Author Topic: Has anyone tried making a Phantom without a plate?  (Read 4039 times)
Offline dante
« on: Tue, 03 September 2013, 10:59:43 »
Basically making it feel like a Cherry board.  The biggest fear is having it bend in the middle like a Poker - but the 11900 doesn't do that.
Re: Has anyone tried making a Phantom without a plate?
« Reply #1 on: Tue, 03 September 2013, 11:09:18 »
The Phantom PCB doesn't have holes for PCB mount switches. :(
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Tue, 03 September 2013, 11:09:30 »
The only way you could is if you drilled holes for PCB mount stabilizers since it currently doesn't support them.
12 seconds too late!
« Last Edit: Tue, 03 September 2013, 11:37:51 by The_Beast »
Offline esoomenona
  • Gnillort?
« Reply #3 on: Tue, 03 September 2013, 11:24:19 »
The 7bit layout doesn't use stabilizers, as far as I'm aware. Thus, you could set that up without a plate.
« Reply #4 on: Tue, 03 September 2013, 11:26:22 »
I don't think this would be too hard. I'm actually considering making holes for PCB stabs on my phantom since they're so much nicer than plate moun.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Tue, 03 September 2013, 11:27:56 »
You might run into issues if you drill through any connections in the PCB since I think the Phantom is multi layered (I could be wrong)
Offline esoomenona
  • Gnillort?
« Reply #6 on: Tue, 03 September 2013, 11:31:18 »
Dual layered, IIRC.
« Reply #7 on: Tue, 03 September 2013, 11:36:53 »
I think maybe you guys missed this:
Offline dante
« Reply #8 on: Tue, 03 September 2013, 11:39:27 »
well that sucks ... ok  :(
I'm going to stick with the GH60 then since that allows PCB only.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #9 on: Tue, 03 September 2013, 11:41:16 »
The Gh60 should support all stabilizers if you get the right plate. I think it's only the universal plate that only allows PCB mount stabilizers
Offline dante
« Reply #10 on: Tue, 03 September 2013, 11:45:20 »
You are confusing me...  What I'm trying to reproduce is the experience of typing on a Poker and as far as I know that doesn't have a plate.  So why would you need a one for PCB stabilizers?  What I'm after is a softer typing experience that may also be easier on the hands.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #11 on: Tue, 03 September 2013, 11:48:57 »
If you're not using a plate, it supports PCB mount cherries.
The quote I quoted made it seems like it only supported PCB mount, when really, with the right plate, it supports all 3 stabilizers types
« Reply #12 on: Wed, 04 September 2013, 10:00:40 »
Each switch on the Phantom will be connected to the PCB at only two points: the two switch pins.
The biggest reason for using a plate is to prevent the switches from being rotated, and thus damage the soldering of the switch pins.
So, technically, you could make a plate from 1.5mm acrylic, and it would work fine for the switches. The stabilisers may need a more durable plate, though.
« Last Edit: Wed, 04 September 2013, 10:02:17 by Findecanor »
