Author Topic: White on Black PBT KEYCAP SETS  (Read 5141 times)
Offline therecorder
« on: Sun, 18 August 2013, 07:47:36 »
Would like to get a couple for my Filcos. (104 and 87, or 2 104s).  Any know where to get?
Offline badcop
  • thorpe thocking master race
Re: White on Black PBT KEYCAP SETS
« Reply #1 on: Sun, 18 August 2013, 08:14:32 »
The legends must be darker in order to dye sub so Im afraid white on black isn't an option at this point.
Offline therecorder
« Reply #2 on: Sun, 18 August 2013, 08:17:38 »
I didn't say that they had to be "dye sub"...  Just PBT.
Offline PepperPanda
« Reply #3 on: Sun, 18 August 2013, 11:57:02 »
Currently there is no full set of doubleshot PBT keycaps. Well other then the one posted here, but who knows when thats coming out.
If you're talking about lasered there might be. A quick search and I found this. Might have more luck searching through taobao.
Offline therecorder
« Reply #4 on: Sun, 18 August 2013, 12:09:43 »
Truthfully, it doesn't even have to be doubleshot - A simple OEM would do.  One of your links led to a black on white set - I'm looking for the opposite.  The Ducky set is out of stock, and a Ducky keycap set on a Filco keyboard doesn't match very well ("F" keys and windowed LED caps are all wrong).  Thanks for trying.
Offline Xenderwind
« Reply #5 on: Sun, 18 August 2013, 15:13:12 »
well dyesub, doubleshot, and lasering is out.  So I guess your only options are pad printing or UV(not even sure on this one)?  I'm sure someone with more knowledge will chime in soon.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline esoomenona
  • Gnillort?
« Reply #6 on: Mon, 19 August 2013, 14:53:29 »
The only pad printed white on black PBT caps I can recall seeing are the caps on a black IBM M13... Hmm...
Offline therecorder
« Reply #7 on: Mon, 19 August 2013, 15:04:14 »
Well, if PBT isn't available, what about POM White on Black 104 sets?
Offline esoomenona
  • Gnillort?
« Reply #8 on: Mon, 19 August 2013, 15:05:06 »
POM is even less available, aside from mostly those POM jelly sets...
Offline therecorder
« Reply #9 on: Mon, 19 August 2013, 15:10:43 »
It's really strange, the most used keycap color combination, and no one has come up with a decent upgrade replacement set.
Offline esoomenona
  • Gnillort?
« Reply #10 on: Mon, 19 August 2013, 15:13:20 »
It's because PBT is generally seen as a higher quality cap based on cost, and pad printing is a downgrade.
Offline therecorder
« Reply #11 on: Mon, 19 August 2013, 15:22:40 »
Yet Keycool and noppoo make some nice White on Black POM sets, and they're really not what you would call high-end.
Offline esoomenona
  • Gnillort?
« Reply #12 on: Mon, 19 August 2013, 15:25:43 »
Yeah, POM doesn't seem to be too popular, and seems to be a lower end thing. Shame, because POM isn't too bad.
For the record, I'm not saying I agree with the state of things. I love white on black. I went out of my way to find a black M13 so I could take the caps for another Model M. It's just the way things are...
Offline therecorder
« Reply #13 on: Mon, 19 August 2013, 15:38:37 »
Perhaps I should go with Signature Plastics Standard Double Shot ABS Sets http://www.keycapsdirect.com/marketplace.php But, it will cost me $60 + $18 for my 104 Filcos.  Never used these...  Any comments?
Offline therecorder
« Reply #14 on: Mon, 19 August 2013, 15:50:18 »
Offline esoomenona
  • Gnillort?
« Reply #15 on: Mon, 19 August 2013, 16:58:11 »
NO! IF you really want the greatest white on black set, you HAVE to go Cherry doubleshot ABS. They are amazing. The best, literally. Start a WTB on the classifieds, and you can find a set ranging in price depending on what you're willing to spend. I've seen them range from $10 to $150, depending on how new they are and compatibility.
The thing about Cherry WoB sets is you usually need something to make them compatible. Usually, that means an SP moogle. But you can also find people who sell complete Cherry sets that are compatible. If you need more info, you can PM me.
Offline therecorder
« Reply #16 on: Mon, 19 August 2013, 18:09:21 »
Thanks for the advice, but I'm not a lover of the profile.  Perhaps I'll just go with blanks, or Vortex Black on Black dye-subs...  At least the feel will be what I want.
Offline esoomenona
  • Gnillort?
« Reply #17 on: Mon, 19 August 2013, 18:14:53 »
You in the CONUS?
Offline therecorder
« Reply #18 on: Mon, 19 August 2013, 18:23:56 »
No...  In Israel...  Usually do all my purchases like this one from Qtang.
Offline esoomenona
  • Gnillort?
« Reply #19 on: Mon, 19 August 2013, 18:29:13 »
Ah, okay then. Good luck.
Offline therecorder
« Reply #20 on: Mon, 19 August 2013, 18:30:24 »
Much thanks for all your help.
