Author Topic: POST Your GON(s)!!!! ;)  (Read 463734 times)
Offline yobinad
Re: POST Your GON(s)!!!! ;)
« Reply #700 on: Wed, 17 June 2015, 15:49:25 »
Thank you :)
I'm planning to apply varnish
Offline ideus
  • Björkö.
« Reply #701 on: Wed, 17 June 2015, 23:16:58 »
I also have my Nerd60 PCB with no plate, Gateron switches, Granite caps and a machined acrylic plate. I just need to build a small front cover for the open corners at the bottom row left with no switches because I am using a HHKB style.
Offline hoz
  • 60% is more than enough.
« Reply #702 on: Thu, 18 June 2015, 07:04:25 »
the plate i'll have cut and anodised in the same green as the tex case i'll most likely use for my nerd60 :D
one 40% and seven 60%'s
Offline Ngt
« Reply #703 on: Fri, 19 June 2015, 04:12:05 »
Prototype of a wood case for my Nerd60
Really cool! Did you do it all by yourself?
« Reply #704 on: Fri, 19 June 2015, 16:57:27 »
The inside shot in CNC porn.  :-*
Offline yobinad
« Reply #705 on: Fri, 26 June 2015, 12:15:54 »
GONne orangina  :p
« Last Edit: Sat, 04 July 2015, 07:17:13 by yobinad »
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #706 on: Fri, 03 July 2015, 16:59:47 »
GONne orangina  :p
Really nice keyboard! did you request to have anything custom for that? Like was the engraving requested or did it come with it?
Offline yobinad
« Reply #707 on: Fri, 03 July 2015, 19:13:29 »
Thank you :)
The engraving is by request. Plus 20$
Meanwhile i've receive the Tai-Hao orange set. I need to unsolder everything so i can change the stabilizers.
Will post pics when done
Offline Sed8op8
  • Keyboard Padawan
« Reply #708 on: Fri, 03 July 2015, 23:53:39 »
Thank you :)
I wish I had spent the money on engraving !!! I cannot believe I am actually getting this board so long have I waited !
Yobinad orange os one of my favs you must be very happy with this 8)
Offline yobinad
« Reply #709 on: Sat, 04 July 2015, 07:13:32 »
Yes i'm very happy  ;)
I really like the orange glow effect on the plate. It looks like is melting  :D
It will feel good on those cold winter days  :))
Yesterday i put the Tai Hao orange set on it. I still need to unsolder everything so i can change it to ANSI.
Also i need to paint inside orange keycaps. They bleed too much.
Offline baldgye
  • Will Smith Disciple
« Reply #710 on: Sat, 04 July 2015, 07:26:36 »
Yeah that looks really great! Also good to see an ISO GON!
Offline rpeterclark
  • RPTR ❌
« Reply #711 on: Sat, 04 July 2015, 07:44:42 »
That looks great!
About the bleed, I've had success using aluminum foil tape, cutting tiny squares and placing them on top of the LEDs, redirecting the light downwards. It's reversible and less work than paint.
Offline yobinad
« Reply #712 on: Sat, 04 July 2015, 09:15:35 »
That looks great!
Great tip!!!! :)
Thank you ;)
Offline hoz
« Reply #713 on: Mon, 06 July 2015, 04:38:08 »
weih, keyboards!
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #714 on: Mon, 06 July 2015, 04:45:04 »
weih, keyboards!
Damn, that green looks nice.
Offline hoz
« Reply #715 on: Mon, 06 July 2015, 05:25:08 »
weih, keyboards!
yep, and damnit, after trying out the ducky yellow dyesubs on it i'm pretty much forced to choose full iso layout for this build  :eek:
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #716 on: Mon, 06 July 2015, 06:27:21 »
weih, keyboards!
Damn now you got me needing to buy that case! That green is amazing!
Offline hoz
« Reply #717 on: Mon, 06 July 2015, 11:14:02 »
aaand, done for the day :)
Offline yobinad
« Reply #718 on: Mon, 06 July 2015, 11:51:16 »
Congrats it is very nice :)
Offline radio_killah
  • Chinchillin'
« Reply #719 on: Mon, 06 July 2015, 13:08:40 »
weih, keyboards!
Is that just a standard tex case?
Offline hoz
« Reply #720 on: Mon, 06 July 2015, 13:58:10 »
  • Chinchillin'
« Reply #721 on: Mon, 06 July 2015, 19:43:53 »
weih, keyboards!
yep.
Were they color matched? It looks really good together.
Offline hoz
« Reply #722 on: Tue, 07 July 2015, 08:16:57 »
weih, keyboards!
yep.
nope, i did not even see a picture of the "green" color before i placed my order, could've turned out so much worse :D
Offline lookitdisnub
« Reply #723 on: Thu, 09 July 2015, 01:04:39 »
Note 3's camera kinda sucks
« Reply #724 on: Thu, 09 July 2015, 05:45:21 »
Yeah, it does - it makes your space bar look like it's on the wrong way around :p
Offline ideus
  • Björkö.
« Reply #725 on: Thu, 09 July 2015, 14:01:01 »
Awesome setup, congratulations.
« Reply #726 on: Thu, 09 July 2015, 17:19:00 »
GON HHKB in non glare black with some pink and purple accessories. I'll be assembling it sometime this weekend.
104872-0
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #727 on: Thu, 09 July 2015, 17:21:22 »
Nice! I like the accessories too  :thumb:
« Last Edit: Thu, 09 July 2015, 17:25:22 by nickheller »
Offline Sed8op8
  • Keyboard Padawan
« Reply #728 on: Thu, 09 July 2015, 17:31:39 »
I need 12 of those purple 3mx12mm bolts for my board coming tomorrow I'm really not feeling the yellow ones coming with it although I guess I might feel different once it gets here ...l
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #729 on: Thu, 09 July 2015, 17:32:37 »
Awwww yeah.  Pink and purple.  Joey knows what's up.
Offline Sed8op8
  • Keyboard Padawan
« Reply #730 on: Thu, 09 July 2015, 17:39:34 »
joey do these look anything like what came with your gon kit ?
http://www.fastener-express.com/m3-x-5-x-12mm-flat-head-socket-cap-screw-purple-anodized-qty-25.aspx
« Reply #731 on: Thu, 09 July 2015, 17:41:29 »
Possibly a little pinker but close.
Offline Sed8op8
  • Keyboard Padawan
« Reply #732 on: Thu, 09 July 2015, 20:42:57 »
this is going to be soooo nice Joey 8)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #733 on: Fri, 10 July 2015, 10:00:45 »
I can't wait to see what you do with that board Joey. Want one so bad.
Offline baldgye
« Reply #734 on: Fri, 10 July 2015, 10:19:52 »
Can't wait to see it, god damn I need a GON
    • WTB/WTTF Thread
« Reply #735 on: Fri, 10 July 2015, 10:22:02 »
Same! Now I want to get a green GON HHKB, but the price tag is killer.
Offline baldgye
« Reply #736 on: Fri, 10 July 2015, 10:25:36 »
It's the waiting time that's put me off, kinda waiting to see what Bunny has cooked up for [Ctrl]Alt's relaunch and follow up to the GH60 thing
    • WTB/WTTF Thread
« Reply #737 on: Fri, 10 July 2015, 10:31:07 »
Yea, but considering I don't have the cash right now the wait doesn't even matter. I really can't wait to see the new store setup!
« Reply #738 on: Fri, 10 July 2015, 10:35:11 »
The wait wasn't bad, I was expecting 5 months and that's how long it took. The wait will only suck if you're really nervous and impatient.
Offline Sed8op8
  • Keyboard Padawan
« Reply #739 on: Fri, 10 July 2015, 10:41:55 »
for a complete it was more like 8-10 months but ya he does deliver 8)
Offline joey
« Reply #740 on: Fri, 10 July 2015, 17:03:43 »
Nice Joey (my namesake-ish!)!
Offline yobinad
« Reply #741 on: Fri, 10 July 2015, 20:27:47 »
"Small" update. Converted from ISO to ANSI and Tai-hao orange fully applied.
I hope the next update is with Hacked by Geeks, or Carbon  :)
Offline Sed8op8
  • Keyboard Padawan
« Reply #742 on: Fri, 10 July 2015, 22:49:23 »
It's finally here ......these 67g clears are super smooth. I really need to find a GMK/BSP Olivetti set to put on this as none of my key sets are going to cut it. Played around with the GUI a bit all in all very happy  :thumb:
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #743 on: Fri, 10 July 2015, 22:54:30 »
Looks great!
Offline heedpantsnow
  • Old enough to know better
« Reply #744 on: Fri, 10 July 2015, 22:54:36 »
Gorgeous!  What color mid piece and LED's?
I'm back.
Offline Sed8op8
  • Keyboard Padawan
« Reply #745 on: Fri, 10 July 2015, 23:09:55 »
everything was supposed to be gold but in person it looks a cool orange-ish shade. I actually really like it but its kind of hard to capture with my phone 8)
Offline beehatch
  • baehatch
« Reply #746 on: Sat, 11 July 2015, 01:39:37 »
It looks sweet to me from your phone pics.
Also, I appreciate how you just threw a reaper on there like it's no big deal. I almost didn't even see it lol.  :))
Offline KatzenKinder
« Reply #747 on: Sat, 11 July 2015, 01:43:10 »
Sneaky reaper! The side/under glow always looks so perfect with GON boards, I'd have gotten one already if it wasn't for Orion... But these pics make me waver
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #748 on: Sat, 11 July 2015, 01:46:52 »
GON always delivers.  The board looks great, Ash.
« Reply #749 on: Sat, 11 July 2015, 01:48:04 »
OK so the switches are soldered but I still need to finish the LEDs and SIP sockets. I ended up going with 78g gateron clears with black cherry switch tops. I kept the gateron bottoms because they make the switch much much smoother.
