Author Topic: [FS] ceamocaps - Custom Engraved Acrylic Keycaps Protokeys  (Read 154540 times)
Offline MTManiac
Re: [FS] ceamocaps - Custom Engraved Acrylic Keycaps Protokeys
« Reply #300 on: Wed, 04 September 2013, 09:20:22 »
holy **** moz, those are looking pretty sick
and spy vs spy <*_*> so good
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #301 on: Wed, 04 September 2013, 09:43:19 »
They'll be fused using chloroform.
Guys, I need feedback, do you think they keycaps would look better with white etched portion being more clear (At the moment it is completely white).
I'll post a picture of what I mean.
Offline MTManiac
« Reply #302 on: Wed, 04 September 2013, 09:59:09 »
« Last Edit: Wed, 04 September 2013, 14:14:34 by MTManiac »
Offline chill1217
« Reply #303 on: Wed, 04 September 2013, 10:04:16 »
is it possible to do topre versions?
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #304 on: Wed, 04 September 2013, 10:10:51 »
Mine look fantastic! \o/
Offline MOZ
  • Busy making stuff
« Reply #305 on: Wed, 04 September 2013, 11:55:18 »
3 that I finished.
I am still testing out the color on the etching. It will be hard to maintain the white, since the choloroform used while fusing tends to seep and cause some parts to lose the white. Still, if it doesn't, over time with finger oils, and natural wear, the white would fade off as it is nothing but the residual powder from the laser etching.
The CC is only for me and the first one I made, to please the CC gods!
« Last Edit: Wed, 04 September 2013, 12:01:06 by MOZ »
Offline esoomenona
  • Gnillort?
« Reply #306 on: Wed, 04 September 2013, 11:59:31 »
« Last Edit: Tue, 27 October 2015, 10:08:16 by esoomenona »
Offline MOZ
  • Busy making stuff
« Reply #307 on: Wed, 04 September 2013, 12:01:54 »
clickclack should just give up now. The competition is off the chain.
edit: Looks like he could use a veneer.
I had to please the CC gods! :P
Offline xmagusx
  • QWERTY is hateful.
    • The Ergonomic Zone
« Reply #308 on: Wed, 04 September 2013, 13:35:43 »
Hopefully I didn't hold up progress (doesn't look like I did, these look badASS, so glad Spy vs Spy turned out as well as it looks to have), was driving back to DC from Houston (just got married!), and just now got in. Payment is in tho!
Offline Badwrench
  • ummmm.....I forgot
« Reply #309 on: Wed, 04 September 2013, 13:53:32 »
I think the more clear option looks a little cleaner.  It gives off a different reflection when backlit and you can see the design better (or it may just be the picture).  It is hard to tell that the middle one is bunny's avatar.
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #310 on: Wed, 04 September 2013, 16:16:43 »
OOHHH
I was trying to figure it out. Looked like a zergling or something. It's totally BL.
That being said, I like the "Frosted" look a thousand times better than the white.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline divito
« Reply #311 on: Wed, 04 September 2013, 16:19:53 »
OOHHH
Yes, the clearer/frosted-type look is much better in my opinion.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline MTManiac
« Reply #312 on: Wed, 04 September 2013, 16:50:18 »
it sounds like the white option isn't really an option since it will eventually wear off.
unless he put a clear coat on top or something to seal the dead acrylic skin cells in place
« Reply #313 on: Wed, 04 September 2013, 16:54:32 »
What settings are being used with the laser?  Those look like rather low fidelity engravings.  I'm used to seeing far more detail from laser engraved acrylic.
Offline MOZ
  • Busy making stuff
« Reply #314 on: Wed, 04 September 2013, 22:37:27 »
I do not operate the laser directly, but, from the settings that I did see, I think the one that pertains to the scan lines is the DPI? Correct me if wrong. And the setting that was used was 280, how much would you suggest?
Offline MOZ
  • Busy making stuff
« Reply #315 on: Thu, 05 September 2013, 04:17:59 »
Just finished 9 more.
Will take a break now and get these done next weekend, I know it is a long time but I have exams starting Monday.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #316 on: Fri, 06 September 2013, 08:11:58 »
Looking good so far, MOZ! I definitely agree that the frosted look is best.
Offline Xenderwind
« Reply #317 on: Sat, 14 September 2013, 12:04:52 »
any update on the rest of these?
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline MOZ
  • Busy making stuff
« Reply #318 on: Sat, 14 September 2013, 13:02:12 »
Just got over from exams, will be out tomorrow and then get back on making these, should take a day. I'll then get them polished.
« Reply #319 on: Fri, 20 September 2013, 15:37:26 »
Update?
Offline MOZ
  • Busy making stuff
« Reply #320 on: Fri, 20 September 2013, 15:45:37 »
Sent for polish yesterday, should have it Monday most probably.
Offline asdfjkl36
  • blue shirt guy
« Reply #321 on: Fri, 20 September 2013, 16:00:34 »
cant wait to see how they come out  :thumb:
Offline MOZ
  • Busy making stuff
« Reply #322 on: Mon, 23 September 2013, 13:00:52 »
Found this on the phone:
Took it before I sent them for polishing.
I called up my guy, there has been some delay in his end due to some personal reasons, hopefully we should get them by Friday.
Offline Phedran
    • Phedran.com
« Reply #323 on: Mon, 23 September 2013, 14:58:39 »
Ooh! Definitely getting in on the next batch.
Offline Tym
« Reply #324 on: Mon, 23 September 2013, 17:32:07 »
Out of curiosity can anyone see mine in there? It's a biohazard key? I can't see too well on my iPad! Not being impatient etc. just if it is there I want to have a gander.
Offline lucifurburch
« Reply #325 on: Mon, 23 September 2013, 17:37:17 »
it's dis one...
Offline MOZ
  • Busy making stuff
« Reply #326 on: Mon, 23 September 2013, 17:40:08 »
Yay, I took the best possible photo with the best camera.  :p
Offline Turkishrambo
« Reply #327 on: Mon, 23 September 2013, 17:50:02 »
i think maybe its the second one in from left (above one) Pictures arent good enough.
I definitely see a Bunny, i wonder who that could be :P
Offline Tym
Offline asdfjkl36
  • blue shirt guy
« Reply #329 on: Mon, 23 September 2013, 20:52:46 »
Cant tell where any of mine are  :'(
Offline pmh1410
« Reply #330 on: Tue, 24 September 2013, 04:34:41 »
Dear Moz,
You can made with new logo on your cap that you created but we are not agree if you used CC skull 's logo, Smile logo from DangWang, Gasmask from Gasmask factory and other logo from other creator ....... It's genuine by CC, Gasmask ..... and infect in value of each genuine.
Exemple: If you pay 500$ for Translucent Skull by Click Clark on GH market, are you accept other guy who made replicate and sale it on GH market ?????????
i don't want thread crapping but it's concern with all GH's member who want and have collection Skulls same as Tsangan, Boots, Ethos, JCrouse, Turbo Slaab, Jil_Jil32 ....... and included myseft.
You can made if you had all permet from each Creators ( Click Clack, Gasmask ......)
GLWS
pmh1410
Offline MOZ
  • Busy making stuff
« Reply #331 on: Tue, 24 September 2013, 04:54:58 »
Dear Moz,
GLWS
pmh1410
It was cleared earlier that the Skull is not for sale and is one I mad for myself. Same goes for the hapster, which litster will decide after seeing the final product if he wants to allow production of these.
Offline MOZ
  • Busy making stuff
« Reply #332 on: Fri, 27 September 2013, 03:44:25 »
Further slightly bad news, my guy's polishing dude has backed out, since polishing these is a PITA due to the small size.
I have gotten him to look for a new polishing person. I will keep you guys up-to-date. Sorry for the delay, however ti is a good thing that this is happening in the protoype face, so we can iron out the kinks for the actual GB later.
Thanks for your patience!
Offline MOZ
  • Busy making stuff
« Reply #333 on: Sat, 28 September 2013, 16:17:09 »
New update and good news, my guy has agreed to get them polished along with the keychains, so that should be complete by next weekend.
If you placed an order for the GH keychain, I will send you ceamocaps (The prototypes) with it, unless you tell me not to and want the second batch of ceamocaps (Which will still be some time as the GB hasn't even begun) and the prototype ceamocaps and keychain all sent later.
Offline MOZ
  • Busy making stuff
« Reply #334 on: Tue, 08 October 2013, 05:04:53 »
The ceamocaps have been sent for polishing.
I would day these were somewhat a success with some needed changes, which I have noted.
Now since these are custom designed, if we have a GB for this, it will be longer than my usual GB because of individual designs, so I have decided to ship all the ceamocaps that were ordered for the prototyping and send them out.
Those that ordered a GH 6th anniv. keychain will get their ceamocap with that order and these people are:
acantha
asdfjkl36
Badwrench
BunnyLake
fydo
Halverson
HoffmanMyster
infiniti
jonathanyu
lcs
mkawa
MTManiac
Sent
SpamRay
Wildcard
XenderWind
XmagusX
Those that didn't order a keychain, I will ship the ceamocaps to you. I won't charge anything for shipping at the moment, and when the actual GB happens, I will invoice you for the shipping with your order then, if you decide you don't want any more ceamocaps, it is okay, since I paid for shipping this time, so they cancel out :D. These people are:
artichoke
elton5354
luciferburch
germy
iAmAhab
Techno Trousers
tobr1an
Tym
nubbinator
Offline MOZ
  • Busy making stuff
« Reply #335 on: Tue, 08 October 2013, 05:07:27 »
All that said and done, I will most likely have the GB start at the end of this month, once most people from this round get their ceamocaps, the keychains are shipped, the TVS-e Gold's are shipped and the sticker GB enters production phase. Thus less wait on my shoulders. :)
The GB would be up for ordering for two months or so up until next year.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #336 on: Tue, 08 October 2013, 06:29:57 »
Thanks for the update MOZ!  I'm really looking forward to these! :thumb:
Offline MOZ
  • Busy making stuff
« Reply #337 on: Tue, 15 October 2013, 15:40:37 »
The keycaps came from the polishing, second time. And well, I'll let you guys be the judge, when you get them.
Offline Tym
« Reply #338 on: Tue, 15 October 2013, 15:43:20 »
Not sure if  :thumb: or :thumbdown:
« Reply #339 on: Tue, 15 October 2013, 15:44:45 »
I'd say if they were bad MOZ would have said so :P
Offline MOZ
  • Busy making stuff
« Reply #340 on: Tue, 15 October 2013, 15:52:12 »
It's best to say, I'm not incredible happy, I do see potential. But some things need to be sorted out.
And I was made a great fool a number of times by the worksman here in India, it's safe to say, they won't be getting any more orders from me, and it isn't like it affects them.
Offline Artichoke
« Reply #341 on: Tue, 15 October 2013, 16:21:51 »
Have I already sent you a mailing address, or do I need to do that?
Offline MOZ
  • Busy making stuff
« Reply #342 on: Sun, 27 October 2013, 22:07:53 »
I've printed labels and are ready to ship, I should ship these out on Tuesday most likely along with the first wave of the GH Keychains.
Offline MOZ
  • Busy making stuff
« Reply #343 on: Thu, 07 November 2013, 11:30:03 »
I know I've been delaying this like crazy for the past month, as many of you know I have had some troubles in real life, I will try and send these this weekend.
Again, extremely sorry.
Offline Wildcard
  • When caffeine isn't enough
« Reply #344 on: Wed, 20 November 2013, 22:22:03 »
Thanks again MOZ for doing these. Can't wait to see the finished prototypes.
Offline xmagusx
« Reply #345 on: Fri, 20 December 2013, 14:42:53 »
What's the latest word?
Offline MOZ
  • Busy making stuff
« Reply #346 on: Fri, 20 December 2013, 23:29:10 »
Taking these to the post office:
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #347 on: Sat, 21 December 2013, 06:12:51 »
Woohoo! :thumb:
Offline Wildcard
« Reply #348 on: Mon, 20 January 2014, 10:56:27 »
MOZ were these ever shipped? I still never received mine.
« Reply #349 on: Mon, 20 January 2014, 10:59:40 »
I don't believe MOZ shipped anything yet.
