Author Topic: Keep lightly colored caps clean?  (Read 2760 times)
Offline pandaemic
« on: Sat, 31 August 2013, 15:58:03 »
Hey guys, I just got some white key caps and they get dirty pretty fast.
I was wondering, what's the best way to keep them clean? For the time being, I wipe them down with alcohol wipes at a weekly basis but is there a more permanent solution?
Offline AGmurdercore
Re: Keep lightly colored caps clean?
« Reply #1 on: Sat, 31 August 2013, 17:44:50 »
I don't really think there is anything else you can do except for cleaning them at a regular basis.
What the hell am I even doing
Offline oscillik
    • music podcasts
« Reply #2 on: Sat, 31 August 2013, 19:25:01 »
I find the best way to keep light coloured keycaps clean is to keep them in a sealed box  :p
or to just wipe every few days with a warm damp cloth!
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline abdulmuhsee
« Reply #3 on: Sat, 31 August 2013, 19:27:21 »
Keep your hands clean; that should do the trick.  :-)
Offline pandaemic
« Reply #4 on: Sat, 31 August 2013, 19:57:57 »
I was thinking of maybe spraying down a spare set of keys with that new Rustoleum Never wet spray.
My hands are clean for the most part but there are those few occasional days were I forget to wash my hands.
Offline abdulmuhsee
« Reply #5 on: Sat, 31 August 2013, 21:01:12 »
Yeah, you just need to find the fastest way to clean them; if you're doing it weekly, methinks a cotton swab and rubbing alcohol would take too long.
I'm a super germaphobe, so I haven't had to clean my keys yet, but I know how even the natural oils from clean hands can eventually coalesce into some sort of brownish goo on the keys/mouse.  If you want to keep it really clean, the trick is simply to find a faster way, like making a pass across the keys with a damp washcloth.  No ideas come to mind after that :-).
Offline Photoelectric
« Reply #6 on: Sat, 31 August 2013, 21:04:28 »
You can use a plastic keyboard roof.  I also wipe my PBT caps with a paper towel dampened with ammonia-free surface / glass cleaner periodically to remove dust and any oils.
Offline divito
« Reply #7 on: Mon, 02 September 2013, 23:06:33 »
There's not much I can think of that's more permanent, that wouldn't end up altering the caps slightly. Other than wiping them down periodically, perhaps using a baby wipe, something non-harsh and unscented, before each use of your keyboard might help mitigate any potential dirt collection.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
