Author Topic: the_beast's wood  (Read 278505 times)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: the_beast's wood
« Reply #50 on: Mon, 19 August 2013, 12:47:18 »
. Bottom flocking would be best.
TIL...
Krog likes to flock the bottoms
Offline The_Beast
  • I like wood ಠ_๏
« Reply #51 on: Mon, 19 August 2013, 13:02:25 »
it would be too hard to keep it within the thickness specification due to changes in dimensions with humidity and temperature. it would basically just crack unless it was a wood composite (polymer with wood fibers dispersed)
If you can get larger sheets of stabilized wood, it would work. Stabilized wood is basically wood that has been put into a vacuum with a resin type material. The vacuum pulls the resin into the wood and turns it almost into plastic or it gains the properties of plastic (ie no movements due to humidity and temperature) but still looks like wood.
Offline tricheboars
  • Keyboards are Important!
« Reply #52 on: Mon, 19 August 2013, 13:28:30 »
i want a group buy for Beast wooden PCBs now...
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #53 on: Mon, 19 August 2013, 13:48:08 »
TIL...
And so I win the Internet.
Quote from: Samuel Adams
Offline Thimplum
  • Master of all Ponies
« Reply #54 on: Mon, 19 August 2013, 14:07:12 »
Can some mod please ban everyone except me who posted in this thread?
TP4 FOR ADMIN 2013
Offline Xenderwind
« Reply #55 on: Mon, 19 August 2013, 14:08:39 »
Why wood we do that?
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline The_Beast
  • I like wood ಠ_๏
« Reply #56 on: Mon, 19 August 2013, 14:10:09 »
I know. That wood not be nice....
Offline esoomenona
  • Gnillort?
« Reply #57 on: Mon, 19 August 2013, 14:10:47 »
Erection.
Offline Thimplum
« Reply #58 on: Mon, 19 August 2013, 14:11:02 »
Or wood it...
TP4 FOR ADMIN 2013
« Reply #59 on: Mon, 19 August 2013, 14:12:15 »
It would be much easier to just ban you? Woodn't you agree?
Offline Tym
« Reply #60 on: Mon, 19 August 2013, 14:15:45 »
« Reply #61 on: Mon, 19 August 2013, 14:20:54 »
you woodn't ;)
Offline esoomenona
  • Gnillort?
« Reply #62 on: Mon, 19 August 2013, 14:23:59 »
If I were you guys, I erection be quiet already.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #63 on: Mon, 19 August 2013, 14:25:17 »
that's a wood composite. a composite is just a polymer in a dissimilar non-polymer matrix. so glass fiber reinforced polymers like G10-11, GPO-x, PPx + gfx0, and other variants that use woven or other kinds of silicate matrices are polymers in the same way that plasticized wood or leather is a composite (most "leather" car seats are plasticized leather, which is just low quality leather impregnated with a polymer. the composites getting the most attention are things like carbon fiber, graphene based composites, etc. etc. but that's only because they use an elemental aligned bulk material to make something ridiculously strong in some ways and reinforce with really high energy processed polymers to make it ridiculously strong in all ways, but composites are actually seeping into every part of our life if you consider only the definition.
fun fact: a number of glass fiber reinforced polymers were approved for underhood use recently, and manufacturers have been using them to great success in very common, inexpensive cars. i pulled a bypass valve out of my car recently that was ppo + gf30 on the outside and pp + gf20 on the inside (turbos are subject to exhaust gas heat so a bypass valve is put under HUGE thermal stress. honda's new K series engines (which marketing dubs "earth dreams" or something equally stupid") uses ppx + gfx0 composite for their intake manifolds now (and my intake manifold has at least some kind of composite heat shield if it isn't fully composite, come to think of it...)
what was i talking about? oh right, wood. here's some cool stuff printed with a wood fiber reinforced PLA (the PLA is starch-based and pulped wood fiber is in there somewhere and mixed in.
http://www.thingiverse.com/Fused3D/collections/print-in-wood-with-laywoo-d3-pla-filament
it may be wood-based PLA, but for a PLA you do need to get starch from somewhere to form the polymer so i dunno
anyway one thing you do have to be careful of is that although a wood composite may not warp at room temp, molded in stressed (because it's made with an injection molding process afaik) could cause it to warp at temp.
Offline Thimplum
« Reply #64 on: Mon, 19 August 2013, 14:27:50 »
I'm already going down that road...
TP4 FOR ADMIN 2013
« Reply #65 on: Mon, 19 August 2013, 14:31:14 »
don't be so hard on yourself!
Offline Tym
« Reply #66 on: Mon, 19 August 2013, 14:36:43 »
you woodn't ;)
Weird 'Murican humour I guess?
« Reply #67 on: Mon, 19 August 2013, 14:39:18 »
you woodn't ;)
That wood be my guess.
Offline Tym
« Reply #68 on: Mon, 19 August 2013, 14:41:06 »
I wood have to agree with you.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #69 on: Tue, 20 August 2013, 01:18:46 »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #70 on: Tue, 20 August 2013, 14:59:31 »
After keycon, I'm not at all surprised by this response.
Offline YoungMichael88
  • HHKB Wannabe
« Reply #71 on: Fri, 13 September 2013, 03:22:07 »
Recently the beast gave me wood. I'll always remember my first. And I didn't even have to pay for it this time! (Giveaway winnings)
Thanks Beast!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #72 on: Fri, 13 September 2013, 09:06:39 »
Thanks Beast!
Man that tiger birch looks good.
Glad I made a case out of it!
Offline goobus
  • HHKB Elite
« Reply #73 on: Fri, 20 September 2013, 06:30:22 »
Just put some epoxy/fiberglass mixture on that wood baby
EDIT: you guys beat me to it :(
Offline mkawa
« Reply #74 on: Fri, 20 September 2013, 10:00:36 »
vacuum means it's a cast wood composite. pressure is an injected wood composite. the former would use a thermoset. the latter uses a thermoplastic.
