Author Topic: Deleting Poker II space bar text.  (Read 3527 times)
Offline Obakemono
« on: Thu, 29 August 2013, 07:27:52 »
Hi!
Have anyone tried to erase the text in the poker II space bar?
Something like polish it with dremel or so?
I'm getting mine in a few days and would like to give it a try maybe
Offline JPG
  • Model F is my new passion!
Re: Deleting Poker II space bar text.
« Reply #1 on: Thu, 29 August 2013, 07:30:36 »
Hi!
I am pretty sure it is laser etched. You better find another space bar or live with it.
Offline bahamot
    • bistropolis - dine with style
« Reply #2 on: Thu, 29 August 2013, 07:44:53 »
Yup, laser etched infill (I think)
Offline cdmccart
« Reply #3 on: Thu, 29 August 2013, 10:21:47 »
the picture(s) of the poker II's on mechanicalkeyboards.com are showing it with a blank space bar in addition to the keycap puller and a couple of colored keys.
I did purchase one about 6 weeks ago and it did NOT come with one.  Is someone able to confirm that they are now shipping with a blank space bar?
http://www.mechanicalkeyboards.com/shop/index.php?l=product_detail&p=459
Thanks
Offline Rafen
« Reply #4 on: Thu, 29 August 2013, 10:24:56 »
They are coming with blank spacebars. Received mine 2 weeks ago and it came with a blank one. Will post pictures after work.
Offline Obakemono
« Reply #5 on: Thu, 29 August 2013, 10:27:11 »
In the macro picture the laser etched part seems to be over the key, maybe i can make it work, or at least turn the text black.  :D
Offline Obakemono
« Reply #6 on: Thu, 29 August 2013, 10:28:04 »
Ohhh nice, i'm gonna ask how mine is shipped  :)
Offline ynrozturk
« Reply #7 on: Thu, 29 August 2013, 11:08:44 »
Just curious - could we just sandpaper the letters off a standard (non laser etched) keycap? Or would it look terrible?
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Obakemono
« Reply #8 on: Thu, 29 August 2013, 11:30:35 »
My poker doesn't come with extra space bar  :'(
Maybe sanding is a bit hard, i was thinking more on something like polishing, i think i'm gonna tray even if it's laser etched.
Are spare space bars available in the size of the Poker II BTW? It's a 6x right?
Offline ynrozturk
« Reply #9 on: Thu, 29 August 2013, 11:33:32 »
Yeah but polish with what though? Take a bottle of Jack Daniels to it? Haha
Offline fydo
  • Meow!
« Reply #10 on: Thu, 29 August 2013, 11:36:45 »
Perhaps you could paint over the lettering with a black paint? The etching would likely still be somewhat visible, but I'd imagine it would be much less noticeable.
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline ynrozturk
« Reply #11 on: Thu, 29 August 2013, 11:39:42 »
Nah I'd rather not do that. With the amount of typing I do it would just wear off in a few months.
Offline Hellmark
« Reply #12 on: Thu, 29 August 2013, 14:15:02 »
The other option would be to see if you could use a plastic friendly paint thinner to remove the paint. It would leave the laser'ed shadow, but, that would be better than nothing.
Offline ynrozturk
« Reply #13 on: Fri, 30 August 2013, 08:08:48 »
Paint thinner! Of course. I will give that a try on a few keys later on and see how that goes.
Offline JPG
« Reply #14 on: Fri, 30 August 2013, 08:15:31 »
Or you could simply find another spacebar  :p
Offline Obakemono
« Reply #15 on: Fri, 30 August 2013, 08:18:57 »
^ This xD
I will get another, at first i thought it was a non standard size xDD
Offline laffindude
« Reply #16 on: Fri, 30 August 2013, 08:42:58 »
There is no paint.
Offline ynrozturk
« Reply #17 on: Fri, 30 August 2013, 09:19:42 »
On my Razer there is.
Offline laffindude
« Reply #18 on: Fri, 30 August 2013, 09:53:14 »
It is not paint.
Paint thinner will destroy ABS plastic on the Razer.
Offline insilica
  • Keyboard Geeza
« Reply #19 on: Fri, 30 August 2013, 10:14:20 »
Take to it with 120 grit sand paper or equivalent using a dremel if it's really annoying you.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline ynrozturk
« Reply #20 on: Fri, 30 August 2013, 10:14:48 »
Yeah that may be a better idea.
Offline Obakemono
« Reply #21 on: Fri, 30 August 2013, 11:23:00 »
Asap as i get mine, i'll try something and post pictures.
I guess i'll start from softer to more abrasive stuff.
