Author Topic: Creating a wireless "dongle" to convert a wired keyboard to wireless  (Read 13004 times)
Offline frew
    • blog
I just got in on the KBT Pure Pro Mechanical Keyboard PREORDER massdrop in the hopes that it could replace my crappy wireless logitech.  I am thinking I'll set up two teensy's as the input and output for the communication.  I am not an Electrical Engineer so I am planning on doing the project in stages.
  • External Power.  I will split apart the wire so that the keyboard is powered by a wall wart, but still uses the tx/rx to the computer.
  • Wireless TX/RX. Obviously this is the hard part.  I was hoping to take some of the code and ideas from this, as it does half of the work: http://www.irongeek.com/i.php?page=security%2Fhomemade-hardware-keylogger-phukd
  • Optional Battery control.  So if you put in enough AA batteries you can be unplugged entirely.  I'd still like to have a USB micro plug to reconnect to wall wart though
  • Finally, since I would be completely relaying all the keystrokes through a "wireless proxy" I think it would be interesting to investigate "middleware macros."  The idea being that you can program a macro on the teensy and then it applies to any keyboard using the teensy.
This also might be handy, though it's PS/2: https://courses.cit.cornell.edu/ee476/FinalProjects/s2003/lph2/WirelessKybd/index.html
If anyone else has done this or has links for it please let me know.  I'd be willing to purchase something if it's not too expensive also.
Offline frew
    • blog
Offline 0100010
  • Not Sure
Re: Creating a wireless "dongle" to convert a wired keyboard to wireless
« Reply #2 on: Tue, 17 September 2013, 08:33:54 »
Offline frew
    • blog
« Reply #3 on: Sat, 09 November 2013, 07:57:24 »
Oh awesome, I'll try that out!  Thanks :)
Offline bassfreak
« Reply #4 on: Thu, 11 February 2016, 09:10:10 »
Meanwhile, there are other solutions that can fit inside/on-side of the keyboard more nicer:
