30 on: Fri, 16 August 2013, 07:39:21 »
But are they gold?
I'd rather use it for rowing a boat. Nothing feels better than knowing when you get tactile feedback while paddling.
SmallFry! <3
Re: Topre vs MX
« Reply #31 on: Fri, 16 August 2013, 07:47:55 »
But are they gold?
mmmmmmm, tactile pudding.....oh wait you said paddling.....that might be nice to.
Offline TheQsanity
  • SmallFry Lovin'
Re: Topre vs MX
« Reply #32 on: Fri, 16 August 2013, 07:51:26 »
But are they gold?
We can give them out to bears. So they have something reliable to use that looks nice too.
SmallFry! <3
Offline MJ45
  • HHKB Pro
Re: Topre vs MX
« Reply #33 on: Fri, 16 August 2013, 10:37:44 »
But are they gold?
A BS keyboard would make a better boat Anchor than a Paddle!
Re: Topre vs MX
« Reply #34 on: Fri, 16 August 2013, 23:16:00 »
I must be weird - I use my Model M for typing on.
