Author Topic: My first custom keycap: The Zelda Master Sword.  (Read 12774 times)
Offline RabRhee
« on: Thu, 05 September 2013, 11:37:23 »
Here is my first attempt at a custom keycap. The Zelda master sword, stuck in the Pedestal of Time. I thought the key would work well as a substitute pedestal. OEM profile top row.
34235-0
34237-1
34239-2
It is not complete, I stopped working on it to give my hands and eyesight a break, but its pretty far along. I wanted to carve it in metal rather than something easier to shape, because I wanted it in metal and I didn't fancy my chances of casting metal this early. With hindsight it was way way too complex for a first try, but it seemed to come out ok despite that. Made a few mistakes that helped me make fewer doing my second project (coming soon)
Still to do: shape the wings, the inset jewel and the cup above it. Shape the blades of the sword, smooth and polish the lot, mark triforce on sword and pedestal. Colour and lacquer maybe.
Keycap album - http://imgur.com/a/uIRta
Progress album for those who love the montage - http://imgur.com/a/pux8O
I thought I would try Alumin(i)um to start with. I have worked with brass before, but a brass sword seemed like a bit of a cop-out, and carving stainless may just have sent me insane. (or more insane?)
The Aluminium does give me problems of oxidising/corroding, but I figured that would sort itself out should I actually ever achieve something worth immortalising. I thought of home-anodising (buckets of acid slopping around, nope, not yet) and painting (zinc-something primer, then paint/varnish, may as well be plastic). I have tried some car lacquer on an offcut, and it seemed to hold and look OK. I dare say it may still flake off in time, but the key shouldn't be handled that much, so I think lacquer may just work for a while.
The early work was done with a ghetto mill (Dremel in workstation with crossvice) and shaping mostly with Bahco needle files.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: My first custom keycap: The Zelda Master Sword.
« Reply #1 on: Thu, 05 September 2013, 11:40:03 »
Looks really nice for a first try (I understand zero about doing that).
Good job!
Offline Tarzan
  • formerly known as Greystoke
« Reply #2 on: Thu, 05 September 2013, 11:42:48 »
Doing a custom keycap in metal, for a first custom?!  That's pure flash!
Very nice looking, light years ahead of my first attempts.   :-X
« Reply #3 on: Thu, 05 September 2013, 11:44:12 »
* CPTBadAss gives raucous applause
That's incredible. I can't wait to see where this goes. Great work.
I do have to know though, how steady is that mill? Sounds a bit challenging to use.
« Reply #4 on: Thu, 05 September 2013, 11:44:23 »
This looks very nice! Good work!!
« Reply #5 on: Thu, 05 September 2013, 12:04:00 »
whelp... sculpting in epoxy now looks like child's play D:
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #6 on: Thu, 05 September 2013, 12:13:55 »
Nice!
Offline RabRhee
« Reply #7 on: Thu, 05 September 2013, 12:18:51 »
Thanks for the comments so far everyone.
ty, Metal is what I am used to, anything else would have been more exotic :)
I stripped the crossvice (cheap chinese, $90 for 6" vice, 8 inch movements) and polished all the slides and everything else I could, filed a few rough corners. That helped a lot,   I also made a 2 piece custom base for the vice, wood with 3mm neoprene base. There is very little play in the axes of the vice, only small amount when reversing direction. Sounds peculiar not to bolt it down maybe, but the 2 piece is so that I could either have the vice freestanding with both base pieces,  or use half the base and use the workstation base as the second half. As a result, the Dremel and vice are quite firmly bound together, which took out a lot of the erratic behaviour.
The main wobbles now are on the workstation side, but in a fairly predictable way, it will grab at anything like a corner, and its worse cutting with the rotation rather than against it. I have already replaced a few bits on the workstation with brass, and it could use a few more, also there is one piece of cardboard wedged in the top which reduced a great deal of the play, I must make that a 'permanent' fix sometime. When it does have play, its usually along the X axis as sat in front of it, so it became fairly easy to make the least important part in that direction. I also left the really fine detail to hands. For much of the routing of the undersides, I just drill the basic area then use an endmill as a shaver to trim thin slivers off, its pretty safe for that.
 tldr; yes, its insanity, don't try it ;)
Hehe, I watched your work with increasing flabbergastedness, you have produced so much good work so quickly. But as I am a ham-fisted non-artist, the advantage of the metal is that when I slip and carve the wrong bit (about 1 time in 5) it does relatively little damage so I get away with it. The downside is the details can really burn hours, but hours I got :)
Offline Thimplum
  • Master of all Ponies
« Reply #8 on: Thu, 05 September 2013, 12:27:58 »
THAT'S AMAZING. You should make more and sell them.
TP4 FOR ADMIN 2013
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #9 on: Thu, 05 September 2013, 12:54:02 »
Amazing work sir.
« Reply #10 on: Thu, 05 September 2013, 14:01:48 »
Master sword? Pfffff, step up to the Biggoron's sword. That's what real men use!
But seriously, amazing work!
Offline CalmB4tehPwn
  • Demon of the Fall
« Reply #11 on: Thu, 05 September 2013, 16:28:05 »
A fine choice, and finely executed. It is a conundrum you have, because leaving it as it, polishing it up, and it'll be gorgeous, but there's not a really good way to know how it'll look lacquered until it's too late.
I would most certainly put one of those on my keyboard, assuming I didn't use my keyboard on my lap in a recliner. I'd be bound to snap that sword off at some point.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline Martyn.T.Howells
« Reply #12 on: Wed, 11 September 2013, 16:09:05 »
I like that a lot  :thumb: :p
Steelseries 6gv2 MX Black   Filco Majestouch2 TKL MX Blue   Poker II MX Red   HHKB PRO 2
  • Live long and prosper
« Reply #13 on: Wed, 02 October 2013, 09:58:35 »
^This.
But yes, nice work.  Needs a little purple paint for the hilt tho.
tp thread is tp thread
Offline Moosecraft
  • HHKB Pro
« Reply #14 on: Wed, 02 October 2013, 10:08:41 »
Sick craftmanship, can't wait to see it finished :)
Offline RabRhee
« Reply #15 on: Wed, 02 October 2013, 10:20:18 »
Thanks, and thanks for all the positive comments :) I stopped to make my crowdsource keycap, as well as rest my poor old faculties, but now the crowdsource is done I hope to get back to the Zelda. Although as usual, there are 3 other things that require my time, and the dishwasher has just decided to fail so I shall have to take that apart soon :-/  Still, the Master Sword lurks always in my eyeline, it won't be neglected forever.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #16 on: Wed, 02 October 2013, 11:51:24 »
I love Zelda. Of all the games from my childhood to adulthood, I think Zelda had the most profound effect on me. If you ever decide to sell this one, or others I'm very interested.
Offline keymaster
  • Topre Revolution Theorist
« Reply #17 on: Wed, 02 October 2013, 11:55:06 »
That looks really nice, but it would be annoying to actually press.
Offline mr. rampage
« Reply #18 on: Wed, 02 October 2013, 12:04:10 »
That is awesome! Amazing job. Well done. You definitely put a lot of heart and love into this.
