Author Topic: Glass keycaps  (Read 14878 times)
Glass keycaps
« on: Wed, 11 September 2013, 17:37:29 »
Thinking about making a ceramic mold and filling it with glass frit to create a glass set. Has anyone tried this method before, and have you encountered any issues I should look out for? Would slumping be a better rout?
Offline phetto
  • HHKB JP
Re: Glass keycaps
« Reply #1 on: Wed, 11 September 2013, 17:42:08 »
Are you sure they arent going to break? I believe I might destroy glass keycaps. Perhaps youre a bit more careful when computing. :p
Anyway very cool! I will follow this. :)
Re: Glass keycaps
« Reply #2 on: Wed, 11 September 2013, 17:46:40 »
Thick glass should be fine.  Need to be very careful of sharp corners.
Offline TheSoulhunter
  • Thorpelicious!
Re: Glass keycaps
« Reply #3 on: Wed, 11 September 2013, 18:17:31 »
Do ceramic molds work for glass casting?
Re: Glass keycaps
« Reply #4 on: Wed, 11 September 2013, 18:20:59 »
It would be fairly thick, and probably frosted in the end as well. I have no idea how to implement stems yet though, because consistency is very important to me and having a loose or slightly off-center stem would mean me probably having to re-cast the entire thing again. I'll have to ask some advice from folks who do their own casting about it. All I know is that the stems would be attached after the slumping process. Probably by drilling into the glass with a wet drill and gluing it in, but then there's the issue of where do I get/how do I make them. I have access to a big pottery studio as well as a local artist who works with glass and has the proper tools. Maybe he'll have some ideas.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Glass keycaps
« Reply #5 on: Wed, 11 September 2013, 18:22:56 »
If you tempered the glass after casting, that would probably help.
Re: Glass keycaps
« Reply #6 on: Wed, 11 September 2013, 18:28:18 »
huehuehuehuehuehuehue  :-\
nobody will ever know the true meaning behind this laugh
« Last Edit: Wed, 11 September 2013, 18:29:54 by Binge »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Glass keycaps
« Reply #7 on: Wed, 11 September 2013, 18:31:37 »
don't forget the windex :))
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Tarzan
  • formerly known as Greystoke
Re: Glass keycaps
« Reply #8 on: Wed, 11 September 2013, 18:32:48 »
Maybe metal stems.  Cast the caps like Model M caps, and use metal/plastic stems with a square, flat top surface for maximal adhesion.  A bit of epoxy, and those are never coming loose.
Offline phetto
  • HHKB JP
Re: Glass keycaps
« Reply #9 on: Wed, 11 September 2013, 19:12:52 »
binge: glass wasdson?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Glass keycaps
« Reply #10 on: Wed, 11 September 2013, 22:15:25 »
Excited!
Offline cactux
  • Topre Knight
Re: Glass keycaps
« Reply #11 on: Wed, 11 September 2013, 22:29:30 »
How well do you think they will take the stress before the first cracks?
[FS]☠ The temple lol ->HERE<-
Re: Glass keycaps
« Reply #12 on: Wed, 11 September 2013, 22:35:28 »
How about gorilla glass molded into key caps!
Re: Glass keycaps
« Reply #13 on: Wed, 11 September 2013, 22:39:07 »
I could see fracturing around the stem insertion for those who type with gusto, but the actual caps would be thick, heavy, and solid.
Offline BakerMan1971
Re: Glass keycaps
« Reply #14 on: Thu, 12 September 2013, 05:20:01 »
Not sure if they could handle gaming rage, but they would look awesome!
Re: Glass keycaps
« Reply #15 on: Fri, 13 September 2013, 13:30:57 »
It's something I was researching for a while since I wanted to experiment with it, but it's really problematic and, from what I saw, there was no real feasible way to make a stem.  You'd have to fit a stem into the glass.
  • Thorpelicious!
Re: Glass keycaps
« Reply #16 on: Fri, 13 September 2013, 15:45:48 »
Perhaps transplanting stems from clear polycarbonate caps?
Re: Glass keycaps
« Reply #17 on: Fri, 13 September 2013, 15:48:07 »
Potentially, but you also run into issues with epoxy and the like.  It's definitely an interesting idea and one that I've been trying to figure out how to do for a while, but it has its issues that are hard to get around.
  • Thorpelicious!
Re: Glass keycaps
« Reply #18 on: Fri, 13 September 2013, 15:56:21 »
No epoxy...
Thought more of crystal clear adhesive as used for glass and plexi!
  • Thorpelicious!
Re: Glass keycaps
« Reply #19 on: Fri, 13 September 2013, 16:03:36 »
Perhaps creating the mold with a blind-hole:
Re: Glass keycaps
« Reply #20 on: Fri, 13 September 2013, 16:55:09 »
But the glass would slump over it. The other option would be having the hole be created by the top side of the mold with a protrusion the same size of the stem, but the issue with glass it that it starts out solid. If I use slumping which is probably the best method, I would have to drill a hole in the glass before firing. If I use frit there would be no guarentee as to how the glass would settle around the stem part, so it would be a sort of crap shoot for each key.
  • Thorpelicious!
Re: Glass keycaps
« Reply #21 on: Fri, 13 September 2013, 17:39:23 »
Oh, sorry...
That was actually supposed to be the finished thing (Glass-cap/Adhesive/PC-stem)
The mold would be 2 piece like this ^^;
Re: Glass keycaps
« Reply #22 on: Fri, 13 September 2013, 17:52:02 »
Oh, sorry...
That actually might be possible, but would require a lot of attention. essentially it would be:
Lay the glass over the top mold
Fire it in the kiln until softened
Place the top piece of the mold and continue firing
Double the molds means double the chance of the glass sticking to it too. Also my ceramics teacher is wary of the glass exploding in the kiln.
Re: Glass keycaps
« Reply #23 on: Mon, 14 October 2013, 20:59:05 »
My initial mold came out of the kiln today and sadly there was an air bubble in it somewhere and it exploded destroying a bunch of other peoples work with it. Now my teacher wants me to stick to the curriculum, but says I can try again over winter break. :(
Offline MKULTRA
  • telling it how it is
Re: Glass keycaps
« Reply #24 on: Mon, 14 October 2013, 21:18:12 »
HAHAH that is ****ing hilarious.
Offline xecut
Re: Glass keycaps
« Reply #25 on: Mon, 14 October 2013, 23:06:24 »
wow, i like the idea of a glass keycap
Topre Realforce 87U 10th Anniversary Edition | Topre Realforce 87U White Silent | KBT Race | KBT Poker ii | Filco Majestouch Pink
Offline terran5992
  • One With The Cup Rubber
Re: Glass keycaps
« Reply #26 on: Tue, 15 October 2013, 04:56:08 »
I forsee glass injuries
Offline iAmAhab
  • Established member
Re: Glass keycaps
« Reply #27 on: Tue, 15 October 2013, 06:42:55 »
Well this made smile, so all the carnage was not in vain.
Re: Glass keycaps
« Reply #28 on: Tue, 15 October 2013, 07:21:29 »
A bunch of people were pissed and had to have their grades smoothed out before midterm. I sort of feel like God.
Offline viowastaken
Re: Glass keycaps
« Reply #29 on: Tue, 15 October 2013, 10:12:48 »
this could be very interesting if the glass was sandblasted. Glossy regular glass seems incredibly uncomfortable to type on. Sticky icky  :-\
Filco Majestouch Tenkeyless Cherry MX Brown with Ducky thick PBT white/grey
Offline Moosecraft
  • HHKB Pro
Re: Glass keycaps
« Reply #30 on: Tue, 15 October 2013, 10:28:27 »
This would be so sick
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Glass keycaps
« Reply #31 on: Thu, 24 October 2013, 04:31:11 »
I would buy 4 and use as arrow keys in a heartbeat.
Offline Jixr
Re: Glass keycaps
« Reply #32 on: Mon, 28 October 2013, 11:13:43 »
An allum case and glass keycaps is apples wet dream of a keyboard.
Offline mashby
    • Mashby
Re: Glass keycaps
« Reply #33 on: Mon, 28 October 2013, 13:29:30 »
I think it might be mine too. LOL!  :))
Offline BakaPhoenix
Re: Glass keycaps
« Reply #34 on: Mon, 28 October 2013, 15:53:18 »
A satin glass will be nice, but a full transparent glass will be awfull with all the fingerprints on the keycaps.
Offline MKULTRA
Re: Glass keycaps
« Reply #35 on: Mon, 28 October 2013, 19:11:58 »
Re: Glass keycaps
« Reply #36 on: Mon, 28 October 2013, 20:00:06 »
They glass?  Or just plastic?
Offline MKULTRA
Re: Glass keycaps
« Reply #37 on: Mon, 28 October 2013, 23:46:51 »
Offline jonathanyu
Re: Glass keycaps
« Reply #38 on: Mon, 28 October 2013, 23:48:24 »
Offline BakaPhoenix
Re: Glass keycaps
« Reply #40 on: Tue, 29 October 2013, 06:07:53 »
Re: Glass keycaps
« Reply #41 on: Tue, 29 October 2013, 20:17:53 »
Those looks really nice!
They are CC's - how could they be anything but nice? ;)
