Author Topic: how to add weight to a keyboard  (Read 5337 times)
Offline Jixr
« on: Sat, 07 September 2013, 22:16:29 »
I have a CM quickfire XT at work, and the weight is perfect, heavy enough it won't slide across the desk, but still not too heavy
I'm wanting to add weight to both of my QFR's, since I can easily push them across my desk with my fingers if I try.
Any ideas?
I've had sucess with modeling clay with mice, but not sure if its a good idea to have clay next to a PCB
any ideas?
Offline ComradeSniper
  • HHKB Pro
Re: how to add weight to a keyboard
« Reply #1 on: Sat, 07 September 2013, 22:59:27 »
An aluminium case would definitely do it, though those are expensive and I don't know of any for a full size keyboard. Can't really think of any makeshift weights off the top of my head.
« Reply #2 on: Sat, 07 September 2013, 23:00:58 »
Put a big piece of lead in there. I think that's what ripster actually recommended doing..
  • HHKB Pro
« Reply #3 on: Sat, 07 September 2013, 23:24:45 »
Could you fit a piece big enough to add a noticeable amount of weight under the PCB?
« Reply #4 on: Sat, 07 September 2013, 23:26:49 »
Never seen the insides of an XT but even a thin piece would make a big difference. Lead is very heavy.
If you stuffed a QFR full of lead it'd make a massive difference.
« Last Edit: Sat, 07 September 2013, 23:29:11 by Photekq »
Offline Xenderwind
« Reply #5 on: Sat, 07 September 2013, 23:27:48 »
He's talking about for his qfr's not his xt.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #6 on: Sun, 08 September 2013, 19:41:35 »
Ripster had a guide showing a way to melt lead over your BBQ grill and pour it into a form made from wood and several layers of aluminum foil.
I don't need it, my keyboard weighs 8.25 pounds.
- D Trump 2026-09-28
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7 on: Mon, 09 September 2013, 00:21:31 »
First off I would not recommend using a grill for melting lead unless said grill has been permanently retired from cooking food.  That being said if anyone wants a piece of lead poured for their case let me know the dimensions.  I have a 5 gallon bucket of wheel weights.  Pm me and we can work something out.
