Author Topic: Leopold tenkeyless or cm storm quickfire  (Read 2125 times)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« on: Tue, 03 September 2013, 18:53:31 »
So i was looking at some keyboards and i found this http://www.elitekeyboards.com/products.php?sub=leopold,tenkeyless&pid=fc200rcab and from what i have seen it's a very solid keyboard, this will be my first mech keyboard, sadly i have not had a chance to try any other switches but cherry mx blues but from what i have seen i like blues very much. I'm not sure on a build quality stand point but i prefer the look and font on the leopold over the cm storm. can someone shed some light on this?
« Last Edit: Tue, 03 September 2013, 18:56:23 by Air tree »
Offline jabar
Re: Leopold tenkeyless or cm storm quickfire
« Reply #1 on: Tue, 03 September 2013, 18:59:30 »
Consider that:
the FC200R is an older product already succeeded by the FC700R (that EK cannot/refuses to stock)
that said FC700R has advantages such as PBT keycaps
that the CM Storm Quickfire Rapid is much celebrated as a good quality but cheap option
and the CM QFR is a Costar build
and is sold by many retailers instead of just EK vis Leopolds
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline ComradeSniper
  • HHKB Pro
« Reply #2 on: Tue, 03 September 2013, 19:25:47 »
I'd take a Quickfire Rapid over a Leopold (FC200R or FC700R) any day, mainly because I can't stand Cherry Stabilizers.
Offline Tony
« Reply #3 on: Tue, 03 September 2013, 20:36:55 »
They are both good. For p/p QF Rapid is a bit better, but has the uglier font.
Since I touch type, I recommend QF Rapid
Offline pagosElite
  • This website clings to you.
« Reply #4 on: Wed, 04 September 2013, 00:54:05 »
Definitely QFR, if you want the cool look and don't think you'll buy keycaps any day soon, get the QFS.
Offline vasouv
« Reply #5 on: Wed, 04 September 2013, 01:32:43 »
Personally, if I don't like the looks of something, I don't buy even if it's cheaper.
I ordered a Tenkeyless keyboard from EliteKeyboards simply because I like the looks of it a lot more than the Quickfire. I could have bought a CoolerMaster mechanical keyboard from my country, probably saving some euro, but I'm 100% positive that I wouldn't be totally happy with what I'd end up with. That's why I also didn't get a Razer BlackWidow, same availability in Greece, same weird (for me at least) font on the keys.
Offline Hellmark
« Reply #6 on: Wed, 04 September 2013, 07:39:40 »
Yeah, my biggest complaint about the CM's is the stupid font on the keycaps. They may be good, especially at the price, but if you have to replace the keycaps because you can't stand the font, then any savings goes out the window.
Offline zoolzoo
« Reply #7 on: Wed, 04 September 2013, 10:46:47 »
If you want looks and dont want to replace anything, go with the Leo or QFR Stealth, the reg QFR stock caps are ugly.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
