Author Topic: Recommend me a soldering iron  (Read 4188 times)
Offline Carnage
« on: Thu, 29 August 2013, 18:50:06 »
As title says I'm trying to dig into a bit more of DIY stuff besides keycaps, lube, etc. So I figured id grab myself a cheap beginners solder for just taking off some old alps switches switching them out that something little like that. Id prefer if i could find it on amazon and under 20 dollars. Also what kind of solder is used iron non iron etc?
I was looking at.
http://www.amazon.com/Elenco-Electronics-ST-12-Soldering-Tool/dp/B0002LLWZY/ref=sr_1_3?ie=UTF8&qid=1377820152&sr=8-3&keywords=desoldering+iron
It comes with a solder de solder etc. Thanks!
Offline gnubag
Re: Recommend me a soldering iron
« Reply #1 on: Thu, 29 August 2013, 18:51:35 »
http://geekhack.org/index.php?topic=42824.0
nothing is actually decent under $20 to be honest.
Offline Carnage
« Reply #2 on: Thu, 29 August 2013, 19:07:40 »
Thanks I read through that but I'm looking for ones available on amazon. I wouldn't mind spending more then 20 but id prefer it not to be a ton more since its more of for light changes like swapping out a few switches putting in a teensy etc. Just that little stuff for now one step at a time on diy for me. I was also considering removing all my alps from a board and throwing them onto a new one MAYBE depending on how comfortable i felt after taking off and switching a few switches.
Offline Dubsgalore
« Reply #3 on: Thu, 29 August 2013, 19:10:59 »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Thu, 29 August 2013, 19:14:53 »
^ there's your decent sub-$20 soldering station.
Offline Dubsgalore
« Reply #5 on: Thu, 29 August 2013, 19:18:38 »
it's almost neccessary to get a legit hakko tip, the stock one is abysmal
Offline Carnage
« Reply #6 on: Thu, 29 August 2013, 19:25:05 »
Eek looking at soldering stations, hakko tips, etc on amazon seems like quiet a large chunk of cash.
What about one of these 2?
http://www.amazon.com/Soldering-Station-Features-Continuously-Variable/dp/B0029N70WM/ref=sr_1_1?ie=UTF8&qid=1377822211&sr=8-1&keywords=Soldering+Station
http://www.amazon.com/Velleman-LOW-COST-SOLDERING-STATION-150-480%C2%B0C/dp/B000I40HFQ/ref=sr_1_12?ie=UTF8&qid=1377822211&sr=8-12&keywords=Soldering+Station
First one looks much more appealing imo but i dont know much about this stuff thats why I'm asking you guys.
