Author Topic: GH CAD Resources Hub  (Read 991896 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« on: Thu, 29 August 2013, 00:29:07 »
I felt that we were missing a central hub for all the opensource and freely available cad drawing on GH, for a new comer digging these out can be cumbersome.
So, I would like to request members to post whatever CAD resources they have available and if you have a request don't hesitate to ask, I'm sure they will be plenty of assistance.
Offline MOZ
  • Busy making stuff
Re: GH CAD Resources Hub
« Reply #1 on: Thu, 29 August 2013, 00:29:52 »
All files are uploaded to the Github repo: https://github.com/mohitg11/GH-CAD-Resources
Individual components for designing plates (DWG) This has pretty much all the different sized key units, including universal key units for mods based on the excellent work by WhiteFireDragon on the GH60 plates. I would also like to give a shout out to jdcarpe for his brilliant work in designing plates, which was the foundation for this work.
Basic designs for keyboard layouts (DWG) Create designs for GB, or use the keycap designs for other stuff, the dimensions of the keycap are according to SP.
Switch stickers (DWG)
Cherry MX Keycap Stem from Photekq' brass keycap
"Measurement for a stem on a MX keycap. I used this for my latest brass cap and it fit very well. You could maybe make it a little smaller, and I would definitely recommend making it smaller if using plastic/acrylic." - Photekq
Dimensions for the Cherry switch cutouts in a plate, thanks to CPTBadAss and jdcarpe.
Keycap Checker sheets/Keycap Papers:
Available keycaps from SP. These sheets list the various sizes and dimensions and variety of keycaps available from Signature Plastics.
Mounting options available from SP (With Dimensions): Mounting Styles
Phantom Plates. This includes:
-7Bit
-7Bit Shift
-ANSIO 125
-ANSI 150
-ISO 125
-ISO 150
Official Cherry MX Spec Sheet - This is the complete version of the Cherry specifications for the MX switch, including PCB/Plate mounting specifications.
Ergodox Resources. Resources for the ErgoDox keyboard.
Teensy 2.0 breakout board by OldDatahands
Cherry MX keyswitch 3d model: http://sketchup.google.com/3dwarehouse/details?mid=81cf92a3e03098a5cc90be332989df6e
Alps Specifications
« Last Edit: Sun, 24 April 2016, 11:05:02 by MOZ »
Offline MOZ
  • Busy making stuff
« Reply #2 on: Thu, 29 August 2013, 00:30:16 »
Reserving this.
« Reply #3 on: Thu, 29 August 2013, 00:34:55 »
« Reply #4 on: Thu, 29 August 2013, 00:43:33 »
Cross posted from Simple Questions, Simple Answers, the dimensions for the Cherry switch cutouts in a plate.
Offline MOZ
  • Busy making stuff
« Reply #5 on: Thu, 29 August 2013, 01:05:06 »
Update second post, add some resources of my own.
The plate components too a hell of a lot of time to make, phew.
Offline MOZ
  • Busy making stuff
« Reply #6 on: Thu, 29 August 2013, 01:22:22 »
Thanks guys for the inputs.
I've uploaded a bunch of files to the DropBox folder, I'll add them to the post later.
« Reply #7 on: Thu, 29 August 2013, 01:23:44 »
Please credit my earlier post to jdcarpe. He did that work to make the dimensions for the switch cutouts.
Offline MOZ
  • Busy making stuff
« Reply #8 on: Thu, 29 August 2013, 01:30:16 »
Done.
Anyone know the exact location of the stem for an off-center caplock.
« Last Edit: Thu, 29 August 2013, 01:32:46 by MOZ »
« Reply #9 on: Thu, 29 August 2013, 01:46:48 »
Stepped = 4.763mm to the left.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #10 on: Thu, 29 August 2013, 01:52:34 »
Thanks for the collecting and upload!
A Ghost From The Past
Offline MOZ
  • Busy making stuff
« Reply #11 on: Thu, 29 August 2013, 07:10:14 »
This is for the step if I'n not wrong.
I'm interested in the position of the mounting stem for a off-center stepped caplocks.
« Reply #12 on: Thu, 29 August 2013, 07:16:55 »
Sorry if the diagram is not clear enough. Those two squares represent the position of the switch mounting holes for center and stepped caps lock.
Stepped is 4.763mm to the left of a normal center stemmed mounting hole.
So... the stem is also 4.763 left of the center.
« Last Edit: Thu, 29 August 2013, 07:20:07 by Photekq »
Offline MOZ
  • Busy making stuff
« Reply #13 on: Thu, 29 August 2013, 07:21:59 »
Got it, thanks.  :thumb:
I'll add it to the plates component DWG.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #14 on: Thu, 29 August 2013, 08:05:26 »
MOZ, great idea to collect all this stuff.  :thumb:
Quote from: Samuel Adams
Offline Feign
« Reply #15 on: Thu, 29 August 2013, 09:29:55 »
I have been just making up my own DWG files based on my own measurements. I wish i'd seen these earlier but good stuff! I am trying to figure out exactly how the plate cutouts relate to the caps themselves. Any help?
Offline MOZ
  • Busy making stuff
« Reply #16 on: Thu, 29 August 2013, 10:13:39 »
Just created this thread today.
I don't quite get your question. If you look at the plate components file, you'll see that the cutout for 1u, 1.25u, 1.5u, 1.75u are the same, it is just the positions, thus in the dwg file, I have enclosed the cutout shape in shapes based on key size. I think this is what you wanted to know?
Offline MOZ
  • Busy making stuff
« Reply #17 on: Thu, 29 August 2013, 10:14:14 »
It would be great if we can collect and saturate this thread as much as possible and then Sticky this thread.
Offline Feign
« Reply #18 on: Thu, 29 August 2013, 12:10:29 »
Sorry, i can see how ambiguous it was now. What i meant was the position of the cutouts in relation to the caps above them. I am asking because i am designing a couple of housings and would like to know accurately where to fit the plate to the housing such that the outer edge of the outer keys are flush with the inner edge of the tray.
« Reply #19 on: Thu, 29 August 2013, 12:18:13 »
That's what the switch holes with "boxes" around them are for. The boxes represent the keycap size (well, actual keycaps are very slightly smaller, anyway you don't have to include spacing between the keycaps).
Offline MOZ
  • Busy making stuff
« Reply #20 on: Thu, 29 August 2013, 12:27:59 »
According to Cherry 1 unit = 19.05, and accordingly in the diagrams as jdcarpe said, there are boxes according to this unit, so all you have to do make your plate is align the edges of these boxes next to each other and then you can remove the boxes once done. Actual keycaps can are generally about 18.1 to 18.5mm for 1 unit.
Offline Feign
« Reply #21 on: Thu, 29 August 2013, 13:10:39 »
Great, i have them now. Thanks a lot :)
Offline Thimplum
  • Master of all Ponies
« Reply #22 on: Fri, 30 August 2013, 15:31:13 »
Thank you sooo much for doing this, MOZ!
TP4 FOR ADMIN 2013
Offline AGmurdercore
« Reply #23 on: Fri, 30 August 2013, 15:39:27 »
WOW this thread is AWESOME! Good job everyone i will be using some of the stuff that you provided here, thanks a ton!
What the hell am I even doing
Offline MOZ
  • Busy making stuff
« Reply #24 on: Fri, 30 August 2013, 15:57:21 »
Highly encouraging to see people appreciate the efforts.
I'll try and get other work here, please fell free to PM me or post links to stuff you feel should be added. :D
« Reply #25 on: Sat, 31 August 2013, 04:14:53 »
Btw i just noticed that in the main list these are both pointed to the same link:
MOZ's ErgoDox A4 sheet
GeekHack ISO sheet
Offline kps
« Reply #26 on: Sat, 31 August 2013, 10:57:06 »
Offline MOZ
  • Busy making stuff
« Reply #27 on: Sat, 31 August 2013, 11:35:53 »
GeekHack ISO sheet
Fixed
Shinier MX datasheet: http://www.cherrycorp.com/english/switches/pdf/mx_cat.pdf
Cherry MX datasheet with Imperial measurements: http://media.digikey.com/pdf/Data%20Sheets/Cherry%20PDFs/MX%20Series.pdf
First one is incomplete thus I hadn't added it. The second one looks good, I'll add it.
Offline Thimplum
« Reply #28 on: Sat, 31 August 2013, 12:50:49 »
Hey! It's a sticky! And at the top!
By the way, thanks for the basic keyboard layouts. I'm working on... something, and I found it very useful.
TP4 FOR ADMIN 2013
Offline MOZ
  • Busy making stuff
« Reply #29 on: Sat, 31 August 2013, 13:24:04 »
Thanks, just saw, really happy. I'll post more stuff as it is collected.
I don't have the time in hand, but would love to go through the thousands of posts in the making stuff subforum and any any and everything relevant to the OP.
Offline yasuo
  • spanengan puyeng newbie
« Reply #30 on: Sat, 31 August 2013, 13:26:20 »
any software other to open dwg files besides CAD?
Logitech MK220 Colemak DH
Offline MOZ
  • Busy making stuff
« Reply #31 on: Sat, 31 August 2013, 13:51:08 »
I use CorelDraw to open the dwg files as well as make and edit drawings.
There is Inkscape (Open Source) as well.
Offline MOZ
  • Busy making stuff
« Reply #32 on: Sat, 31 August 2013, 16:11:17 »
Updated OP, with information posted thus far.
Offline yasuo
« Reply #33 on: Mon, 02 September 2013, 06:34:48 »
I want alps module,plate alps about alps :p
Thanks MOZ :eek:
Offline BliTzKiN
« Reply #34 on: Mon, 02 September 2013, 08:27:44 »
Really helpful thread, props to you MOZ
Offline MOZ
  • Busy making stuff
« Reply #35 on: Mon, 02 September 2013, 10:35:25 »
Thanks MOZ :eek:
I've not Alps keyboard to take measurements from, I'll try and find resources online and then post.
Offline kps
« Reply #36 on: Mon, 02 September 2013, 11:16:32 »
http://geekhack.org/index.php?topic=5318.msg77984#msg77984
Offline MOZ
  • Busy making stuff
« Reply #37 on: Mon, 02 September 2013, 11:23:20 »
Thank you very much, I'll add them soon.
Offline yasuo
Offline yasuo
Offline MOZ
  • Busy making stuff
« Reply #40 on: Mon, 02 September 2013, 20:04:14 »
Thanks, will add.
  • ~ BOOO ~
« Reply #41 on: Tue, 03 September 2013, 02:08:53 »
I think we should have a "Resources and Info Hub" subforum!
Information only, keyboard-science FTW...
Offline Thimplum
« Reply #42 on: Tue, 03 September 2013, 10:00:13 »
Hmm... I feel like I should contribute something... but what?
TP4 FOR ADMIN 2013
« Reply #43 on: Tue, 03 September 2013, 10:21:20 »
Here are a couple of Alps switch plate files, if anyone would like them.
Offline MOZ
  • Busy making stuff
« Reply #44 on: Tue, 03 September 2013, 14:09:18 »
Thank you sir.
Can I extract the components and post them as a dxf?
« Reply #45 on: Tue, 03 September 2013, 14:24:39 »
Thank you sir.
I was hoping you would do that, yes. :)
Offline MOZ
  • Busy making stuff
« Reply #46 on: Tue, 03 September 2013, 21:06:55 »
Hehe. Good to know.
I'll update  the OP soon.
Offline frogamic
« Reply #47 on: Wed, 11 September 2013, 21:25:16 »
You might want to add this diagram of a costar stabiliser cutout from the DIY resources thread in this sub.
EDIT: credit to bpiphany for the diagram
« Last Edit: Wed, 11 September 2013, 21:30:52 by frogamic »
Filco TKL | Filco ISO105 | Acer 6311-K71
Offline MOZ
  • Busy making stuff
« Reply #48 on: Wed, 11 September 2013, 21:35:22 »
The one in the OP supports both the costar and cherry stabs.
Offline MOZ
  • Busy making stuff
« Reply #49 on: Sun, 22 September 2013, 20:26:31 »
Added 3D model of Cherry MX Switch to OP
