Author Topic: Ergodox - Raising/Suspending your Ergodox  (Read 7318 times)
Offline audukent
« on: Mon, 26 August 2013, 09:36:38 »
Hello,
I posed this question in another Ergodox post, but never got a real response.  The question is in regards to raising your Ergodox.
I'm curious about how to raise your Ergodox.  I've seen some users using 'Kinesis Freestyle V3' and I'm curious if this is easy or even worth it?  Whats the best way to do this?  How do you like your Ergodox? Raised? Angled?
Amazon Link:
http://www.amazon.com/Kinesis-Corporation-Ac730-blk-Freestyle-Accessory/dp/B003F8MDPY/ref=sr_1_fkmr0_1?s=electronics&ie=UTF8&qid=1377490657&sr=1-1-fkmr0&keywords=Kinesis+Avantage+V3
Best,
Kent
[LZ-GH - 62g mx greens and 62g mx clears]    [Ducky Shine - mx browns]    [RACE mxMini - mxreds]  [POKER II - mx Blacks]    [KPAD - 62g mx blacks]
Offline yasuo
  • spanengan puyeng newbie
Logitech MK220 Colemak DH
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Ergodox - Raising/Suspending your Ergodox
« Reply #2 on: Mon, 26 August 2013, 10:42:08 »
I've been playing with small various sized acrylic discs with a M3 sized hole in the center for the past couple of hours and finally got it correct.
I'll post pics soon.
Offline yasuo
« Reply #3 on: Mon, 26 August 2013, 10:49:29 »
@MOZ you have ergo dox apparently
what switch?
@CommunistWitchDr
Offline MOZ
  • Busy making stuff
« Reply #4 on: Mon, 26 August 2013, 10:53:23 »
Cherry MX Blue with 80g Korean springs.
Offline yasuo
« Reply #5 on: Mon, 26 August 2013, 10:59:31 »
it's not become ergonomic
Offline MOZ
  • Busy making stuff
« Reply #6 on: Mon, 26 August 2013, 12:08:13 »
I don't quite get you
Offline MOZ
  • Busy making stuff
« Reply #7 on: Mon, 26 August 2013, 14:49:30 »
II made these feet to adjust the vertical angle of the ErgoDox to make it even more comfortable. Got various sized discs and different sized hex bolts and then balanced it out according to my comfort level:
You can see that on each hand, I am missing one bumpon on one feet, the ebay dealer only sent two sets of 4 instead of 3  :mad:
Offline audukent
« Reply #8 on: Mon, 26 August 2013, 15:02:46 »
hahaha I can not stop laughing
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #9 on: Mon, 26 August 2013, 18:32:35 »
The two most common ways are using the kinesis lifts or adding longer bolts  to raise units to suit your preference. Then you will likely add rubber pads to make it non slip and non marring.
I'm surprised more people haven't made  an Ergodock like Glod's.  Simple design, tent to your spec's, simple woodworking and built in wrist rest.
<a href="http://www.flickr.com/photos/panicfx/8945584872/
Offline audukent
« Reply #10 on: Tue, 27 August 2013, 15:20:41 »
I really like Glod's thing but I already am getting the 'full hand' case for my Ergo so I'm not sure that all is necessary.  Although, I could create that tilted base to hold the ergo suspended. Seems simple enough.
Offline audukent
« Reply #11 on: Tue, 27 August 2013, 15:21:40 »
what switch?
@CommunistWitchDr
I wonder how he was able to attach the Kinesis?
Offline darkfire32
« Reply #12 on: Tue, 27 August 2013, 16:18:51 »
He said it in the post and one of the pictures: velcro.
Also, I did reply to your post in the other thread. Use cardboard, free at your postal office.
