Author Topic: Phantom/QFR/Filco TKL 100% Open Source Acrylic Case  (Read 315423 times)
Offline roadblock2thesun
Re: Phantom/QFR/Filco TKL 100% Open Source Acrylic Case
« Reply #100 on: Fri, 18 October 2013, 09:06:18 »
Given that the 3mm plate only holds the switches steady, this design would not lend itself to a hand wired board. Is that correct? I wanted to be able to adapt this to make whatever style board I want, including some odd contraptions. I know there is another thread related to using the lowpoly method and laser cut plates, but I didn't see any discussion of the plat thickness there.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #101 on: Fri, 18 October 2013, 12:23:57 »
You have to hot glue the switches.
« Reply #102 on: Fri, 18 October 2013, 21:58:59 »
got it, thanks so much.
I wish there were more convenient laser cutting services. I have had no trouble finding convenient laser cutting of acrylic, but finding someone online to cut metal is much more difficult.
Offline AKmalamute
  • HHKB Scrub
« Reply #103 on: Fri, 18 October 2013, 23:37:04 »
and if I could insert another what-if question...Suppose you had a laser cutter make the 3mm plate then took the pieces to a CNC machine (ridiculous economy I'm sure but) and ground down a 45deg slope, preferably half from each side, so that where the switch clipped into place it was 1.5mm but the plate was the stiffer 3mm thickness?
 Would such a design have structural advantages or would it be asking too much to ground off just that much plastic?
HHKB-lite2, Dvorak user
Offline MOZ
  • Busy making stuff
« Reply #104 on: Fri, 18 October 2013, 23:46:18 »
i tried something similar be etching the area where the switch locks in and it gets much expensive, so much so that you could get a metal plate.
Offline acantha
  • Aure Entuluva
« Reply #105 on: Sat, 19 October 2013, 02:13:01 »
My Phantom build is complete! HUGE props to MOZ for his excellent quality case. It looks AMAZING!
my full build album is here: http://imgur.com/a/ZuQ4H
here's a few shots of the fully built case:
All the Happy Hacking Things
Offline MOZ
  • Busy making stuff
« Reply #106 on: Sat, 19 October 2013, 04:02:56 »
So now we await the Toxic set.
Offline MOZ
  • Busy making stuff
« Reply #107 on: Sat, 19 October 2013, 04:05:19 »
Thanks for the detailed pics. Let me know if there were ANY issues at all, I would love to get them sorted out. So that is two out the park as compatibility goes, now waiting for ray to test out the budget style with a Phantom plate.
« Reply #108 on: Sat, 19 October 2013, 06:48:31 »
Hopefully soon!!! :D
Offline LechnerDE
« Reply #109 on: Sat, 19 October 2013, 08:23:27 »
Wow, those pics look really good!
I'm really interested in ordering a base case and a couple of different color top layers to mix it up :D
Offline Badwrench
  • ummmm.....I forgot
« Reply #110 on: Sat, 19 October 2013, 13:14:35 »
Looks great acantha.  Love that you chose a transparent top so that you can see the phantom pcb.
Offline acantha
  • Aure Entuluva
« Reply #111 on: Sat, 19 October 2013, 13:16:01 »
thanks! yeah, the transparent top turned out better than i had hoped for.
Offline Photoelectric
« Reply #112 on: Sat, 19 October 2013, 13:47:23 »
As already commented elsewhere, the case is excellent! I love that you can see the PCB really well at the top and from the bottom.  Interesting colors too.
Offline archer
« Reply #113 on: Wed, 23 October 2013, 11:58:18 »
Absolutely great job with this case! It looks amazing!
Any idea when a GB will be started for this?
Offline MOZ
  • Busy making stuff
« Reply #114 on: Wed, 23 October 2013, 12:04:03 »
I'm looking to start a flash GB (End in 7 days, fulfillment in 15) in a couple of days, however, there are some road blocks, I don't want to start it and then not be able to fulfill it by the time mentioned.
In anycase, I will start a longer much longer (fulfillment be end of Feb) GB sometime in Nov.
Offline whiskytango
  • Don't touch the trim
« Reply #115 on: Wed, 23 October 2013, 12:38:09 »
MOZ, will you be offering your GH60 and 1800/leeku  cases in the group buy as well?
Offline MOZ
  • Busy making stuff
« Reply #116 on: Wed, 23 October 2013, 12:50:21 »
Yeah, it will be the great case GB, 60%/40%/GHPad/TKL/1800/Funky/75%/ErgoDox, all the cases!
Just need to evaluate what the time I have and how much I can put into the GB. Honestly it is not looking good for the flash GB, I have to fulfill my current GBs and exams will start in Nov.
« Last Edit: Wed, 23 October 2013, 13:25:40 by MOZ »
Offline whiskytango
« Reply #117 on: Wed, 23 October 2013, 13:00:51 »
I understand that. That would be a lot to accomplish in a short amount of time. Well, thanks for all the work, regardless.
Offline archer
« Reply #118 on: Wed, 23 October 2013, 13:19:19 »
Hey thanks for such a quick reply! Whether it's the flash GB or the big GB, I look forward to buying some acrylic from you  :D
Offline BliTzKiN
« Reply #119 on: Thu, 31 October 2013, 21:15:18 »
Me too as well! Does that mean you'll only take 15 orders of each case?
« Reply #120 on: Thu, 05 December 2013, 22:09:00 »
Moz, did you take on too many projects and get side tracked from this one ;)
Does anyone know what steps would need to be taken when converting the dwg files to svg for use with ponoko?
Offline MOZ
  • Busy making stuff
« Reply #121 on: Fri, 06 December 2013, 06:41:30 »
No I have not forgotten it, just ran into some exams and stuff. Once they are over, I will be posting the final designs.
Offline jaymatter
« Reply #122 on: Wed, 18 December 2013, 22:55:10 »
Great work, Moz! Totally interested in the dxf files for this, if you release them (the title does say open source :D ). I've decided to make a Phantom :D
Offline LechnerDE
« Reply #123 on: Fri, 20 December 2013, 01:22:05 »
Looking forward to that!
Offline hellerbarde
  • stumbling through the mechanical keyboard world.
« Reply #124 on: Fri, 27 December 2013, 17:32:54 »
here is a inkscape svg file for curious people without expensive software. (plus the intermediate dxf, but I have no idea whether it's usable, as i dont have autocad)
i hope this is not considered rude.
it's the latest non-disassembled version i found. i'll use that because the lasercutter i have access to has a misaligned lens leading to slightly sheared edges.
Software used: anydwg.com trial version for dwg-dxf and inkscape for dxf-svg (open source)
objectoriented when someone felt like it.
Offline MOZ
  • Busy making stuff
« Reply #125 on: Sat, 28 December 2013, 09:04:20 »
hellerblade, thanks for the svg, I'll remember to post a variety of formats next time I put an update.
I'll be posting the latest revision of this case and the various other cases i have been working on for the past few months soon.
Update includes:
- Designed to support flat-head screws and brass standoffs.
- Support for sprakfun mini-USB-B breakout board: https://www.sparkfun.com/products/9966
- Possible variants: Square edges, thick border, thicker border in middle layers, etc.
Since it is open source, possibilities are endless
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #126 on: Mon, 30 December 2013, 06:37:50 »
Hey MOZ, as you know I've been out of the world for awhile, and I've decided on my phantom solution.
That being said, I'd be very interested in picking up something for a second project, a longer term project.
Here's my idea (and part of it has been mentioned before)
Okay, so working with what you've got, but an alum/steel plate (preferably something we can get colored) and bottom piece. Acrylic body pieces, with no feet pieces, or facing (building up around the keys, on top of the plate)
The plan here, is for me to make a wooden foot piece, and face piece, to bolt onto the body from you.
That being said, I know metalwork in your part of the world seems a bit less exceptionally reasonable than acrylic work, so I'm curious if we could pool resources and maybe find something for the aluminum pieces in another part of the world.
Maybe get quotes from people who already have a good amount of familiarity with their local metalworkers?
You shouldn't have to change too much with the designs, to accommodate the metal plate.
Also, no rush on this project. I'm in not place currently to start paying to prototype it, nor am I ready to start working on my end of this build (still haven't done much with my current phantom board), but I'd like to get ideas and digital plans worked out, because I am very serious about this idea.
What do you think? Any suggestions, or questions?
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline MOZ
  • Busy making stuff
« Reply #127 on: Mon, 30 December 2013, 07:36:21 »
I'm all for helping out in any manner you want, as long is it 2D designs.
Your project does sound interesting and I recall you PMing me about it as well some time back.
  • Demon of the Fall
« Reply #128 on: Mon, 30 December 2013, 10:12:57 »
Yeah, I decided to put it on the back burner for awhile, and make this phantom project my focus.
But I'm thinking about it again.
We'll link up over PM at some point and work out details, but I just wanted to plant the seed today.
Offline MOZ
  • Busy making stuff
« Reply #129 on: Fri, 10 January 2014, 10:06:04 »
So I am completing what hopefully is the final version of the case, however I need some assistance.
I've done editing and finalising all the parts except the plate layer.
I was making the various possible plate layouts that may be used with the Phantom PCB, and there are just so many options. Attached is an SVG/PNG that contains possible layouts for the STANDARD 1.25 base with various options such as:
- Standard 2u backspace OR split (1 -- 1) backspace
- Standard 2.75u right shift OR split (1.75 -- 1) right shift
- Standard 1.75u left shift OR split left shift
- ANSI 2.25u enter OR ISO enter or split (1 -- 1.25) enter
- Standard function row OR 7bit function row
- 15 key nav cluster or standard TKL nav/arrow cluster
For a total of 96 layouts in a 16x9 matrix.
What I need your assistance in is,
- Check that the layouts correspond correctly to the matrix cell based on headings.
- Do not check each layout for accuracy of switch cutouts as that is correct
- All fixed switch cutouts are in black and the changing cut outs in colored for assistance
Once this matrix is verified, I can then swap out the 1.25 base with the following bases:
- 1.5 Mods
- WKL
- HHKB
- 7bit
- 10x spacebar
For a total of 576 (Who would have thought the Phantom would support this many and possibly more layouts)
« Last Edit: Tue, 01 April 2014, 16:57:54 by MOZ »
Offline pasph
« Reply #130 on: Fri, 10 January 2014, 14:35:00 »
There will be a case only option to use with existing plates?
Offline MOZ
  • Busy making stuff
« Reply #131 on: Fri, 10 January 2014, 15:24:42 »
Definitely, and that part is sorted, there are some 12 top plates for different layouts for existing and future plates. I just wanted to get everything sorted and then upload everything in a single go.
Offline MOZ
  • Busy making stuff
« Reply #132 on: Thu, 16 January 2014, 09:32:18 »
Bump, a request for assistance.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #133 on: Fri, 24 January 2014, 01:47:45 »
If I understood your request correctly you want help checking for stuff like this?
In the upper left most layout:
     Column: Standard 2.25L.Shift
     Row: 2.75 R.Shift / Standard 2x BackSpace)
>> The cutout for split 1--1 backspace (in green) and 2x backspace (in red) is overlapped.
Offline MOZ
  • Busy making stuff
« Reply #134 on: Fri, 24 January 2014, 06:23:26 »
Exactly! Thanks. Anymore that you may have spotted?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #135 on: Fri, 24 January 2014, 07:08:10 »
Just that one so far.  I'll go over the rest and report back soon. ;)
Offline MOZ
  • Busy making stuff
« Reply #136 on: Fri, 24 January 2014, 07:52:53 »
Thanks a whole!
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #137 on: Sat, 25 January 2014, 00:20:30 »
Thanks a whole!
What...What did you just call me? :)) :)) :))
You're welcome in advance a whole too! :)) :)) :)) :))
About half-way done. :thumb:
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #138 on: Sat, 25 January 2014, 03:21:34 »
MOZ, spotted 16 in total.  I highlighted them in the red in the attached PNG.
Hope this helps! :thumb:
Offline MOZ
  • Busy making stuff
« Reply #139 on: Sat, 25 January 2014, 09:29:46 »
Thanks very much! This was immensely helpful!
I'll correct those and now easily swap out the bottom row and then post all the layouts.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #140 on: Sat, 25 January 2014, 10:09:03 »
You're very welcome!
I'm game to do a test run for the QFR and Universal TKL Plate.
Offline Ishamael
« Reply #141 on: Fri, 28 February 2014, 15:06:55 »
Are further revisions of this still being worked on, or are the files on page 2 or 7 the final product?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #142 on: Fri, 28 February 2014, 15:11:35 »
My phantom needs this!!!
Offline goonx
« Reply #143 on: Wed, 26 March 2014, 18:51:11 »
Wow this is exactly what i've been looking for. thanks!
really interested in getting the machined version made out of wood. I'm hoping for something like the MKC case
Not a big fan of metal and arcylic
« Last Edit: Wed, 26 March 2014, 18:54:58 by goonx »
Offline MOZ
  • Busy making stuff
« Reply #144 on: Thu, 27 March 2014, 00:25:31 »
Final revisions will be posted early next month,  since right now all my energy is being spent on completing my current GBs.
Offline LechnerDE
« Reply #145 on: Mon, 31 March 2014, 16:18:21 »
That's great news!
I am ready to throw my money at you :p
Offline MOZ
  • Busy making stuff
« Reply #146 on: Mon, 31 March 2014, 16:19:54 »
What money? This is open source :P
Offline LechnerDE
« Reply #147 on: Mon, 31 March 2014, 16:25:15 »
Oh, I supposed this would lead to a GB for the final design?
Offline MOZ
  • Busy making stuff
« Reply #148 on: Mon, 31 March 2014, 16:46:25 »
Not likely.
Offline MOZ
  • Busy making stuff
« Reply #149 on: Tue, 01 April 2014, 18:06:22 »
I've setup the SVG generator, now you can generate the plate based on your choice: http://www.moz.twisted-artworx.com/TKLCase/
Right now the stab cutouts should work with Costar and both Cherry types for all plates less than or equal to 1.5mm, for thicker acrylic plates it will support Costar via gluing.
I'll add option for Cherry PCB mounted stabs for thick mounting plates later.
P.S: Generated SVG will show an error right now (But you can view the generated SVG), this is due to the added text by the free web hosting. If someone has a small server and they could lend me some resource on it, it would be excellent.
Sorry for the plane-jane layout, I'm not much of a web designer. :-/
« Last Edit: Tue, 01 April 2014, 23:29:03 by MOZ »
