Author Topic: Question about zinc caps  (Read 5445 times)
Offline xmagusx
  • QWERTY is hateful.
    • The Ergonomic Zone
« on: Wed, 28 August 2013, 08:54:55 »
Someone's posted caution about Zinc caps:
http://www.reddit.com/r/MechanicalKeyboards/comments/1jnbsr/why_i_wouldnt_recommend_zinc_key_caps_photos/
Has anyone else had this issue?
Offline Tym
Re: Question about zinc caps
« Reply #1 on: Wed, 28 August 2013, 08:57:13 »
Well I have had mine (WASD) set for a fair time now, about 6 months. A heavy use on my daily driver and so far they are still fine, someone mentioned once (can't remember who/where) that it was a reaction to crap on your fingers, but I don't know about that.
Basically, not personally had that issue, but I have seen a couple of examples of those who have.
Offline Obakemono
« Reply #2 on: Wed, 28 August 2013, 09:17:22 »
I guess it depends on caps quality + user cleanliness  :rolleyes:
Offline Photoelectric
« Reply #3 on: Wed, 28 August 2013, 09:22:21 »
I wouldn't use them as my main alpha caps, but I've had them on arrow cluster keys and also Esc, and they've been like new after three months of use.
« Reply #4 on: Wed, 28 August 2013, 09:23:25 »
^^ this matters a lot
eating fried chicken while typing probably not a good idea ;)
Offline tricheboars
  • Keyboards are Important!
« Reply #5 on: Wed, 28 August 2013, 16:03:01 »
if the price of your zinc caps are too good to be true it is because it is too good to be true. i bet this is due to the caps being made out of aluminum with a zinc coating. the zinc coating was thin and wore off. thus this nonsense.
get some good caps and you will probably have better luck.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #6 on: Wed, 28 August 2013, 16:09:01 »
Woa, they were made out of Zinc turbo. Zinc is cheaper than Alu and also heavier, which is evident form the keycaps, since I have both zic and alu caps.
Offline divito
« Reply #7 on: Wed, 28 August 2013, 16:57:18 »
As others have said, it comes down the coating, your finger's cleanliness, as well as, those keys listed in the Reddit article are lettered. I imagine the lettering process makes it thinner in that area, which makes any oils, debris etc... have an easier time penetrating the area of the letters, as seems to be witnessed in the pictures.
I plan on doing zinc alphas, but of the blank variety, to help mitigate any potential issues with wear, on top of maintaining clean hands and the like.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline FrostyToast
  • Litshoard
« Reply #8 on: Mon, 08 December 2014, 14:04:42 »
I used to be all over the idea of a board decked out with zinc caps, but then I slowly came to think that they looked kind of ugly.
Never once considered them again.
Quote from: elton5354
Offline Data
« Reply #9 on: Mon, 08 December 2014, 16:21:52 »
That Reddit post links back to a Titanium key caps group buy on this board from last year.
We should do something like that again.  :D
Offline SpicyLobotomy
« Reply #10 on: Mon, 08 December 2014, 20:43:32 »
From what I know there are 2 versions of the zinc caps, where the first revision would get screwed up from use. The second revision is supposed to be much more durable and I have not seen anyone posting issues with that one yet. Only time will tell I suppose.
"Squidward, I used your clarinet to unclog my toilet"
"They don't think it be like it is, but it do?"
Offline berserkfan
« Reply #11 on: Mon, 08 December 2014, 22:14:01 »
Exactly. Is that MKC Round 1 or MKC Round 2?
Offline EvilOliv3
« Reply #12 on: Tue, 09 December 2014, 05:09:54 »
Wow, I'm pretty sure there's more to it from looking at those pictures. The guy must be omitting something, he could be living unda da sea... No but seriously though, I don't see how, from normal use, the keys would degrade and rust like that.
Offline Data
« Reply #13 on: Tue, 09 December 2014, 10:31:05 »
Skin pH varies between regions and cultures, but is generally mildly acidic (around 5.0 pH).  I'd assume this is sufficient to cause oxidation in the Zinc over the period of months described in that Reddit post, though it probably depends on the electroplating method as suggested by another user.  If the plating layer (probably chrome?) is very thin it would naturally wear with use, exposing the solid Zinc layer below to oxidation.
Just a guess, I'm no chemist.
« Last Edit: Tue, 09 December 2014, 10:36:40 by Data »
Offline berserkfan
« Reply #14 on: Tue, 09 December 2014, 10:31:51 »
One big killer could be him spilling mountain dew on the keycaps and not cleaning them off quickly enough. Mountain dew is acid.
Offline SpecTP
« Reply #15 on: Fri, 12 December 2014, 11:21:30 »
I have a set of MKC red WASD and they wore out around 3months of heavy use.  No more legend and the corners have lost the red color.
« Reply #16 on: Fri, 12 December 2014, 12:56:51 »
All sodas are acid. Not only that, but strong acid as well.
Offline EvilOliv3
« Reply #17 on: Fri, 12 December 2014, 17:45:04 »
Dude must off dipped his fingertips in salt water every time he used his board.
No one seems to mention that this guy carried on using the S and L keys to the point where it looks like a cat's butthole.... and then posted issue.
You would think he thought to post the issue, when he noticed the first sign of wear. Or at least swapped that s*** out, or wear some gloves, just to find out what was causing the problem.
