Author Topic: Shine 3....Need To Slow Down Holding Down Backspace Key  (Read 3261 times)
Offline dman777
« on: Mon, 26 August 2013, 10:23:06 »
I have a Shine 3 and when I hold the backspace down the cursor is way to fast and deletes way to much. To slow this down, do I adjust USB Repeat Delay Time or USB Repeat Rate?
Offline jameslr
Re: Shine 3....Need To Slow Down Holding Down Backspace Key
« Reply #1 on: Mon, 26 August 2013, 10:25:01 »
USB repeat rate; Delay is the amount of time it waits before the repeat begins.
« Last Edit: Mon, 26 August 2013, 10:49:55 by jameslr »
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline JPG
  • Model F is my new passion!
« Reply #2 on: Mon, 26 August 2013, 10:34:43 »
I saw a video showing how to change the repeat rate on the new duckies. I am pretty sure it's a new feature on this keyboard and in the video it could go from very slow to very fast.
Offline daerid
    • Rossipedia
« Reply #3 on: Mon, 26 August 2013, 11:14:13 »
I believe it's FN+one of the function keys.
Offline JPG
« Reply #4 on: Mon, 26 August 2013, 12:02:36 »
Watch this video :
At like 5 minutes, they show how to program the speed. it's fn + function keys to set either the speed or repeat rate.
Offline falkentyne
« Reply #5 on: Mon, 26 August 2013, 12:43:15 »
FN+F1 and FN+F5 set the repeat rate and delay back from keyboard to OS controlled.
F1-F4 control delay, F5-f8 control repeat rate.
