Author Topic: POST Your GON(s)!!!! ;)  (Read 463722 times)
Offline henz
  • What?
Re: POST Your GON(s)!!!! ;)
« Reply #650 on: Thu, 07 May 2015, 07:44:34 »
My first GON  :)
Cat inspection :p
wow that looks awesome, I didn't know you could get that board in ISO tho :OO
The possibilities are endless! My next will have ISO enter. Cherry space, ANSI left shift and cherry caps lock,
I need to find someone to build me a GON, from what I've heard he's backed up months and months and I kinda want one now! haha
I can hook you up, but im afraid that even though you just order parts, its going to take some time atm. As gon is pretty backed up
Offline Sed8op8
  • Keyboard Padawan
« Reply #651 on: Thu, 07 May 2015, 07:56:07 »
My first GON  :)
Cat inspection :p
I really love the orange and gray layout it would look amazing with Hack'd by geeks keyset  :thumb:....sounds like a bunch of notifications went out!
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #652 on: Thu, 07 May 2015, 10:25:07 »
My first GON  :)
Cat inspection :p
That orange side light is awesome. I want one. Just with a slightly lighter plate ;)
What colour on GON's site is that?
Offline baldgye
  • Will Smith Disciple
« Reply #653 on: Thu, 07 May 2015, 10:25:46 »
My first GON  :)
Cat inspection :p
yeah I really wish he made one in white QQ
Offline Sed8op8
  • Keyboard Padawan
« Reply #654 on: Thu, 07 May 2015, 10:37:29 »
My first GON  :)
Cat inspection :p
you could go with the polycarbonate !!!
Offline katushkin
  • Just the guy
« Reply #655 on: Thu, 07 May 2015, 10:43:35 »
My first GON  :)
Cat inspection :p
But the whole point is to get a metal one :P
If he did white it would go so well with the Cherry Rep set... sploosh...
Offline ttzhou
  • in your base, belonging
« Reply #656 on: Thu, 07 May 2015, 10:47:27 »
don't think it is possible to anodize aluminum in white since it's default steel/grey is a darker shade.
Offline Sed8op8
  • Keyboard Padawan
« Reply #657 on: Thu, 07 May 2015, 10:58:03 »
My first GON  :)
Cat inspection :p
agreed,,,,, the only white aluminum cases I even though have been painted
Offline FoC_Tow
  • Brokehlicious
« Reply #658 on: Thu, 07 May 2015, 11:16:41 »
My first GON  :)
Cat inspection :p
Wow, totally love the combination you went with yobinad!
Awesome build man!  :thumb:
My first GON  :)
Cat inspection :p
It's true that you can't anodize aluminum white, but besides painting there would still be the option to powder coat.
Depending on the kind of powder coating, this might also even be stronger in terms of scratch resistance compared with anodizing afaik.
However, Powder Coating adds quite a bit of thickness to the parts (while anodizing just changes color of the aluminum instead of adding a layer on top)
so you couldn't powder coat hole screws for example like you would with anodizing since it most likely would ruin the threads.
Offline Ngt
« Reply #659 on: Fri, 08 May 2015, 13:19:12 »
My first GON  :)
Cat inspection :p
Really nice board! The choice of colors is really nice. Is that the grey (Hard anodized) color?
Offline radio_killah
  • Chinchillin'
« Reply #660 on: Fri, 08 May 2015, 13:49:13 »
Damnit.. I am going to need to buy another GON..
Offline henz
  • What?
« Reply #661 on: Fri, 08 May 2015, 13:58:08 »
i soon have 2!. and  2 more bords with nerd pcb !! :D
Offline yobinad
« Reply #662 on: Fri, 08 May 2015, 17:35:28 »
:thumb:
It is non-glare grey. GON told me that non-glare is hard anodized
Offline Latin00032
« Reply #663 on: Fri, 08 May 2015, 17:59:25 »
:thumb:
I thought hard anodized is only grey?
« Reply #664 on: Fri, 08 May 2015, 18:01:49 »
Correct and the exact grey color is determined by the type of alu being anodized.
Offline Mikey Mo
« Reply #665 on: Sat, 09 May 2015, 20:44:10 »
 ;D ;D
Offline Mikey Mo
« Reply #666 on: Sat, 09 May 2015, 20:44:43 »
 :D :D
Offline FoC_Tow
  • Brokehlicious
« Reply #667 on: Sun, 10 May 2015, 00:03:31 »
:D :D
Sweet Picture Mikey! Much clarity!!  ;)
Offline ideus
  • Björkö.
« Reply #668 on: Sun, 10 May 2015, 08:58:46 »
Is it possible to program a LED to turn on when FN1, or FN2 is locked?
  • Chinchillin'
« Reply #669 on: Sun, 10 May 2015, 10:33:50 »
You can have it so the in switch leds or the side leds light up when you activate a function layer. But not a single led.
Offline FoC_Tow
  • Brokehlicious
« Reply #670 on: Sun, 10 May 2015, 10:36:04 »
Did you check out GONs video on Nerdy GUI LED config Ideus? =)
Im slightly confused what exactly you meant by FN 'locked' tbh, but from what it looks like you can definitely Link the Backlight LEDs and/or Side LEDs to FN1 or FN2. (which I guess would mean LEDs coming on whenever you access the assigned function layer.)
However you don't get this option for the indicator LED so that one can not be linked to FN from what it looks like.
I kinda have a question regarding LEDs on a Nerd60 pcb as well.
Is it possible to program Num-lock on one of the function layers and link the Indicator LED to it to get manual control with a designated button?
(so basically since there is no num keys on 60% its hole purpose would be controlling the indicator LED)
Im planning to make use of (might say abuse) the third LED channel for a project and just want manual LED on/off control... =)
Offline ideus
  • Björkö.
« Reply #671 on: Sun, 10 May 2015, 15:47:46 »
It is what I think, you can define all of them to light up at once; but, not individually.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #672 on: Sun, 10 May 2015, 21:14:24 »
If you double tap the FN keys they will stay on/locked to the FN layer till you double tap it again.
Now I'm not 100% sure what you're asking but you can program any button anywhere on any layer you like so it sounds possible if I'm understanding what you're asking.
But I would imagine that the NerD60 doesn't have a indicator socket for num lock unless you were using a different source for that indicator light.
GON NerD TKL DTA Edition
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #673 on: Sun, 10 May 2015, 21:28:01 »
ALWAYS get more GON in your life  :thumb: .
His keyboards are to die for and you can have it customized to what ever you like, I always get him to make it for me because I'm a moron when it comes to making anything small and complicated and his keyboards are just that.
Going to get his full sized (104) keyboard which is absolute hard-core porn, for the very keen in Korean Keyboards.
GON is what represents the very BEST in Korean one-man manufacturing, like what Rolex was in 1905.  So if you want the absolute best of the best in keyboards today, you can't go past a GON  8) .
Offline FoC_Tow
  • Brokehlicious
« Reply #674 on: Mon, 11 May 2015, 05:44:27 »
THX Evo! =)
I was referring to the indicator LED next to Caps lock.
Its used as Caps Lock indicator by default (and to show macro/programming mode etc) but it looks like Nerdy gui can also Link this Indicator LED to Num-Lock or Scroll-Lock.
So if I where to use this LED Channel for a mod, I could most likely link to num-lock to have a dedicated button to toggle the LED on/off, right?
I kinda think it should work as long as you can program num-lock on the Nerd60 with Nerdy gui.  :)
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #675 on: Mon, 11 May 2015, 06:01:53 »
THX Evo! =)
If no one answers this by the end of this month I'll solder in an LED in my NerD TKL caplocks indicator spot and test it out.
Offline FoC_Tow
  • Brokehlicious
« Reply #676 on: Mon, 11 May 2015, 19:18:00 »
THX Evo! =)
Wow! Much THX EVO! <3
I kinda think it should work, would very much appreciate it if you can confirm this tho! =)
Ill shoot you a PM with my basic idea...
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #677 on: Wed, 20 May 2015, 12:13:41 »
DTA GON NerD TKL.  ;D
Offline abswyfe
  • I <3 Geekhack
« Reply #678 on: Wed, 20 May 2015, 12:43:58 »
:D :D
Your glow seems much more subtle than many of these
I think I could deal with that
Some would give me migraines tho
Thank you all Destiny supporters and all you fun people in off topic! I think I will try to stick around for a while!
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #679 on: Wed, 20 May 2015, 22:41:26 »
:D :D
You can set the brightness levels on them (and they go pretty dim) so I imagine that he has it set on the low side to give it that effect.
I just like mine obnoxiously bright =)
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #680 on: Wed, 20 May 2015, 22:42:19 »
Nice work man! Where's dat build log!
Offline Sed8op8
  • Keyboard Padawan
« Reply #681 on: Thu, 21 May 2015, 04:47:11 »
« Reply #682 on: Thu, 21 May 2015, 17:43:18 »
Is that what happens when you use a frosted white top and a pink middle layer or when you have a frosted case and pink backlighting?
Offline Sed8op8
  • Keyboard Padawan
« Reply #683 on: Thu, 21 May 2015, 18:14:11 »
i think it might be red but looks pink through the PC
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #684 on: Fri, 22 May 2015, 05:02:36 »
I wished I had taken more pics, I built it last week when I just got back from the UK and I was jetlagged. So I just merely assembled it when I couldn't sleep.
Haha, I do have some pics and I'll try and upload them later.  :D
The LEDs are "Peach Red" in Chinese. It's closer to pink not red.  ;D
And yeah, my top layer is frosted/matte like finish.  :)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #685 on: Fri, 22 May 2015, 05:09:40 »
Sorry, I got shaky hands :(
If you see the led in the Esc position it cycles to red at one point, so the others are definitely not red :p
Offline hoz
  • 60% is more than enough.
« Reply #686 on: Mon, 25 May 2015, 13:42:13 »
Mobik in proper lightning without all the bling enabled :)
one 40% and seven 60%'s
Offline koalapear
  • Actually hates koalas.
« Reply #687 on: Mon, 25 May 2015, 13:54:26 »
Might not be a full-on GON but it is a NerD 60!  ;D
'91 Model M SSK | NerD 60 (MX Greens) | Realforce 87U 55g | Winkeyless B.87 (MX Greens) | Monarch Matias Custom | HHKB | Duck Octagon (67g Zealios)
Offline baldgye
« Reply #688 on: Thu, 28 May 2015, 10:11:48 »
really great board
Offline n0rvig
« Reply #689 on: Thu, 28 May 2015, 23:11:07 »
Beautiful boards guys!
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #690 on: Sun, 07 June 2015, 03:38:01 »
NerD TKL with GMK Olivetti :)
Offline Sed8op8
  • Keyboard Padawan
« Reply #691 on: Sun, 07 June 2015, 05:21:37 »
stunning naasfu  :eek: as usual ;)
Offline Belfong
« Reply #692 on: Sun, 07 June 2015, 05:49:06 »
I love your GON, bro!
But I refuse to admit I need one!
I'm super happy with my 2TU, yep, I'm happy!
Offline Ngt
« Reply #693 on: Sun, 07 June 2015, 06:56:42 »
If only there was no so much delay ATM with gon, I would have ordered a Nerd NS 60. I love the design.
Offline strict
  • TKL Zealot
« Reply #694 on: Sun, 07 June 2015, 09:11:01 »
http://i.imgur.com/rRlBmn2.jpg
http://i.imgur.com/RSjQtAk.jpg
Everytime I look at these pictures I find more to love! The black GON, the trans-blue clack, the blue accent Enter, the GMK, even the lighting is excellent. As always, naasfu, your photos are a top-shelf treat   :thumb:
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #695 on: Sun, 07 June 2015, 12:05:01 »
Damn! I'm gonna need a custom soon. That is a great board!
Offline eosph
« Reply #696 on: Tue, 16 June 2015, 15:57:34 »
She's a beauty, Gateron browns, raindrop v2, special geekhack key.
Offline gropingmantis
« Reply #697 on: Wed, 17 June 2015, 03:15:31 »
Yeah I need a camera. Might try to borrow one to take some glamour shots.
103613-0
Offline yobinad
« Reply #698 on: Wed, 17 June 2015, 15:35:07 »
Prototype of a wood case for my Nerd60
Offline ideus
  • Björkö.
« Reply #699 on: Wed, 17 June 2015, 15:44:25 »
Awesome work; have you ever consider to add some enamel, or clear coat?
