Author Topic: New 104 Keysets from EK  (Read 12986 times)
« on: Thu, 15 August 2013, 07:18:03 »
http://elitekeyboards.com/products.php?sub=special&filter=tampo
Looks like they're nothing too special, but I actually really like these.
They're pad-printed ABS, but I love the colors they come in. I'll probably buy a set or 2.
Re: New 104 Keysets from EK
« Reply #1 on: Thu, 15 August 2013, 07:18:43 »
Know if its thin or thick ABS? Or who made them?
Offline GeeGee
  • ㅈ ㅈ
« Reply #2 on: Thu, 15 August 2013, 07:20:51 »
These actually look quite nice, but EK's shipping rates are ridiculous.
God it sucks to live in Europe.
Ducky Shine 2 with Blues
Poker 2 with Reds
KMAC Korean Custom with Clears
ReΛlforce 87u 55g
456GT
« Reply #3 on: Thu, 15 August 2013, 07:21:07 »
The legends are "tampo" legends. Whatever that means. I don't know if that helps you.
Also, the colors look to be the same colors EK has been using, so I'd assume they're from whoever EK normally buys from (GMK?).
« Reply #4 on: Thu, 15 August 2013, 07:27:17 »
Not sure, the purple looks off...Maybe Tampo is another OEM for keycaps? I know their other MX stuff is GMK but these caps colors don't look the same as the GMK ones. Specifically the Blue and Purple looks off.
Offline BimboBB
« Reply #5 on: Thu, 15 August 2013, 07:52:05 »
tampo(n) is the printing process...named after the company....http://www.tampoprint.de/en/index_en.html
« Reply #6 on: Thu, 15 August 2013, 07:54:46 »
So maybe they're GMK caps and then they're sent to Tampo for printing?
« Reply #7 on: Thu, 15 August 2013, 07:58:58 »
Need to see bottom shots!
Offline BimboBB
« Reply #8 on: Thu, 15 August 2013, 07:59:50 »
doubt that....they are too cheap even for that.  ;D
also the caps looking fairly rounded (OEM) instead of the sharp edges of the GMK caps.
« Reply #9 on: Thu, 15 August 2013, 08:03:56 »
Maybe they got in on their on a buy from tai hao
« Reply #10 on: Thu, 15 August 2013, 08:04:43 »
Tai Hao are double shots though.
« Reply #11 on: Thu, 15 August 2013, 08:08:52 »
Doh....nevermind....
Actually I am more interested in this
Reusable transparent packaging makes storing unused keycap sets a breeze.
« Reply #12 on: Thu, 15 August 2013, 17:16:01 »
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #13 on: Thu, 15 August 2013, 23:06:00 »
My problem with EK is that they say universal, but then it doesn't fit the FC700R or the FC660M when it comes to the right shift key and the spacebar.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline fydo
  • Meow!
« Reply #14 on: Thu, 15 August 2013, 23:09:45 »
Wow, $33.55 shipping to Canada for a single keyset.
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
« Reply #15 on: Thu, 15 August 2013, 23:20:31 »
I guess you'd fall into the "Likely incompatibilities exist only for the space bar which only allows for 80mm and 100mm wide mounts. Spacebar is not compatible with Leopold FC500 series!" area.
Offline jabar
« Reply #16 on: Thu, 15 August 2013, 23:21:16 »
I fail to see why this would even be a possibility without them mentioning it (and upcharging like EK always does).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #17 on: Thu, 15 August 2013, 23:22:33 »
Consider yourself lucky!  Shipping to Australia: $65.56 :eek:
I was thinking of getting some, but no way!  Not for $85.56 USD :eek:
Offline Photoelectric
« Reply #18 on: Thu, 15 August 2013, 23:28:01 »
Could be a mistake--I'd contact EK and inquire about it.  Perhaps somewhat higher shipping because of the size and weight of the boxes these caps come with.
« Reply #19 on: Thu, 15 August 2013, 23:55:55 »
Makes me think that the reusable transparent packaging is a largeish plastic display case, and the size probably causes the extcessive cost.
Actually for that shipping cost I can pretty much get a keyboard shipped over here.
Offline stealthycow
« Reply #20 on: Fri, 16 August 2013, 00:53:09 »
anyone know what profile these might be? for 20 bucks I'd love to try something shorter than my stock keys but I'm guessing they're just standard OEM...
« Last Edit: Fri, 16 August 2013, 00:54:43 by stealthycow »
« Reply #21 on: Fri, 16 August 2013, 01:02:25 »
Probably OEM - they look it.
« Reply #22 on: Fri, 16 August 2013, 08:45:29 »
Someone buy these already.
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #23 on: Fri, 16 August 2013, 17:54:12 »
I ordered some yesterday when I grabbed a wrist rest.  ;)
« Reply #24 on: Fri, 16 August 2013, 17:56:01 »
Too many nice looking keycaps -- too few keyboards!  Otherwise, I like the look of the light blue set very much.
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #25 on: Fri, 16 August 2013, 18:01:44 »
I was really torn between that set or the lavender.  Ended up going with the latter.  When they get here, I'll take some comparison pics and try to provide some more detail on the caps as best I can.
« Reply #26 on: Fri, 16 August 2013, 21:54:25 »
 I'm interested to see what these come packaged in.
Offline therecorder
« Reply #27 on: Fri, 16 August 2013, 22:08:02 »
No one has said anything about the profile of these caps.  Brian sells only Leoplod MX keyboards.  Are these Leopold, Cherry, or standard height?
Offline therecorder
« Reply #28 on: Fri, 16 August 2013, 23:20:38 »
It states "Cherry MX keycap sets" on EK, but this is often used as a general term.  On the other hand he states, "Authentic Cherry Blue Alt Set (Double-Shot)," and "Original Cherry Profile Double-Shot 1.25 keywidth Alt keycap" for other "modifier" keycaps on the same page.
http://elitekeyboards.com/products.php?sub=access,cherrymxkeys
« Reply #29 on: Fri, 16 August 2013, 23:58:37 »
If you look at the height of the keycaps, they look too tall to be Cherry profile, so probably OEM.
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #30 on: Sat, 17 August 2013, 00:06:20 »
We'll know as soon as EK ships 'em out to me.  I live about 30 mins away from them so it should be pretty damn fast.  Last time, it took a day.
« Reply #31 on: Sat, 17 August 2013, 03:29:54 »
A shame you cannot pickup to completely save on shipping.
We will be expecting detailed photos ;)
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #32 on: Sat, 17 August 2013, 05:05:06 »
The shipping is still 9 bucks.  Gotta love that.  :rolleyes:  I wish I had something better than this potato to take pics with.  Lol.
« Reply #33 on: Sat, 17 August 2013, 06:18:47 »
If your potato has a macro setting (usually indicated by a flower icon) please use it!
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #34 on: Mon, 19 August 2013, 04:30:10 »
Just wanted to touch base, as I've been chatting on the other thread regarding these keycaps. I emailed them and got a response from Brian down at EK. I had mentioned that there were a number of GHers looking for these keysets, but blank, like myself.
Hey guys, I actually just got an email back from Brian at elitekeyboards. He says that there are blanks in these colors on the way. The majority of the shipment was sent by boat, to include all of the colored blanks, with a limited number of the colored printed sets, and black blank sets, sent by air. He wanted to get them debuted as quickly as possible, since they're 8 months overdue. But given another 3 or 4 weeks, the same colors will be available in blanks.
Also, he mentioned the reusable keycap packaging, saying that they'd recently patented it. He was very excited because this is the packaging debut as well, and expects the packaging to be more popular than the keycaps that come in it.
He was very receptive and thankful for the feedback I sent them, and I have to say that this interaction with them has led me to decide that they'll be getting my business. Even if I was on the fence about the blanks (which I wasn't, assuming they were an option) this has definitely made my decision for me.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #35 on: Mon, 19 August 2013, 04:31:27 »
Hmmm, wish there was an answer about profile and all that jazz.  And kind of surprised my order isn't here yet.  Hasn't even shipped.  Last time it was stupid fast.   :))
  • Demon of the Fall
« Reply #36 on: Mon, 19 August 2013, 04:33:59 »
Maybe go knock on their door?
« Reply #37 on: Mon, 19 August 2013, 05:24:34 »
Now I don't know which thread to post in, so I'll post here.
EK has been great to me for the few things I ordered.  Glad to see the trend is continuing :)
The only problem with these sets is the $65 shipping cost to Australia, probably because of the size of the keycap box.
« Reply #38 on: Mon, 19 August 2013, 08:49:10 »
post in both its more fun that way.
Last order I had with them seems like it was 2-3 days to ship then 2-3 days to get it so almost a week total.
Offline Danule
« Reply #39 on: Mon, 19 August 2013, 09:05:58 »
EK has always been very good to me.  They process and ship the orders the next day.  Quality products and service from them.
45g Brown Brown Blue
« Reply #40 on: Mon, 19 August 2013, 15:10:34 »
Someone should have gotten these already!  We need photos :)  Of cap undersides for thickness and general close ups!  As well as for profile info.
« Reply #41 on: Mon, 19 August 2013, 15:14:44 »
soon....
« Reply #42 on: Mon, 19 August 2013, 19:11:02 »
I'm curious to see this keycap box.
If that is what pushes shipping cost up to $65 I might try to find a way to get a set of these without the box.
« Reply #43 on: Mon, 19 August 2013, 19:30:04 »
Rumor is they will be selling the cases next month for a good price.
« Reply #44 on: Mon, 19 August 2013, 19:42:08 »
That's not the point - if it is the case that pushes the shipping price up to $65, then I'll gladly do without the case and a more reasonable ($15?) shipping price for just the keycaps.
« Reply #45 on: Tue, 20 August 2013, 01:59:49 »
Which caps do you want? I just want to see this case.
« Reply #46 on: Tue, 20 August 2013, 02:10:19 »
I was thinking of a full set of the green ones, but $65 shipping - nah.  But then if it is hte keycap case that pushes shipping price up, maybe I can get a set without the case.  But I want to see case first, and get an indication of what the keycaps are like, hence waiting for someone else who has ordered them to receive theirs and review them.
« Reply #47 on: Tue, 20 August 2013, 06:35:51 »
I can probably hook you up, but I gotta check on shipping to Australia.....But surely I can do it cheaper than what they are charging. Especially if I get to keep the case!! I should have these by the end of the week.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #48 on: Tue, 20 August 2013, 09:46:14 »
Anybody receive theirs yet? I want an answer about the profile, too. :P
Offline tooki
« Reply #49 on: Tue, 20 August 2013, 11:01:54 »
"Tampo printing" is just another name for "pad printing". It's the process used for nearly all mass-market keyboards other than perhaps Apple's (lasered).
I'm quite certain the company is named after the process. In many languages, "tampon" just means "pad".
Given how common pad printing is, no need to send them to a specific German company.
